Multi-stage compression with intercooling
  • Thread starter Thread starter exergetic
    Compression
The discussion focuses on the calculation of intermediate pressures in a multi-stage compressor with three intercoolers to minimize specific work. The user seeks clarification on how to determine these pressures, noting that they can find the intermediate pressure with a single intercooler but struggle with multiple intercoolers. It is established that the minimum specific work occurs when all pressure ratios between stages are equal. The formula provided indicates that the pressure ratio can be calculated as the nth root of the inlet and outlet pressures, where n represents the number of compression stages. The conversation concludes with an acknowledgment of the assistance received.
exergetic
Hi everybody!:smile:
I have a question about intercooling process in compressors
Regarding ,for example, a mutli-stage compressor with 3 intercoolers,I'm a little bit confused about finding the intermediate pressures of each intercooler that minimize specific work.I'm able to find the intermediate pressure only if there'ls only one intercooler,using well known statement:
where Px is the intermediate pressure at which intercooling process happens, P1 and P2 the inlet and the oulet pressure in the compressor.
Could anyone help me?
http://air-compressors-info.blogspot.com/2007/12/multi-stage-compression-with.html"
Thanks in advance.
(sorry for my rough english)
Are you familiar with thermodynamic processes, and how they are mapped on a thermodynamic properties chart (such as a T-S or P-V diagram)? A multi-staged compression cycle with intercooling would be pretty easy to visualize on a T-S diagram...
http://en.wikipedia.org/wiki/Temperature_entropy_diagram"
Yes,I have some familiarity with thermodynamics.But I know how to represent this process on T-s chart.Instead I would understand,in case of more than 1 intercooling process, how to calculate pressure values at which intercoolers must work for minimizing specific work.Could be correct to state that the minimum specific work is obtained when all pressure ratios equate each other?In other words when:
\frac{Pinlet}{Pi1}=\frac{Pi2}{Pi1}=\frac{Pi3}{Pi2}=\frac{Poutlet}{Pi3}
Yes, all pressure ratios from each compressor must be the same and it is found this way:
P_{r}=\sqrt[n]{\frac{P_{out}}{P_{in}}}
Where n is the number of compressors.
So with 3 intercoolers, n = 4.
Ok,thanks a lot for your help.I appreciated it.
:smile:
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
