Minimizing Fraction with Inequalities - POTW #292
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, the purpose of minimizing fractions with inequalities is to simplify and solve equations that involve fractions and inequalities. This is done by finding the least common denominator (LCD) of the fractions involved and multiplying each fraction by the LCD. This process allows for easier comparison of values and makes it easier to find the solution to the equation. There are no special rules for minimizing fractions with inequalities, and it can be done with fractions that have different denominators. It is important to minimize fractions with inequalities because it simplifies complex equations and makes them easier to solve.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
Minimize \(\displaystyle \frac{2x^3+1}{4y(x-y)}\) given \(\displaystyle x\ge -\frac{1}{2}\) and \(\displaystyle \frac{x}{y}>1.\)
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the following members for their correct solution: (Smile)
1. Ackbach
2. Opalg
3. castor28
4. greg1313
Solution from Opalg:
Let $z = \dfrac xy$. Then $z>1$, and $y = \dfrac xz$. Therefore $$ \frac{2x^3+1}{4y(x-y)} = \frac{(2x^3+1)z^2}{4x(xz-x)} = \frac{2x^3+1}{4x^2}\cdot\frac{z^2}{z-1}.$$ The function $\frac{2x^3+1}{4x^2}$ is positive for all $x\geqslant -\frac12$, and the function $\frac{z^2}{z-1}$ is positive for all $z>1$. So to minimise the product of the two functions on those intervals, it is sufficient to minimise each function separately and then take the product.
The minimum of $\frac{2x^3+1}{4x^2}$ is $\frac34$ (occurring when $x = -\frac12$ and also when $x=1$). The minimum of $\frac{z^2}{z-1}$ is $4$ (occurring when $z=2$). So the minimum of their product is $3$, occurring at the points $(x,y) = \bigl(-\frac12,-\frac14\bigr)$ and $(x,y) = \bigl(1,\frac12\bigr)$.
Alternate solution from castor28:
Let us call the expression $f(x,y)$. The domain under consideration is delimited by the lines $y=0$, $y=x$, and $x=-\frac{1}{2}$. As the first two lines are not part of the domain, we can only have a minimum at an interior point or on the boundary $x=-\frac{1}{2}$.
We compute the partial derivative:
$$\displaystyle
\frac{\partial f}{\partial y} = -\frac{(2x^3+1)(x-2y)}{4y^2(x-y)^2}
In the domain, this is $0$ only on the line $x=2y$; therefore, any interior minimum must be on that line.
We define:
$$\displaystyle
g(x) = f\left(x,\frac{x}{2}\right) = 2x + \frac{1}{x^2}
This function has a single minimum at $x=1$ with value $g(1) = 3$.
We look now for a minimum on the boundary line $x=-\frac{1}{2}$. As this line is parallel to the $y$ axis, the condition $\partial f/\partial y=0$ still applies, and the only possible extremum is at $y=-\frac14$, where the value of the function is $3$. As $g'(-\frac12) =18>0$, this is indeed a minimum.
To summarize, we have two minima at $\left(1,\frac{1}{2}\right)$ and $\left(-\frac{1}{2},-\frac14\right)$, both with value $3$.
1. What is the purpose of minimizing fractions with inequalities?
The purpose of minimizing fractions with inequalities is to simplify and solve equations that involve fractions and inequalities. This allows for easier comparison of values and makes it easier to find the solution to the equation.
2. How do you minimize fractions with inequalities?
To minimize fractions with inequalities, you first need to find the least common denominator (LCD) of the fractions involved. Then, multiply both the numerator and denominator of each fraction by the LCD. This will result in equivalent fractions with the same denominator, making it easier to compare and solve the equation.
3. Can you minimize fractions with different denominators?
Yes, you can minimize fractions with different denominators. This is done by finding the least common denominator (LCD) of all the fractions involved and multiplying each fraction by the LCD.
4. Are there any special rules for minimizing fractions with inequalities?
There are no special rules for minimizing fractions with inequalities. The same rules for simplifying and solving equations with fractions apply, such as finding the LCD and multiplying by it.
5. Why is it important to minimize fractions with inequalities?
Minimizing fractions with inequalities is important because it allows for easier comparison of values and makes it easier to find the solution to the equation. It also helps to simplify complex equations and make them more manageable to solve.
  • Math POTW for Secondary and High School Students
