Limits of expression with square root
In summary, the author derives an expression for the concentration of an oxide over time by taking the limit of sqrt(A+Bt) as t approaches zero and infinity. It is possible to do this without making assumptions about the sizes of the terms, such as Bt being significantly larger than A. One approach could be to expand the expression as a Taylor series. As t approaches zero, the sqrt becomes continuous and simplifies to sqrt(A). As t approaches infinity, as long as B is greater than zero, the expression behaves like sqrt(Bt).
engineer23
75
I am looking at the derivation for an expression that relates the concentration of an oxide to time. It appears that to do this, the author takes the limit of sqrt(A+Bt), where A and B are constants as t approaches zero and infinity. Is there an easy way to do this without making assumptions about the sizes of the terms (ex. Bt >> A)? Could I expand this as a Taylor series?
Since the sqrt is continuous, when t->0 you are simply left with sqrt(A). As t->oo, as long as B >0, eventually Bt >> A, so it behaves like sqrt(Bt).
Related to Limits of expression with square root
What is the square root function?
The square root function is a mathematical operation that finds the number which, when multiplied by itself, gives the original number. It is represented by the symbol √ and is the inverse of squaring a number.
What are the limitations of the square root function?
The square root function has some limitations in terms of the values it can output. It can only return non-negative real numbers, meaning it cannot return complex numbers or negative numbers. It also has limitations in terms of the precision of its output, as it may round the result to a certain number of decimal places.
How does the square root function affect the domain and range of a function?
The square root function can greatly affect the domain and range of a function. When applied to a function, it can limit the domain to only positive values, as the square root function cannot take negative inputs. It also has the potential to expand the range of a function, as the square root of a number can be a larger number than the original number.
Can the square root function be used to solve equations?
Yes, the square root function can be used to solve equations, particularly those involving finding the value of a variable that is squared. However, it is important to remember that the square root function has limitations in terms of the values it can output, so it may not always provide a complete solution to an equation.
Are there any alternative methods for finding roots of numbers?
Yes, there are alternative methods for finding roots of numbers, such as using exponentiation or logarithms. However, the square root function is a widely used and efficient method for finding roots of numbers, particularly when dealing with square roots specifically.
