Is Momentum Conserved in Both Axes During a Projectile Explosion?
Momentum is conserved in both the horizontal and vertical axes during a projectile explosion, particularly when considering the moment of the explosion itself. While gravity acts on the projectile and its fragments, its influence can be negligible compared to the explosive forces at the moment of the explosion. This allows for the assumption that momentum conservation applies during the short duration of the explosion. However, gravity will affect the overall momentum before and after the explosion. Thus, it is reasonable to conclude that momentum conservation holds true at the peak of a projectile's trajectory during an explosion.
Toranc3
Is momentum conserved in a projectile? I was a bit confused with this. Would it be conserved only horizontally? What if it explodes at its max height?
mv=mv2
mv=mv2
What are your thoughts? What can change momentum?
ok so let's say some mass at the top of a projectile explodes. The external force on my system(mass) is the force of gravity. During the explosion though, the force of gravity is small enough to ignore it(compared to the explosion). So momentum is conserved in the x and in the y, starting at the top of a projectile. Is it correct to say that?
Gravity is acting on the projectile and the resulting fragments, so that influences the momentum in the y direction both before and after the explosion.
It's generally a good assumption, considering that the explosive forces are high and short-lived, that other forces such as gravity can be ignored during the explosion. So momentum is conserved during the collision.
TL;DR Summary: Find Electric field due to charges between 2 parallel infinite planes using Gauss law at any point Here's the diagram. We have a uniform p (rho) density of charges between 2 infinite planes in the cartesian coordinates system. I used a cube of thickness a that spans from z=-a/2 to z=a/2 as a Gaussian surface, each side of the cube has area A. I know that the field depends only on z since there is translational invariance in x and y directions because the planes are...
