Balint Kovats
- 4
- 0
Dear friends I am new at this forum thank you for accepting my application first of all.
My question is that I don't understand the optics/physics behind the reason why Si-based CCDs are not sensitive for IR-light (above 1000-1100 nm) if on the top of the p-type Si there is a SiO2 layer which has a refractive index of 1.449 at 1100 nm wavelength. Taking into consideration that EM waves entering into a new medium because of their frequency is constant their wavelenght and speed will change can we calculate in this way: wavelength = speed of light in vacuum/frequency >> frequency = speed of light in vacuum/wavelength in our case f = 3*10^8[m/s]/1100*10^-9[m] = 2,73*10^14 [1/s] and as written in this post (https://www.physicsforums.com/threads/changing-wavelength-of-light-ps-hello.1833/) new wavelength in the new medium = speed of light in vacuum/frequency*refraction index >> new wavelength in the new medium = 3*10^8[m/s]/2,73*10^14[1/s]*1,449 = 7,58*10^-7 [m] = 758 [nm] There we go: if the Si is perfectly coated with SiO2 layer why isn't the incoming IR-light impacting the surface of the Si at 758 nm wavelength and so it should generate photoelectric effects and the CCD should be sensitive for that range too. Can anyone explain this? Is there something wrong with my knowledge about CCD manufacturing or the basic optical principles?
Thank you very much
Thank you very much
