K_w and auto-ionization of water
  • Thread starter STEMucator
  • Tags
    Water
In summary, the autoionization of water is an endothermic reaction that shifts to the left to compensate for the heat loss. This means that the forward reaction is exothermic and not the reverse.
STEMucator
2,076
140
##K_w## and auto-ionization of water
The ##K_w## value decreases as the temperature decreases. Is the auto-ionization of water an exothermic or endothermic reaction in the forward direction?
Water is able to auto-ionize into ##H_3O^{+1}## and ##OH^{-1}## in an equilibrium reaction:
##H_2O_{(L)} + H_2O_{(L)} \leftrightharpoons H_3O^{+1}_{(aq)} + OH^{-1}_{(aq)}##
The equilibrium constant for this reaction is defined as ##K_w = [H_3O^{+1}][OH^{-1}]##. It is known that the ##K_w## value increases as the temperature increases and decreases as the temperature decreases.
If ##K_w## is decreasing because temperature is decreasing, it means that the concentration of products is decreasing and so the reaction must move forward to produce more products and restore equilibrium. This means that heat must be a by-product of the reaction and therefore the overall reaction must be exothermic so that the equilibrium will shift right as the temperature decreases.
Is this reasonable?
The autoionization of water is an endothermic reaction.
If we increases the temperature Kw increases and the equilibrium shifts towards the products. Because an increase in temperature favors the endothermic side (the products, in this case) we can conclude that the forward reaction is endothermic and not exothermic.
Likes 1 person
But it doesn't shift right.
Think in terms of LeChatelier's principle.
Likes 1 person
Ah so I should think of it the other way around.
If ##K_w## is decreasing because temperature is decreasing, it means that the concentration of products is decreasing BECAUSE the reaction is shifting to the left to compensate for the heat loss. While this shift occurs, it is clear that products become reactants.
Since we added heat and the equilibrium shifted left, we can conclude the overall reaction is endothermic.
Thanks guys :)
Yes, this is a reasonable explanation. As the temperature decreases, the equilibrium between water molecules and ions shifts towards the formation of more ions in order to maintain a constant ##K_w## value. This means that the forward reaction, which produces more ions, is favored and therefore must be exothermic in order to release heat and maintain equilibrium. This is consistent with Le Chatelier's principle, which states that a system will shift in the direction that relieves stress or disturbance. In this case, the decrease in temperature is the stress and the shift towards the forward reaction is the system's way of relieving it.
Related to K_w and auto-ionization of water
1. What is the value of the auto-ionization constant (Kw) of water?
Kw is the equilibrium constant for the auto-ionization of water, which is the process of water molecules breaking apart into hydrogen ions (H+) and hydroxide ions (OH-). It has a value of 1.0 x 10-14 at 25°C. This means that at equilibrium, the concentration of H+ ions multiplied by the concentration of OH- ions will always equal 1.0 x 10-14.
2. How is the value of Kw affected by temperature?
The value of Kw increases as temperature increases. This is because the auto-ionization of water is an endothermic reaction, meaning it requires heat to proceed. As the temperature increases, more water molecules have enough energy to break apart into H+ and OH- ions, resulting in a higher concentration of these ions and a higher value of Kw.
3. What is the relationship between Kw and pH?
Kw and pH are inversely related. As the concentration of H+ ions increases, the concentration of OH- ions decreases, and vice versa. This means that as the pH (a measure of H+ ion concentration) decreases, the value of Kw increases to maintain the equilibrium relationship.
4. How does the presence of solutes affect the auto-ionization of water?
The presence of solutes (other substances dissolved in water) can affect the auto-ionization of water by altering the concentration of H+ and OH- ions. For example, adding an acid (which increases H+ ion concentration) will decrease the value of Kw, while adding a base (which increases OH- ion concentration) will increase the value of Kw.
5. Why is Kw important in chemistry?
Kw is important in chemistry because it relates to the fundamental properties of water and its ability to act as a solvent. It also plays a role in many chemical reactions, as the concentration of H+ and OH- ions can affect reaction rates and products. Additionally, pH, which is related to Kw, is an important parameter in many biological and environmental systems.
  • Astronomy and Astrophysics
