Quadratic Equation Roots in Terms of Summation: POTW #285, Oct 28th, 2017
  • MHB
  • Thread starter anemone
  • Tags
    2017
In summary, a quadratic equation is a mathematical equation in the form of ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. The roots of a quadratic equation are the values of x that make the equation equal to 0, and they can be expressed as a summation of two terms using Vieta's formulas. This method provides a better understanding of the relationship between the roots and coefficients of the equation, but it only applies to equations with real roots. Complex roots cannot be expressed in terms of summation.
anemone
MHB
POTW Director
3,883
115
Here is this week's POTW:
One of the roots of the quadratic equation $x^2-kx+2n=0$ is equals to $\dfrac{1}{\sqrt{1}}+\dfrac{1}{\sqrt{2}}+\cdots+\dfrac{1}{\sqrt{n}}$, where $n$ is a positive integer.
Prove that $2\sqrt{2n} \le k \le 3\sqrt{n}$.
Remember to read the http://www.mathhelpboards.com/showthread.php?772-Problem-of-the-Week-%28POTW%29-Procedure-and-Guidelines to find out how to http://www.mathhelpboards.com/forms.php?do=form&fid=2!
Congratulations to the lfdahl for his correct solution(Smile), and you can read the suggested solution as follows:
Let \(\displaystyle u=\sum_{a=1}^{n}\frac{1}{\sqrt{a}}\) and \(\displaystyle v=\frac{u}{\sqrt{n}}\) so we have \(\displaystyle k=u+\frac{2n}{u}\).
Note that for all \(\displaystyle a\in [1,\,n]\), it must be true that \(\displaystyle \frac{1}{\sqrt{a}}\ge \frac{1}{\sqrt{n}}\). From here we get \(\displaystyle u\ge \frac{n}{\sqrt{n}}\) and that simply is \(\displaystyle u \ge \sqrt{n}\).
Now, for all \(\displaystyle a\in (1,\,n]\), \(\displaystyle \frac{1}{\sqrt{a}}\le \int_{a-1}^{a} \,\frac{dx}{\sqrt{x}}\) and so we get
\(\displaystyle \sqrt{n}\le u \le 1+\int_{1}^{n} \,\frac{dx}{\sqrt{x}}\)
\(\displaystyle \sqrt{n}\le u \le 2\sqrt{n}-1 \le 2\sqrt{n}\)
\(\displaystyle 1\le \frac{u}{\sqrt{n}} \le 2\)
\(\displaystyle 1\le v \le 2\)
So we get $v-2 \le 0$ and $v-1 \ge 0$ and thus
$(v-2)(v-1) \le 0$
$v^2-3v+2 \le 0$
$v+\dfrac{2}{v} \le 3$
Since we have $x+\dfrac{2}{x}\ge 2\sqrt{2}$ for all $x>0$, we get
$2\sqrt{2} \le v+\dfrac{2}{v} \le 3$
$2\sqrt{2n}\le u+\dfrac{2n}{u}\le 3\sqrt{n}$
$2\sqrt{2n} \le k \le 3\sqrt{n}$ (Q.E.D.)
What is a quadratic equation?
A quadratic equation is a mathematical equation in the form of ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. It is used to solve problems involving quadratic relationships, such as finding the dimensions of a rectangle with a given area.
What are the roots of a quadratic equation?
The roots of a quadratic equation are the values of x that make the equation equal to 0. They are also known as the solutions or zeroes of the equation. In terms of graphing, the roots represent the x-intercepts of the parabola.
How can quadratic equation roots be expressed in terms of summation?
In some cases, the roots of a quadratic equation can be expressed as a summation of two terms. For example, if the roots are r and s, then they can be written as (r + s) and (rs). This is known as Vieta's formulas.
What is the significance of Quadratic Equation Roots in Terms of Summation?
Expressing quadratic equation roots in terms of summation can provide a more intuitive understanding of the relationship between the roots and coefficients of the equation. It also allows for easier calculation of the roots in certain cases, such as when one root is known and the other can be calculated using Vieta's formulas.
Can all quadratic equations be expressed in terms of summation for their roots?
No, not all quadratic equations can be expressed in terms of summation for their roots. This method only applies to equations with real roots. If the roots are complex numbers, then they cannot be expressed in terms of summation.
  • Math POTW for Secondary and High School Students
