How Much Heat Evolves in the Reaction of 2-Propanol to Acetone?
  • Thread starter predentalgirl1
  • Tags
    Reaction
In summary: Therefore, the acetone may not be as concentrated as it would be at sea level. In summary, the conversation discusses the calculations involved in determining the heat evolved and mole ratios of acetone and water in a liquid product mixture. It also explains how the partial pressure of water and acetone can be calculated and how the boiling point of the mixture can be affected by factors such as altitude.
predentalgirl1
67
Just basically need my answers looked over and checked. Thanks.
(a) If we started with 1 mL of 2-propanol and reacted it all to form acetone then approximately how much heat should evolve (use DH°= -117 kJ/mol, and density of 2-propanol= 0.789 g/mL)?
Answer:-
Molar mass of 2-propanol=60.10 g/mol
Density=mass/volume
Mass=0.789 x 1=0.789g
No. of moles of 2-propanol=0.789/60.10=0.0131moles
Heat evolved= 0.0131 x -117= - 1.535 kJ
(b) If there were 5 mL of water (density = 1g/mL) mixed with the 1 mL of 2-propanol and all of the propanol formed acetone what is the mole ratio of acetone (Xl, a) and of water (Xl, w) in the liquid product mixture?
Answer;-
Mass of water= 5g
Molar mass of water= 18.016 g/mole
No.of moles of water=5/18.016=0.278 moles
mole ratio of acetone (Xl, a) and of water (Xl, w)= 0.278/0.0131=21.19
c) Given the pressure of 765 mm Hg and at an experimental boiling point of the mixture of Tboil = 70° C, we find the vapor pressure of pure water (P°w) from a table to be 233.7 mm Hg. What is the partial pressure of water (Pw) above the mixture at Tboil?
Answer:-
Mole fraction of water= 0.278/21.19= 0.0131
partial pressure of water= vapor pressure of pure water x mole fraction of water
= 233.7x0.0131 =3.06mm Hg
(d) From part c) what is the partial pressure of acetone (Pa) and what is the mole ratio of acetone in the vapor phase above the mixture at Tboil?
Answer:-
Vapour pressure of acetone =1191.55mmHg
No. of moles of acetone=0.789/60.10=0.0131moles
Mole fraction of = 0.0131/21.19=6.181x 10-4
Partial fraction of acetone = 1191.55x6.181x 10-4=0.736mmHg
(e) Correspondingly what is the expected mole ratio of the distillate upon collecting the first few drops and does this show more or less concentration of the acetone?
Answer:-
Mole ratio= mole fraction of acetone/mole fraction of water=6.181x 10-4/0.0131
= 0.047
(f) What would happen to Tboil if we were to do the distillation at the top of a mountain?
Answer;-
Tboil will be lower at the top of a mountain, where the atmospheric pressure is less.
This means that the boiling point of the mixture will decrease, potentially resulting in a lower concentration of acetone in the distillate.
This is because boiling point is directly proportional to atmospheric pressure. As the pressure decreases, the boiling point decreases as well.
What are reaction problems?
Reaction problems are mathematical problems that involve balancing chemical equations and calculating the quantities of substances involved in a chemical reaction.
Why are reaction problems important?
Reaction problems are important because they allow us to understand and predict the outcomes of chemical reactions. This knowledge is crucial in fields such as medicine, environmental science, and materials science.
What are the steps for solving a reaction problem?
The steps for solving a reaction problem are:
1. Write the balanced chemical equation
2. Determine the known and unknown quantities
3. Convert the known quantities to moles
4. Use the mole ratio from the balanced equation to calculate the unknown quantity
5. Convert the result back to the desired units, if necessary.
What are some common types of reaction problems?
Some common types of reaction problems include stoichiometry problems, limiting reactant problems, and percent yield problems. These all involve different aspects of balancing equations and calculating quantities in chemical reactions.
What are some tips for solving reaction problems?
Some tips for solving reaction problems include:
- Always start by writing a balanced chemical equation
- Pay attention to units and make sure to convert to the desired units
- Double check your calculations and make sure they make sense
- Practice, practice, practice! The more you solve reaction problems, the easier they will become.
