Integral of Fresnel functions
In summary: Finally, we can use the properties of the Fresnel integral to evaluate this integral and arrive at the solution for your original integral. In summary, if you are struggling with this integral, I recommend using integration by parts and a substitution to simplify it and then using the properties of the Fresnel integral to evaluate it. Good luck!
johnglenn
I have been working on this for several days but getting nowhere. Any help would be great.
\begin{align}
&\int_0^x dy\,y^2 \cos(y^2) C^2 \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)
\end{align}
In reality only the first one is causing me troubles, however I have pasted the entire expression as it might lead to some cancellations. Any help would be welcome. $C()$ is the Fresnel integral.
Mathematics news on Phys.org
Hello there,
I can see that you are struggling with an integral involving the Fresnel integral. This type of integral can be tricky, but there are some techniques that you can use to solve it.
Firstly, let's take a look at the integral you have provided:
\begin{align}
\end{align}
One approach you can take is to use integration by parts. This involves rewriting the integral as a product of two functions and then applying the integration by parts formula. In this case, we can choose $u = y^2 \cos(y^2)$ and $dv = C^2 \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)dy$. This will give us:
\begin{align}
&\int_0^x dy\,y^2 \cos(y^2) C^2 \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right) = \left[y^2 C^2 \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)\right]_0^x - \int_0^x dy\,2yC \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)\sin(y^2)
\end{align}
Notice that the first term on the right-hand side can be easily evaluated, leaving us with the integral:
\begin{align}
&\int_0^x dy\,2yC \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)\sin(y^2)
\end{align}
This integral can be solved using a substitution, where we let $u = y^2$ and $du = 2ydy$. This will give us:
\begin{align}
&\int_0^x dy\,2yC \!\!\left(\!\frac{\sqrt{2}\,y}{\sqrt\pi}\!\right)\sin(y^2) = \int_0^{x^2} du\,C \!\
What is the integral of the Fresnel cosine function?
The integral of the Fresnel cosine function is known as the Fresnel C integral, denoted by C(x). It is defined as the integral from 0 to x of cos(pi/2 * t^2) dt. This integral cannot be expressed in terms of elementary functions, but it can be approximated numerically.
What is the integral of the Fresnel sine function?
The integral of the Fresnel sine function is known as the Fresnel S integral, denoted by S(x). It is defined as the integral from 0 to x of sin(pi/2 * t^2) dt. Similar to the Fresnel C integral, this integral cannot be expressed in terms of elementary functions but can be approximated numerically.
What is the relationship between the Fresnel C and S integrals?
The Fresnel C and S integrals are closely related. The C(x) integral can be expressed as 1/2 + 1/2 * S(x), and the S(x) integral can be expressed as 1/2 - 1/2 * C(x). This relationship is known as the Euler identity for the Fresnel integrals.
What are the applications of the Fresnel integrals?
The Fresnel integrals have various applications in mathematics, physics, and engineering. They are commonly used in the study of diffraction patterns, optics, and electromagnetic theory. They also have applications in signal processing, Fourier analysis, and fluid dynamics.
How are the Fresnel integrals related to other special functions?
The Fresnel integrals are related to other special functions, including the error function and the Dawson function. The error function can be expressed in terms of the Fresnel C and S integrals, while the Dawson function is closely related to the derivative of the Fresnel S integral. Additionally, the Fresnel integrals can be used to express other special functions, such as the hyperbolic sine and cosine integrals.
  • General Math
11K
