Monitoring Voltage of Batteries w/ ADC0834 - Help Needed!
  • Thread starter Thread starter TxAggie00
    Batteries Voltage
The discussion focuses on automating the monitoring of battery voltage during charging and discharging using a microcontroller and the ADC0834. The user seeks advice on how to connect the ADC without overloading it, especially given the charger’s output of up to 24V. Recommendations include using a voltage divider to ensure the ADC only sees a maximum of 5V, and considering a higher precision ADC, such as a 10-bit version, for better measurement accuracy. The circuit design proposed draws minimal current from the charger, ensuring it does not interfere with battery charging. Overall, the conversation emphasizes the need for careful circuit design to protect the ADC and achieve precise voltage readings.
TxAggie00
Hello all!
I do not pretend to have any knowledge of electrical engineering, just enough to get myself in trouble and blow up some transistors. That being said, I have a question for the experts.
My recent hobby project requires my computer software (my area of expertise) to interface with a microcontroller. What I am trying to do is plot the voltage change in batteries as they are being charged and discharged. Sitting there with my fluke for 6 hours doesn't intrigue me, so I am trying to "automate" the process. The charger has an output rating of up to 24V and 1.5 amps. I am using a Parallax bs2px for the microcontroller and an ADC0834 4-channel ADC for voltage sensing. How can I monitor the batteries with that ADC and not put too much current through it? Do I need to isolate that part of the circuit? If so, how? I have read through the datasheet for the http://www.national.com/mpf/DC/ADC0804.html#Overview" , but it might as well be written in latin. I do know that I am going to need a 5:1 voltage divider, because my Vref is 5V.
Any help is appreciated! Thanks,
Scott
That link was for a different ADC. However, I have used the ADC0834 and wouldn't recommend it.
It is a serial device, so you have to read off each of the 8 bits by sending pulses to it. Yukk!
If your battery charger does 24 volt batteries, you need the ADC to cover up to 30 volts to allow for fully charged batteries being about 29 volts.
To do this, get two 100 K resistors and put them in parallel. Wire this combination from the charger to a 10 K resistor to ground.
Then take the voltage at the junction of the two 100 K resistors and the 10 K resistor to your ADC converter.
[PLAIN]http://dl.dropbox.com/u/4222062/voltage%20divider.PNG
So, suppose you had 30 volts at the input of this voltage divider.
Then the output would be 10/60 times 30 V or 5 volts.
Lower input voltages will give less than 5 volts.
You might like to take this question to the Programming and Computer Sci part of this Forum:
https://www.physicsforums.com/forumdisplay.php?f=165
to see if someone can suggest a better way of doing the A to D conversion.
I use Picaxe chips for everything, but I haven't had much luck getting converts to that system.
Thanks for the reply!
From what I have seen and experimented with using the ADC0834, I would have to agree with you. I will probably move to at least a 12 bit ADC. I have all the programming done and am successful taking measurements using the 5V on the board and a 10K pot to adjust the voltage going into the ADC, but what I am unsure of, is how the ADC being in parallel with the charger and battery will affect the charging of the battery if at all. I want to have as little of an impact as possible. Also, the batteries are 18V, so I probably won't see voltages over 24.
Thanks for the circuit diagram. I will breadboard that out and see how it works.
Thanks,
Scott
The circuit I suggested would draw only 0.5 mA from the battery charger, so it is not a problem. (ie 30 Volts / 60000 ohms = 0.5 mA). You can get 1% precision resistors for a few cents more, so get those if you can.
One thing worth considering is the open circuit voltage of the battery charger. If this goes to 40 volts when the battery is disconnected, you need to allow for this and make sure your ADC is protected.
I'd suggest at least a 10 bit A to D. This is because you need to read the voltage in a small area of the total range (maybe 14 volts to 18 volts) and you need good precision to do this.
If the range was 0 to 30 volts then each bit change would represent 0.029 volts on a 10 bit A to D while it would represent 0.117 volts on an 8 bit A to D. This is a worthwhile improvement.
It will give much smoother curves if you are graphing the results.
Perfect! Thanks so much for your assistance!
Thanks,
Scott
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
