Initial Velocity of a dropped object problem
The discussion clarifies the concept of initial velocity for objects in motion. When an object is dropped, its initial velocity is considered 0 m/s at the moment it leaves the hand, as it has not yet begun to move downwards. Conversely, when an object is thrown upwards at 25 m/s, that speed is its initial velocity immediately after leaving the hand. The confusion arises from measuring velocity while the object is still in hand versus after it begins motion. Understanding these distinctions is crucial for correctly applying the concept of initial velocity in physics problems.
sinchan
Why we take initial velocity of dropped object downwards as 0 and 25m/s when the object is thrown 25m/s upwards ?
What is then initial velocity cause when t=0 both object dropping and moving upwards had 0 velocity - in other words when object came to motion at both places it had some velocity?
Are you saying that, when you throw a ball, its velocity is zero when it leaves your hand? And, when you drop a ball, its velocity isn't zero when it leaves your hand?
I can state better when I understand initial velocity - for me when object is dropped from height or thrown with a velocity upwards both of them has velocity zero when it is in hand but both of them have a velocity when it leaves the hand - but then I am not sure when do we measure initial velocity - when it is in hand or when it just started its moion - so when it is in hand for both case initial velocity is 0 and when it started its motion both of them have a velocity - so why we say that initial velocity of object dropped is 0 while 25 m/s when object is thrown upwards as in my example
This is not correct. When you throw something, the velocity of the object just before it leaves your hand is the same as its velocity just after it leaves your hand (>0). And when you drop something, its velocity just before it leaves your hand is the same as its velocity just after it leaves your hand (=0).
i understand your confusion...When you drop a ball, its velocity increases by every second.It becomes 9.8 m/s 1 second after leaving your hand.However, when you throw a ball, the only reason the ball goes out from your hand is because your provided it with acceleration, which caused it to have a velocity, which started its motion, hence its "initial" velocity. When you dropped the ball, the velocity at which the "downwards" motion of ball started is 0 m/s...
Hope this helps
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
