Need some Domain and Range Help
In summary, In part a, you graphed a graph of the square root function and found that the domain is (2, infinity] and the range is (1, infitty]. In part b, you graphed a graph of the square root function and found that the domain is (X E R | x >= 2) and the range is (Y E R | y >= 1). In part c, you found that y(x) is undefined and in part d, you found that z(x) is undefined.
MrRottenTreats
Hey here is the question has a few parts to it.
Let f(x)= (x-1)^1/2 and g(x)= 2x^2/x^2+1
a) State the domain and range of f using interval notation.
b) State the domain and range of g using interval notation. (Hint: At
x=0, g is 0. For x(cannot=0) it helps to write g(x)=2/1+1/x^2 and
then stetch a plot of g. Since x^2>0 it follows that g(x_ is always
below 2)
c) Find and simplify the expression for y(x)=(g o f)(x) and state its
domain and range in interval notation.
d) Find and simplify the expression for z(x)=(f o g)(x) and state its
for a) i sketched a graph and made an x/y chart and subbed numbers in.
2 1
5 2
10 3
then got the domain to be: X E R | x >= 2
and the Rang YE R | y >= 1
domain: (2, infinity] ?
Range: (1, infitty] ?
and for b i did that same thing with the x/y chart
and i got domain: X E R
Range: Y E R | y >= 0
the hard part here is that i don't know how to put either of them in "interval notation"
and for that c) and d) i have no clue what y(x)=(g o f)(x) is asking me to do, and also z(x)=(f o g)(x)
some help would be great ! thanks.
Interval notation is something like:
(a,b) or [a,b) or (a,b] or [a,b]
I'm pretty sure that your range and domain aren't correct but you do understand interval notation.
Although you want to use the 'open' bracket for infinity:
[tex](a,\infty)[/tex]
and not
[tex](a,\infty][/tex]
since the latter indicates that [itex]\infty[/itex] is part of the set.
This should probably be in the homework help section.
Anyway, f o g means apply g to x first, then apply f to g.
So for example, say you have[tex] f(x) = 3x, g(x) = x^2, then f o g = f(g(x)) = f(x^2) = 3(x^2) = 3x^2[/tex]
Obviously, in general, f o g =/= g o f.
OK, now for part a and b..
The domain of a function is the set of all numbers such that that function is defined; why is it that you say the domain of [tex]f(x) = \sqrt{x-1}[/tex] is [tex][2,\infty][/tex]?
Also, what about what you found for the range? The range is the set of all points that the function hits, so to speak, whenever you give it its domain.
With the square root function, it's always greater than or equal to 0. Hence, to find its domain, you want to find all x such that [tex]\sqrt{x-1}\ge0[/tex] which you should have no problem solving.
Part B's domain is OK, but your range is off-- see below.
To write something like R, you write it as the interval [tex](-\infty,\infty)[/tex], or [tex]x\ge2[/tex] as [tex][2,\infty)[/tex] and so on and so forth.
About Part B's range-- [tex]g(x)= \frac{2x^2}{x^2+1}[/tex] can be written as [tex]g(x) = \frac{2x^2 + 2 - 2}{x^2 + 1} = 2 - \frac{2}{x^2 + 1}[/tex] (what you wrote is incorrect-- the way I'm seeing it, anyway).
From this, what can you gather from the behaviour of x, i.e. locally around 0 and as [tex]x\to \infty[/tex]?
ok so for part a) i siad that cause when i plotted my points it started at x=2 , so that's why i had my domain as [tex][2,\infty][/tex]
and for the rang it was the same thing, i just looked at my graph and tried to do it...
and also the same thing for b).. um I am looking at them again and i can't really see where i went wrong with the domain and range.. maybe i graphed it wrong. What should the domain and range read?
now for c)
g o f = 2(x-1)^1/2)^2 / ((x-1)^1/2)^2+1
d)
f of g = ((2x^2/x^2+1)-1)^1/2
now what the heck do i do with these, if i got them done correctly.
thanks.
Well, does f(1) make sense? What about f(0)?
Related to Need some Domain and Range Help
1. What is a domain and range?
A domain is the set of all possible input values for a function, while a range is the set of all possible output values. In other words, the domain is the set of x-values and the range is the set of y-values for a function.
2. How do I find the domain and range of a function?
To find the domain, look at the input values (x-values) and determine what values can be used in the function. To find the range, look at the output values (y-values) and determine what values are produced by the function.
3. Can a function have more than one domain and range?
No, a function can only have one domain and one range. This is because each input value (x-value) must correspond to only one output value (y-value).
4. What is the difference between a continuous and discrete domain and range?
A continuous domain and range consists of values that can take on any real number, while a discrete domain and range consists of specific, separate values. For example, a function with a continuous domain and range could be a line, while a function with a discrete domain and range could be a bar graph.
5. Can a function have an infinite domain or range?
Yes, a function can have an infinite domain or range. This means that the function can take on any real number, positive or negative, as an input or output value.
  • Calculus
  • Calculus
