Probability theory question
In summary, Alice is choosing 7 classes out of 30 in a small college where classes meet only once a week. She has 6 classes to choose from for each day of the week (Monday through Friday). The probability of her having classes every day is not as simple as choosing any course for each day and then any two of the remaining courses. This method overcounts possibilities and leads to a probability above 1. Instead, the principle of inclusion and exclusion should be used to account for possible overlaps in the chosen courses.
Astudious
61
Alice attends a small college in which each class meets only once a week. She is
deciding between 30 non-overlapping classes. There are 6 classes to choose from
for each day of the week, Monday through Friday. Trusting in the benevolence
of randomness, Alice decides to register for 7 randomly selected classes out of
the 30, with all choices equally likely. What is the probability that she will have
classes every day, Monday through Friday?
Seems like basic probability theory
I'm confused here, because my thinking was that I should be able to say she can choose any course for the five days of the week (65 ways of doing this), and then any two of the remaining 25 courses (C(25,2) ways of doing this), so the total probability is 65*C(25,2) / C(30,7). But this is wrong (the answer is above 1).
I considered also that if, after she has picked one course on each day of the week (65), she can then pick another, she has 25 options, and then 24 more after that (since those are how many courses are available at each stage, and she can pick anything since she has fulfilled the every-day-class criterion). But this gives 65*25*24 / C(30,7) which is also wrong (above 1).
Why are these methods wrong?
Since there are 5 slots and 6 chosen courses, the event E = {at least one course each day} must have one day with two courses and four days with one course each.
The first course is chosen at random. What is the probability that the second chosen course is on the same day as the first? What is the probability it is on a different day? What is the probability the third chosen course is on the same day as one of the first two (if possible)? What is the probability it is on a different day from the first two?
Keep going like that. The main issue is to keep track of the "overlaps".
I think the main problem with your method is that she does not choose "days", but courses. When she chooses a course, its day is pre-determined and so is not under her control.
For a start, you get to count the same selection more than once (hence the > 1 result). E.g. if the 5 one-per-day selections you start with are A, B, C, D, E, respectively and your last two are F and G, which happen to be on Wednesday and Thursday, you get the same set of 7 starting with A, B, F, G, E, then picking C and D.
Are you familiar with the principle of inclusion and exclusion? Consider how many ways there are of picking the 7 from a specific four days (or subset thereof).
I'm not sure I understand this. I do see the way of solving this problem by brainstorming, but not why the two methods in the OP are wrong?
It's similar, I feel, to the conundrum in this link: http://mathforum.org/library/drmath/view/62620.html. I would think the answer to the question there should be (2 * C(4,1) * C(51,4)) / C(52,5) - you pick an ace, out of the 4, and then any 4 cards (to total 5) out of the remainder (51), and there are two ways to arrange the two cards you have, so multiply by 2. What's wrong with the logic?
Dr Math's explanation of Matti's error at that link is wrong. Matti's error is the same as yours in this thread. As I posted above, you are counting some possibilities twice over.
In the poker hand example, Matti is counting hands with two Aces twice. E.g. suppose the hand is DA, CA, HK, HQ, HJ. Matti counts DA, plus the other four cards, then counts CA plus the other four cards. Hands with three Aces Matti counts three times, etc.
First: sorry, my previous response was for choosing 6 courses, not 7. But my final objection stands: you need to choose courses, not days.
Let's look at the case of choosing 6 courses (which I will do now in another way); the case of choosing 7 course is a bit more involved, as it needs consideration of more cases, but I will leave that up to you to pursue.
So (for 6 courses) let p(i,j,k,l,m) = probability of choosing i courses on day 1, j courses on day 2, ..., m courses on day 5. You want
[tex] \text{answer} = p(2,1,1,1,1) + p(1,2,1,1,1)+p(1,1,2,1,1)+p(1,1,1,2,1) + p(1,1,1,1,2) [/tex]
Now each of these terms is a simple (multi-class) hypergeometric probability: if we have ##N## items, ##N_1## of type 1, ##N_2## of type 2, ..., ##N_r## of type r, then the probability ##p(k_1,k_2, \ldots, k_r)## of choosing ##k_1## items of type 1, ##k_2## items of type 2, ..., ##k_r## items of type r in a sample of ##n## items selected without replacement (and with ##k_1 + k_2 + \cdots + k_r = n## is
[tex] p(k_1, k_2, \ldots, k_r) = \frac{C(N_1,k_1)\, C(N_2, k_2)\, \cdots \,C(N_r,k_r)}{C(N,n)} [/tex]
Here, ##N = N_1 + N_2 + \cdots + N_r##. See, eg., http://en.wikipedia.org/wiki/Hypergeometric_distribution (esp., last section) or
http://www.epixanalytics.com/modelassist/AtRisk/Model_Assist.htm#Distributions/Discrete_distributions/Multivariate_Hypergeometric.htm
So, we have ##p(2,1,1,1,1) = C(6,2) C(6,1)^4/C(30,6) = 432/13195 \doteq 0.03274##. You can quite easily see that all the other terms in the answer are equal to the first one, so
[tex] \text{answer} = 5\, p(2,1,1,1,1) = C(5,1) \, p(2,1,1,1,1) = 432/2639 \doteq 0.16370 [/tex]
Can you see how to extend this to the case of choosing 7 courses?
BTW: you should always check your answers. Had you done so you would have seen that your first answer gave a value of ##\text{ans. 1} = 432/377 \doteq 1.146##, while your second one was ##\text{ans. 2} = 1512/377 \doteq 4.011##.
I think "haruspex" has already explained to you where your errors lie, so I am restricting myself to giving a positive answer (what to do), rather than a negative one (what you did wrong).
1. What is probability theory?
Probability theory is a branch of mathematics that deals with the study of random phenomena and their outcomes. It helps in understanding the likelihood of different events occurring and enables us to make predictions based on data.
2. How is probability calculated?
Probability is calculated by dividing the number of desired outcomes by the total number of possible outcomes. This gives us a numerical value between 0 and 1, where 0 represents impossibility and 1 represents certainty.
3. What is the difference between theoretical and experimental probability?
Theoretical probability is based on mathematical calculations and assumes that all outcomes are equally likely. Experimental probability, on the other hand, is based on actual data collected from experiments or observations and may differ from theoretical probability.
4. What are the different types of probability?
The three main types of probability are classical, empirical, and subjective. Classical probability is based on equally likely outcomes, empirical probability is based on data collected from experiments, and subjective probability is based on personal beliefs or opinions.
5. How is probability used in real life?
Probability is used in various fields, such as statistics, finance, and science, to make predictions and informed decisions based on data. It is also used in gambling and risk assessment to determine the likelihood of different outcomes and to manage uncertainty.
