Question about Piezoelectricity
In summary, the conversation discusses the concept of piezoelectricity and its potential use as a source of energy. The article states that a piezoelectric material can produce a voltage in response to mechanical stress, but this voltage is only useful for high frequency AC current. The conversation also explores the possibility of using piezoelectricity at the atomic scale and for cooling purposes, but it is currently only feasible at the macro-level for devices such as microphones. The reliability of Wikipedia as a source of information is also questioned.
superpaul3000
62
I was reading the wiki article on Piezoelectricity and this effect is either really odd or I'm missing something obvious here (I know wikipedia is not the best source but I'm feeling lazy). The article states that a Piezoelectric material will produce a voltage in response to mechanical stress. So looking at the picture there it looks like simply applying pressure to something will produce a voltage that I can run an electric load on. If that is true then we can just put one of these under a mountain and humanity's energy needs are taken care of forever!? Something about that just doesn't make sense. Do they mean that the increase in pressure produces a voltage but after that pressure is done increasing the voltage drops again? So dropping a mountain on one of these would make a lot of energy obviously lol.
It seems you missed the third sentence in the article you were reading.
If the material is not short-circuited, the applied stress induces a voltage across the material.
I see now. That seems to rule out the ridiculous mountain scenario. So if you can't close the circuit then how is it used to power devices like when it is put in peoples shoes?
Because the stress is variable in time, constantly creating new charges on the plates of the capacitor.
Hi Paul. The trick is that these piezoelectric devices can only displace the charge in the circuit by a very small amount, so that rules out the possibility of providing the constant DC current that you envisage.
Note however that you can get useful amounts of high frequency AC current flow even with very small displacement of charge! So that's the catch, you can't use them to deliver constant power under a static load (like your "under a mountain" example), you have to continually alternate (or pulsate) the mechanical stress in order to obtain useful output power.
I hope that helps.
I hope that helps.
Ok that makes a lot more sense. I think that was my understanding I guess the article just confused me. I'll update it to make that more explicit. This is a cool effect. I wonder if it can convert atomic scale kinetic energy into electricity like it can do with macro scale kinetic energy. Like if there was a wall of nano sized Piezoelectric plates that an air molecule could bounce off and some of that momentum would be converted into electricity. Is that possible? If so I wonder if it could be used to take thermal energy out of the air. That way I can chill the beer in my cooler and run my laptop of that energy at the beach. :)
Please do not update anything since it is obvious you are incompetent to do so.
Well that's the great thing about wikipedia. Check out what I wrote and fix it if you see anything wrong. Just because I'm incompetent doesn't mean I'm always wrong. So what do you think, is the cooler idea not possible?
This concept is already in use at the macro-level in piezoelectric microphones. So, it won't cool your beer but you can rock with it! :biggrin:
My experience - Wikipedia is worthless if you're trying to learn something of any complexity. If you already know it, but have forgotten the formula's,etc., it can be right handy.
That much I know. The difference between the two examples being that sound waves create mechanical stress large enough to produce voltages big enough to have detectable currents given the resistances we are dealing with. The voltage from an air molecule bouncing off the piezoelectric device is minuscule. I think the problem with the piezoelectric cooler is that R>>V and thus current is negligible. What if we had a room temperature superconducting closed circuit, could we charge a superconducting battery (not chemical) on that and cool the air as well?
Actually a total closed superconducting circuit is not necessary. I guess it must be superconducting from the capacitor plates surrounding the piezoelectric material, through a transformer that can step it up to some usable voltage, and up to the electrodes. Then you can apply any load.
1. What is piezoelectricity?
Piezoelectricity is the ability of certain materials, such as crystals and ceramics, to generate an electric charge in response to mechanical stress or pressure.
2. How does piezoelectricity work?
Piezoelectric materials have a crystalline structure that allows for the displacement of positive and negative charges within the material when it is subjected to mechanical stress or pressure. This displacement creates an electric field and results in the production of an electric charge.
3. What are some common uses of piezoelectricity?
Piezoelectricity has a variety of applications, including in sensors and transducers for measuring pressure, force, and acceleration. It is also used in ultrasound technology, motors, and actuators.
4. Can piezoelectricity be produced in any material?
No, piezoelectricity is only observed in certain materials with a specific crystalline structure, such as quartz, tourmaline, and certain ceramics. These materials are known as piezoelectric materials.
5. Is piezoelectricity a renewable source of energy?
Yes, piezoelectricity is considered a renewable source of energy because it can be continuously generated as long as the material is subjected to mechanical stress or pressure. However, the amount of energy produced is relatively small and it is not currently a major source of renewable energy.
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
  • Electromagnetism
  • Materials and Chemical Engineering
