member 529879
what is the cause of the centrifugal force from the perspective of the rotating observer? Also is rotation relative like linear motion?
Rotation is not relative. You can unambiguously determine how fast a reference frame is rotating without reference to any other frame. For example, you can use a gimbaled gyroscope or a ring interferometer.OldEngr63 said:Yes, rotation is relative like linear motion.
Rotation is the circular movement of an object around a central axis or point.
Centrifugal force is the apparent outward force on an object that is moving in a circular path. It is caused by the inertia of the object trying to resist the change in direction.
The faster an object rotates, the greater the centrifugal force acting on it. This is because the centrifugal force is directly proportional to the square of the rotational speed.
Centripetal force is the inward force that keeps an object moving in a circular path, while centrifugal force is the outward force that appears to be acting on the object due to its rotation.
Some examples include the rotation of the Earth around its axis causing the centrifugal force experienced as gravity, the rotation of a bicycle wheel causing the centrifugal force that keeps the bike balanced, and the rotation of a washing machine during the spin cycle causing the clothes to be pushed against the sides of the drum due to centrifugal force.
