How Do Magnetrons Generate Microwave EM Waves?
  • Thread starter IniquiTrance
  • Tags
    Concepts
In summary, the magnetron is a thermionic diode that uses a parallel magnetic field to cause bunched electrons to travel in a circular path. When these bunched electrons pass by cavities, microwave electromagnetic waves are resonated in the cavity. The frequency of revolution for the electrons is determined by the magnetic field strength, which is set to the desired frequency for the magnetron microwave cavities. This creates a chain reaction of electron bunching, resulting in the production of electromagnetic waves.
IniquiTrance
190
I'm writing a paper on the magnetron, and was wondering if anyone can help me with some conceptual elements of its workings.
I understand it is a thermionic diode, and that a parallel magnetic field causes emitted electrons to travel in a circular path about the cathode.
How is it that when the circling electron bunches pass by cavities, microwave EM waves resonate in the cavity?
Any help is greatly appreciated!
Please see my post in another thread. The electrons are accelerated by a negative bias on the thermionic cathode, and they orbit in a circle just inside the vanes of the magnetron cavities. Their frequency of revolution is about 27.992 GHz per Tesla of magnetic field (875 Gauss for a microwave oven), so the magnetic field strength determines the revolution frequency. The magnetron microwave cavities are resonant at the desired frequency, and the magnetic field is set to the proper value so they generate a electromagnetic wave which in turn bunches the electrons, which in turn bunches the electrons more, etc.
Hey Bob,
I'm going to thank you for both replies here. :)
The thing I seem to be missing is how is it that the electron bunches produce EM waves? When and how are photons emitted?
Thanks!
EM waves have both transverse E and transverse H components. A bunched electron beam has a radial E field (from Coulomb charge) and an azimuthal H field (from amp current). So a bunched electron beam can couple to (or from) a bunched electron beam.
1. What is a Magnetron?
A Magnetron is a vacuum tube that is used to generate high-frequency electromagnetic waves, typically microwaves. It is commonly used in microwave ovens, radar systems, and particle accelerators.
2. How does a Magnetron work?
A Magnetron works by using a strong magnetic field to control the flow of electrons within the tube. The electrons are emitted from a cathode and then accelerated towards a series of resonant cavities, which causes them to oscillate and generate microwaves.
3. What are the main components of a Magnetron?
The main components of a Magnetron include a cathode, an anode, a filament, a magnet, and resonant cavities. The cathode emits electrons, the anode collects them, the filament heats up the cathode, the magnet controls the electron flow, and the resonant cavities generate the microwaves.
4. What are the applications of Magnetrons?
Magnetrons have various applications, including in microwave ovens for cooking food, in radar systems for detecting objects, in medical equipment for imaging, and in particle accelerators for scientific research.
5. How can I troubleshoot issues with a Magnetron?
If you are experiencing problems with your Magnetron, it is best to consult a professional. However, some common troubleshooting steps include checking for loose connections, ensuring the power supply is functioning correctly, and examining the magnetron for any physical damage or signs of wear and tear.
  • DIY Projects
  • Electrical Engineering
  • Poll
  • Science and Math Textbooks
  • Electromagnetism
