MHB Simplification of an equation based on exponent rules
  • Thread starter Thread starter ATroelstein
    Exponent Rules
The equation presented for simplification is $$\frac{5 + \sqrt{5}}{2\sqrt{5}}*(\frac{1 + \sqrt{5}}{2})^{x}$$. It can be simplified to $$\left(\frac{1 + \sqrt{5}}{2}\right)^{x+1}$$ by recognizing that $$\frac{5 + \sqrt{5}}{2\sqrt{5}}$$ simplifies to $$\frac{1 + \sqrt{5}}{2}$$. The discussion emphasizes the importance of terminology, noting that the expression is not an equation since it lacks an equality sign. Additionally, it suggests factoring the numerator to facilitate cancellation with the denominator. The overall conclusion is that the expression can indeed be simplified as initially suspected.
ATroelstein
I have the following equation that I'm trying to simplify:
From looking at it, it seems like it could be simplified so that the right-hand side of the multiplication would be:
$$(\frac{1 + \sqrt{5}}{2})^{x+1}
I started to pull the left-hand side apart to get a match to the right-hand side and ended up with:
(\frac{4}{2\sqrt{5}} + \frac{1}{\sqrt{5}} * \frac{1+\sqrt{5}}{2}) * (\frac{1 + \sqrt{5}}{2})^{x}
From here, I'm starting to wonder if my initial observation was flawed. Is there a way to simplify this is terms of:
Thanks.
Mathematics news on Phys.org
$ \displaystyle \frac{5 + \sqrt{5}}{2 \sqrt{5}}$ = $\displaystyle \frac{1 + \sqrt{5}}{2}$ by multiplying numerator and the denominator by $$\sqrt{5}$$
Hence, the multiplication of it with $$\left ( \frac{1 + \sqrt{5}}{2} \right )^x$$ is equal to $$\left ( \frac{1 + \sqrt{5}}{2} \right )^{x+1}$$
First, I want to say that what you have is an expression, not an equation. An equation gives the equality between two expressions, and is identified by the use of the "=" sign. I have seen many student confuse the two terms. :D
This may seem like a trivial point to make, but in order to be able to communicate effectively in any subject, the correct use of terminology is crucial.
Your expression consists ot two factors. Look at the factor on the left:
$$\frac{5+\sqrt{5}}{2\sqrt{5}}$$
Can you factor the numerator, so that you may cancel with a factor in the denominator?
I now see I have been pipped at the post, but do you see how mathbalarka simplified the factor on the left?
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
