Why Is Y Considered 1 in Antenna Power Gain Calculations?
In summary: I got started on this journey. But, at the start, of necessity, it's easiest to talk about something that's ideal and mathematically easy to deal with. That's the isotropic antenna, and for the moment, assume that you are feeding it with a magical wire that doesn't radiate. Then the power into the feedpoint is all radiated away by the isotropic antenna. That's the "1" in the denominator.Keep in mind that this is just a theoretical concept and in reality, antennas have ohmic losses and other factors that affect their efficiency and gain. But for the purposes of understanding the basic concepts, it is helpful to start with an idealized isotropic antenna.
amgc63
TL;DR Summary
Question;
Given that a dipole antenna has directional gain of 2, calculate the power gain in Dbi?
Answer;
Power gain = 10 log (x/y), where y =1
Power gain = 10 log (2/1) = 3dbi
My question is….how come y = 1??
Thanks in advance
Question;
Answer;
Thanks in advance
Welcome to PF.
dB gain will be with respect to some reference. So the antenna gain in this case is with respect to a unity gain (isotropic) antenna.
Other common dB gains are dBm (dB above 1mW into 50 Ohms) and dBuV (dB above a microvolt).
Likes amgc63 and hutchphd
Because dB is always the log( abs( ratio ). In this case, the directivity of 2 is being compared with the isotropic antenna, which is defined as having a directivity of 1.
amgc63 said:
Question;
It is unusual to mix antenna directivity with power gain without considering ohmic losses in the antenna. A half wave dipole has a directivity gain of 2.15 dBi .
https://en.wikipedia.org/wiki/Antenna_(radio)#Gain
https://en.wikipedia.org/wiki/Antenna_gain
Likes berkeman and amgc63
Baluncore said:
Because dB is always the log( abs( ratio ). In this case, the directivity of 2 is being compared with the isotropic antenna, which is defined as having a directivity of 1.It is unusual to mix antenna directivity with power gain without considering ohmic losses in the antenna. A half wave dipole has a directivity gain of 2.15 dBi .
Thanks.
What if the question ask a directivity gain of 4?
What is the power gain in dbi??
10log(x/y)
10log (4/?)
Still can’t get the “y” into my head. :(
Are you aware that multiplying numbers in the real domain is equivalent to adding their logs ?
A gain of 2 is 10 * Log( 2 ) dB = 3.0103 dB
A gain of 4 is a gain of 2 twice, 2*2 = 4. That is 2 * 3.0103 dB = 6.0206 dB
10 * Log( 4 ) = 6.0206
10( 6.0206 / 10 ) = 4.0000
Thank you.
Yes, but I just don’t understand y=1
Was given a question previously,
Question;
Answer;
I just don’t understand why y =1
Is it becoz isotopic? “Y” always 1?
Yes. An isotropic antenna is a virtual antenna that has a directivity of 1.
If you want gain in dBi you use y = 1.
If you want gain in dBd you use y = 1.64
You should read the wikipedia section on Antenna Gain where it is fully explained;
Likes amgc63
Gain is defined as a RATIO between what the improvement is and some standard.
For instance you mentioned a power gain of 4. OK, that makes the power 4 times greater than 'something.' Looking at it this way, the 'something' is the standard and you are getting 4 times as much of it.
Now the number '4' can also we written as '4/1', with the '1' representing what you started with.
That's why the '1' in the denominator.
In this case the 'something' is the broadcast power of the simplest omni-directional antenna.
Here is another, made-up example that wouldn't actually be used:
If you had a 2HP motor and replaced it with an 8HP motor. You can say that you are now using a motor that is 4 times stronger than the original, or a power increase of 6dBH (H for horsepower).
Hope this helps!
Cheers,
Tom
Likes amgc63
Thank u so much. Now the “y” get into my head. 🙏
All this assumes that all the power that's put into the feed point of the antenna gets radiated. It's got nowhere else to go but into space and an isotropic antenna will radiate equal power densities in all directions (hence the "1")
It's easy to want (intuitively) to consider practicalities like the effect of plugging a different antenna into the same transmitter / feed arrangement but the theoretical antenna gain ignores this. The design Engineer doesn't because higher gain antennae tend to have higher currents flowing in places (like the ground) which introduces loss and another 'dB factor' to be added in.
Likes amgc63
The OP persists in computing the “power gain” directly from the directivity.
The problem here is that directivity specified in dB is not "power gain" even though it uses 10 * Log10( ratio ).
It's a pretty common 'error'. The geometrical gain talks much more than the 'signal gain' in the mind and often in practice. Moreover, when considering a receiving antenna, the important performance criterion is very often to do with rejection of interference off-beam and less to do with receiver noise.
We're getting into more complex matters here and perhaps the OP would see that factors, other than just antenna are very relevant in real radio communications.
1. What is antenna power gain?
Antenna power gain is a measure of the ability of an antenna to direct or concentrate the power of an electromagnetic wave in a particular direction.
2. How is antenna power gain calculated?
Antenna power gain is calculated by comparing the strength of the signal in a particular direction with the strength of the signal that would be transmitted by a hypothetical isotropic antenna, which radiates equally in all directions.
3. What is the difference between antenna power gain and antenna directivity?
Antenna power gain and antenna directivity are related but different concepts. Antenna directivity refers to the ability of an antenna to focus radiation in a particular direction, while antenna power gain takes into account the efficiency of the antenna as well as its directivity.
4. How does antenna power gain affect the performance of a wireless system?
The higher the antenna power gain, the more focused the radiation pattern of the antenna will be, resulting in a stronger signal in a particular direction. This can improve the performance and range of a wireless system, but it also means that the antenna will be less effective in transmitting or receiving signals from other directions.
5. What factors can affect antenna power gain?
The design and construction of the antenna, as well as its placement and the surrounding environment, can all affect antenna power gain. Other factors such as frequency, polarization, and impedance matching can also play a role in determining the power gain of an antenna.
  • Astronomy and Astrophysics
  • Classical Physics
  • General Engineering
