- #36
mattt
- 298
- 123
Philip Wood said:I'm certainly not saying that doing Physics in a rotating frame is invalid! Nor am I saying that one observer is right and the other wrong.
I'm merely trying to understand how to interpret the equation you write as
[tex]\left( \frac{d \vec q}{d t}\right)_A = \left( \frac{d \vec q}{d t}\right)_B +\ \vec \omega \times \vec q.[/tex]
I'm arguing that [itex]\left( \frac{d \vec q}{d t}\right)_B [/itex] is only a 'partial' derivative of the vector [itex]\vec q[/itex] because it treats the unit vectors in the rotating (B) frame (rotating with the frame) as constants.
I don't know how to explain it without differential geometry concepts. But I'll try.
What you call "the (total in your wording, I guess) derivative of a vector" is in reality the coordinate expression of a certain geometric object with respect to that coordinate frame
The same object will have different coordinates in different frames.
For each frame, the derivative of that vector is just the usual derivative of its escalar components.
For example, if [tex]\vec{q}(t) = (x(t),y(t),z(t))[/tex] for a given observer, then [tex]\frac{d\vec{q}(t)}{dt} = (x'(t), y'(t), z'(t))[/tex] for this observer.
For another different observer, the same vector may have the expression [tex]\vec{q}(t) = (a(t),b(t),c(t))[/tex], then [tex]\frac{d\vec{q}(t)}{dt} = (a'(t), b'(t), c'(t))[/tex] for this other observer.
These two sets of coordinates can be much more general than the usual components with respect to an orthonormal vector basis. But for simplicity let us restric to the especial case where [tex](x(t), y(t), z(t))[/tex] means
[tex]x(t)\vec{i} + y(t)\vec{j} + z(t)\vec{k}[/tex]
where [tex]\vec{i} , \vec{j}, \vec{k}[/tex] is an orthonormal basis.
And the same with
[tex]a(t)\vec{m} + b(t)\vec{n} + c(t)\vec{p}[/tex]
where [tex]\vec{m} , \vec{n}, \vec{p}[/tex] is another orthonormal basis.
So that for one observer it is
[tex]\frac{d\vec{q}(t)}{dt} = x'(t)\vec{i} + y'(t)\vec{j} + z'(t)\vec{k}[/tex]
and for the other observer it is
[tex]\frac{d\vec{q}(t)}{dt} = a'(t)\vec{m} + b'(t)\vec{n} + c'(t)\vec{p}[/tex]
Obviously I am just stating how it works. To be able to know why it is this way, you'd need to know some differential geometry concepts.
The second term on the right is the 'missing' part of the B-frame derivative that takes account of the rotation (non-constancy) of the unit vectors. See footnote.
No. In fact, from the point of view of B, it is A who is rotating with -w angular velocity. So if you make the exact same reasoning, but from B point of view, you will get to
[tex]\left( \frac{d \vec q}{d t}\right)_B = \left( \frac{d \vec q}{d t}\right)_A +\ (-\vec{\omega}) \times \vec q.[/tex]
On the left hand side, there is only one term, [itex]\left( \frac{d \vec q}{d t}\right)_A [/itex] because in the inertial frame the unit vectors are constants. So [itex]\left( \frac{d \vec q}{d t}\right)_A [/itex] is a genuine, complete, derivative of [itex]\vec q[/itex].
Footnote
Mathematically, what I'm saying in the paragraph under the equation is that the 'complete' derivative of [itex]\vec q[/itex] expressed in terms of the rotating unit vectors of the 'B' frame is
[tex]\frac{d}{dt}\left(q_x \hat {\vec x}+ q_y \hat {\vec y}+ q_z \hat {\vec z}\right)[/tex]
in which [itex]q_x, q_y, q_z [/itex] are (scalar) components of [itex]\vec q[/itex] on the rotating unit vector set [itex]\hat {\vec x}, \hat {\vec y}, \hat {\vec z}[/itex].
Differentiating each term in the last equation as a product, and re-assembling:
[tex]\frac{d q_x}{dt} \hat {\vec x}+ \frac{d q_y}{dt} \hat {\vec y}+\frac{d q_z}{dt} \hat {\vec z} \ +\ q_x \frac{d \hat {\vec x}}{dt}+q_y \frac{d \hat {\vec y}}{dt}+q_z \frac{d \hat {\vec z}}{dt} \ \ \ = \ \ \ \left( \frac{d \vec q}{d t}\right)_B \ + \ \vec{\omega} \times \vec{q}[/tex]
In the last step I've identified the sum of the first three terms with your [itex]\left( \frac{d \vec q}{d t}\right)_B [/itex], (what Lanczos calls [itex]\frac{d' \mathbf q}{dt}[/itex]), and the last three terms with [itex]\vec{\omega} \times \vec{q}[/itex]. The latter can easily be justified.
You can do exactly the same from B point of view.
I know it may be difficult to grasp it without the proper differential geometry concepts, and in fact I have not explained why it is the way it is, I just stated how it is.
I have to go now, I'll try more later if I have time. :-)
