Converting Longitude coordinates to feet (for separation)
John1397
188
TL;DR Summary
I have two longitude decimals readings and they are .11330 apart how many feet is this? One is 98.000000 and other is 98.113300
Mathematics news on Phys.org
On the north pole it's zero. Where are you ?
98 puts it in North Dakota
:smile: that would be latitude 47 or thereabouts. Latitude matters to convert longitude differences to furlongs!
  • Haha
Likes berkeman
Here we have 1 degree of longitude = 288200 ft. That's at 38 deg latitude. So for latitude 47 you have ##\cos 47/\cos 38## times 288200 feet per degree of longitude.
Someone should check this :wink:
And don't forget to set the calculator to 'degrees' !
Likes berkeman
@John1397 you need to figure the circumference at the latitude then divide by 360 to get the arc distance per degree.
Likes FactChecker
With the range of latitudes in North Dakota, that leaves an uncertainty of about 800 feet plus or minus for the east/west distance corresponding to .113300 degrees of longitude.
Meanwhile, with six significant figures, that angular measurement claims to be good to within 2.5 inches, plus or minus.
*mumbles to self for a bit... derivative of cosine is sine... latitude around 45 degrees... sine is about .7... *
If your north/south position is off by 4 inches, then your estimate of east/west distance will be less accurate than that angular uncertainty calls for.
*mumbles to self again... *
At the 2.5 inch accuracy level, we need to be worrying about the ellipsoidal shape of the Earth, local topography and the distinction between a great circle and a rhumb line.
Likes gmax137
  • General Math
  • General Math
  • Astronomy and Astrophysics
