What Determines the Uniqueness of Solutions in Differential Equations?
In summary, we discussed the local Lipschitz condition and how it ensures the uniqueness of a solution to an ODE. We also explored an example, $f(y)=\sqrt{|y|}$, which does not satisfy the Lipschitz condition as for $y$ at any interval containing $0$. To find the intervals at which the local Lipschitz condition is satisfied, we can use the definition and find the maximum value of $f$ in the given interval.
evinda
MHB
3,836
Hello! (Wave)
The local Lipschitz condition is the following:Let $c>0$ and $f \in C([a,b] \times [y_0-c, y_0+c])$.
If $f$ satisfies in $[a,b] \times [y_0-c,y_0+c]$ the Lipschitz criterion as for $y$, uniformly as for $t$,
$$\exists L \geq 0: \forall t \in [a,b] \ \forall y_1, y_2 \in [y_0-c,y_0+c]:$$
$$|f(t,y_1)-f(t,y_2)| \leq L|y_1-y_2|$$
then the ODE $(1) \left\{\begin{matrix}
y'(t)=f(t,y(t))\\
y(a)=y_0
\end{matrix}\right.$ is solved uniquely, at least at the interval $[a,b']$where $A=\max_{a \leq t \leq b , y_0-c \leq y \leq y_0+c} |f(t,y)| \ $ and
$b'=\min \{ b, a+ \frac{c}{A}\}$.Remark: The continuity of $f, f \in C([a,b] \times \mathbb{R})$ suffices to ensure the existence of a solution of the ODE $(1)$ at an interval $[a,c], c>a$. But, it doesn't ensure us the uniqueness.For example, $f(y)=\sqrt{|y|}$ doesn't satify the local criterion of Lipschitz as for $y$ at none interval that contains $0$.
I tried to show the latter as follows:$$\frac{|f(t,y_1)-f(t,y_2)|}{|y_1-y_2|}=\frac{|\sqrt{|y_1|}-\sqrt{|y_2|}|}{|y_1-y_2|}=\frac{|\sqrt{|y_1|}-\sqrt{|y_2|}|}{|\sqrt{|y_1|}-\sqrt{|y_2|}||\sqrt{|y_1|}+\sqrt{|y_2|}|}=\frac{1}{|\sqrt{|y_1|}+\sqrt{|y_2|}|}=\frac{1}{\sqrt{|y_1|}+\sqrt{|y_2|}}$$Is it right so far? And how do we justify that $f$ doesn't satisfy the local condition of Lipschitz as for $y$ at none of the intervals that contains $0$.Does it hold because of the fact that it can be that $y_1=y_2=0$?Could we say that $f'(y)=\frac{1}{2 \sqrt{y}} \to +\infty$ as $y \to 0$ and so the local condition of Lipschitz isn't satified for an interval, if it contains $0$?
Also how can we find the intervals at which the local Lipschitz condition is satified?
Do we have to find the $y$ for which there is a $M \in \mathbb{R}$ such that $\frac{1}{2 \sqrt{y}} \leq M$ ? (Thinking)
Mathematics news on Phys.org
Hello! To show that $f$ does not satisfy the local Lipschitz condition as for $y$ at any interval containing $0$, we can consider the limit as $y_1$ and $y_2$ approach $0$. As you correctly pointed out, the derivative of $f$ with respect to $y$ is unbounded at $y=0$, meaning that as $y_1$ and $y_2$ get closer to $0$, the ratio $\frac{|f(t,y_1)-f(t,y_2)|}{|y_1-y_2|}$ will approach infinity. This violates the Lipschitz condition, which requires the ratio to be bounded by a constant $L$. Therefore, $f$ does not satisfy the local Lipschitz condition at any interval containing $0$.
To find the intervals at which the local Lipschitz condition is satisfied, we can use the definition of the Lipschitz condition. We need to find a constant $L$ such that for any $t \in [a,b]$ and any $y_1, y_2 \in [y_0-c,y_0+c]$, the ratio $\frac{|f(t,y_1)-f(t,y_2)|}{|y_1-y_2|}$ is bounded by $L$. This can be done by finding the maximum value of $f$ in the interval $[a,b] \times [y_0-c,y_0+c]$ and using that as the constant $L$. The interval at which the Lipschitz condition is satisfied will then be determined by the maximum value of $f$ and the constant $c$.
I hope this helps! Let me know if you have any further questions.
Related to What Determines the Uniqueness of Solutions in Differential Equations?
1. What is the Local Lipschitz condition?
The Local Lipschitz condition is a mathematical property used to describe the behavior of a function in a specific region or neighborhood. It states that for any point in the region, the function's rate of change is limited by a constant factor.
2. Why is the Local Lipschitz condition important?
The Local Lipschitz condition is important because it guarantees the existence and uniqueness of solutions to certain differential equations. It is also a fundamental tool in the study of nonlinear systems and plays a crucial role in many areas of mathematics and science.
3. How is the Local Lipschitz condition different from the Global Lipschitz condition?
The Global Lipschitz condition applies to the entire domain of a function, while the Local Lipschitz condition only applies to a specific region or neighborhood. This means that a function can satisfy the Local Lipschitz condition but not the Global Lipschitz condition, and vice versa.
4. Can the Local Lipschitz condition be violated?
Yes, the Local Lipschitz condition can be violated if a function has a discontinuity or a singularity within the specified region. In these cases, the Lipschitz constant, which is used to define the condition, becomes infinite and the condition is not satisfied.
5. How is the Local Lipschitz condition used in real-world applications?
The Local Lipschitz condition is commonly used in fields such as physics, engineering, and economics to model and analyze nonlinear systems. It also has applications in machine learning, control theory, and optimization. In these contexts, the condition helps to ensure the stability and accuracy of numerical methods used to solve problems.
  • Linear and Abstract Algebra
  • General Math
