Pool heat gain by solar radiation versus heat loss by evaporation
The discussion centers on the effectiveness of using 22mm thick black EPE panels to cover a pool in relation to heat gain from solar radiation and heat loss from evaporation. It is noted that up to 85% of solar radiation can heat an uncovered pool, while evaporation accounts for 70% of heat loss. The key question raised is whether the heat gain reduction from covering the pool with EPE panels outweighs the benefits of reduced evaporation. One suggestion was to use a transparent foil cover, but concerns about its practicality were expressed. Ultimately, the user seeks clarity on the optimal approach for maintaining pool temperature on sunny days.
chrisDH
Hi,
On various websites I read that 70% of the heat loss of a pool is by evaporation, whereas up to 85% of the solar radiation can heat an uncovered pool.
We use 22mm thick black color EPE panels to cover our pool.
On a sunny day, is it better to cover the pool or to leave it uncovered ?
In other words ;
Is the reduction of heat gain (because of the EPE panel cover) compensated by the reduced heat loss by evaporation ?
Thanks for your help
Chris
Science news on Phys.org
How about using a transparent foil cover? It let's the sun in, and keeps the vapor inside.
Hi A.T
thanks, but I've had one of those before. there difficult to remove and you need an ugly big roll beside your pool.
Since I've been using the EPE panels my pool is a lot warmer too.
I just cannot figure out whether it's better to cover the pool during a sunny day or not
rgds
Chris
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
