Net metering - hybrid solar inverter system question
  • Thread starter Thread starter coltonk
There is a demand for larger inverters (15-20KW) that can utilize either AC or DC generators for net metering without relying on solar panels. The discussion highlights the difficulty in finding commercially available grid-tied inverters that meet these specifications. It emphasizes that net metering is influenced by local regulations and the type of meter used, which can vary significantly by region. Participants suggest exploring manufacturers of biogas and micro-hydro systems as potential sources for the desired inverter technology. The conversation underscores the need for inverters that can comply with grid requirements while facilitating direct net metering from generators.
coltonk
TL;DR Summary
solar inverter
Does anyone know of a manufacturer who makes larger inverters (15-20KW) that can use either an AC or DC generator to product power for net metering. Ive searched for days and all I come up with is systems that require solar panels to do the net metering. I'm not trying to power any loads, just want to do the net metering. I cant believe that there are no commercially available grid-tied inverters that simply take either AC or DC and send it back to the grid via net metering.
coltonk said:
TL;DR Summary: solar inverter
Not sure what you are after. Net metering is not strictly a product of the inverter type, it is how the system is wired to the meter and the type of meter - and crucially, what the rules about it are. Inverters and grid connections need to conform to appropriate local requirements.
Different places, different rules. Earliest grid tied solar around here (Australia) connected so that any feed-in to the grid sent old style disc meters backwards but such meters and net-metering are anachronisms and meters now count feed-in separately to power drawn from grid, each with separate pricing - which may change according to what time of day and how much feed-in, imposed daily or monthly limits etc.
If you still have an old style power meter upgrading it to the required type is a requirement to connect solar here. There are moves towards grid operator capability to remotely turn feed-in off and on according to grid management needs.
I understand net metering, local power company requirements and NEC code related to net metering, but I need to know about the inverter, specifically whether any grid-tied inverter is offered by any manufacturer that can perform straight net metering from a generator to inverter to the power grid. Other than solar, I can not find any manufacturer that supports this. Grid tied inverter are made to perform the need tasks to tie into grid power including protecting the people working on the grid during a power outage. I am hoping someone on here can point me to a group of manufacturers that offer the equipment. Existing solar inverters are an option and I can probably make that work but I would much prefer an AC system that can take incoming AC power and preform the phase match along with any other power company requirements at a cost as inexpensive as solar inverters.
You can start by looking up manufacturers for biogas and micro-hydro system components.
I don't think you are going to find what you are looking for. Even in large wind farms, where the turbines in the nacelles produce AC power, it is then converted to DC before being fed to in inverter to connect to the grid.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
