What is the Range of a/b When ln(a+1)/ln(b+1) = x?
  • MHB
  • Thread starter AlexRaw
  • Tags
    Ratio
In summary, the conversation discusses the relationship between the ratios of two variables, a and b, that have been log-transformed. The speaker is trying to determine the range of a/b when ln(a+1)/ln(b+1) = x where 0 < x < 1. They also mention that a and b are positive integers with finite ranges 0 < a < 499,639 and 1 < b < 837,481. The conversation suggests simplifying the equation to (a-b) = e^x where 0 < x < 1, and using graphing to find the solution that satisfies the given restrictions. The conversation also mentions the incorrect use of ln(m-n) instead of ln(m) -
AlexRaw
Hi,
I am working on a data set and I have log-transformed two variables a and b and would like to figure out the relationship between the respective ratios. I have a strong intuition that a/b should have a well-defined range for a given value of lna/lnb, but my maths is poor.
a and be are positive integers with a finite range
0 < a < amax, amax=499639
1 < b < bmax, bmax=837481
I am looking for the range of
a/b
when
ln(a+1)/ln(b+1) = x
0 < x < 1
I know that for x = 1, a/b = 1 and when x = 0, a/b = 0
For anything in between there must be a range.
I'd like to plug in an x and get a range of possible values for a/b.
I have run a regression analysis on my data and figured out the deviations, but I am looking for a cleaner, more general solution that I could potentially also compute when the ranges of a and b are different.
Is this even possible?
Thanks in advance. I'd appreciate any help. :)
Mathematics news on Phys.org
*Note, it usually helps to write out the mathematical computations yourself for better understanding. Also, the final solution that I have concluded will be capitalized and spaced out to make the conclusion clearer and stand out.*
Hi, I understand that it has been quite some time since you posted this question, but I would like to answer it simply for the sake of not leaving this question unanswered.
Now I'm not sure if there is something missing to this question, but as far as I understand it:
0 < a < 499,639
1 < b < 837,481; where:
ln(a+1)/ln(b+1) = x and 0 < x < 1
Understanding the premise of the question, let's simplify the information given into something more palatable:
ln(a+1)/ln(b+1) = x
ln((a+1) - (b+1)) = x
ln(a+1-b-1) = x
ln(a-b) = x
(a-b) = e^x; where 0 < x < 1
Now that we have simplified, we have two pieces of information:
a/b = x
With this in mind, we can combine these equations to further simplify this into one equation:
( A - B ) = E ^ ( A / B ); where 0 < a/b < 1, 0 < a < 499,639 and 1 < b < 837,481
This equation can be graphed using the appropriate restrictions in order to achieve the graph you (possibly) are looking for. I hope this helps!
[DESMOS]advanced: {"version":7,"graph":{"squareAxes":false,"viewport":{"xmin":-1285622.270847463,"ymin":-1288793.4180495471,"xmax":1438164.1255536359,"ymax":1434992.978351541}},"expressions":{"list":[{"type":"expression","id":"graph1","color":"#2d70b3","latex":"e^{\\frac{x}{y}}=x-y"},{"type":"expression","id":"2","color":"#388c46","latex":"0\\ <\\frac{x}{y}\\ "},{"type":"expression","id":"3","color":"#6042a6","latex":"\\frac{x}{y}\\ <\\ 1"},{"type":"expression","id":"4","color":"#000000"},{"type":"expression","id":"5","color":"#c74440"}]}}[/DESMOS]
* the solution that satisfies the given restrictions are where the green and purple colors MEET, that is, the darker purple color houses all of the possible combinations of "a" and "b" (x and y) that satisfies the conditions outlined in the question.*
Llwewllyn said:
ln(a+1)/ln(b+1) = x
ln(a+1-b-1) = x
ln(a-b) = x
\(\displaystyle \ln(m-n) = \ln \left( \dfrac{m}{n} \right) \neq \dfrac{\ln m}{\ln n}\)
Sorry, but \(\displaystyle ln(m - n) \neq ln \left ( \dfrac{m}{n} \right )\).
\(\displaystyle ln \left ( \dfrac{m}{n} \right ) = ln(m) - ln(n)\)
@Llwewllyn:
Neither \(\displaystyle ln \left ( \dfrac{m}{n} \right)\) nor \(\displaystyle \dfrac{ln(m)}{ln(n)}\) are equal to \(\displaystyle ln(m - n)\). Unless we are using some kind of approximation there is no way to rewrite \(\displaystyle ln(m - n)\) in general.
-Dan
@Llwewllyn:
-Dan
Send me to the woodshed! I misplaced my parentheses.
You mean
\(\displaystyle \ln(m-n) \neq \ln \left( \dfrac{m}{n} \right) = \dfrac{\ln m}{\ln n}\)
Olinguito said:
You mean
Or rather \(\displaystyle \ln(m-n) \neq \ln \left( \dfrac{m}{n} \right) \neq \dfrac{\ln m}{\ln n}\)
-Dan
1. What is the ratio of a/b when lna/lnb=x?
The ratio of a/b when lna/lnb=x is equal to b^x/a^x, where a and b are positive real numbers.
2. How is the ratio of a/b affected by the value of x in lna/lnb=x?
The value of x in lna/lnb=x directly affects the ratio of a/b. As x increases, the ratio also increases, and as x decreases, the ratio decreases.
3. Can the ratio of a/b be negative when lna/lnb=x?
No, the ratio of a/b cannot be negative when lna/lnb=x. Both a and b are positive real numbers, so their exponents will always result in a positive value.
4. How does the ratio of a/b change when the values of a and b are altered?
The ratio of a/b will change when the values of a and b are altered. As a increases and b decreases, the ratio will increase, and vice versa.
5. Is the ratio of a/b affected by the base of the logarithm in lna/lnb=x?
No, the ratio of a/b is not affected by the base of the logarithm in lna/lnb=x. As long as the base is the same for both a and b, the ratio will remain the same.
  • General Math
