Statistical Mechanics Part II: The Ideal Gas - Comments
In summary: The choice of the natural phase-space volume to be able to define phase-space distribution functions has been the greatest enigma for Maxwell and Boltzmann when formulating classical statistical theory.This is resolved by quantum theory, which implies that the single-particle phase-space-cell measure indeed is h^3=(2πℏh=2πℏh=2\pi \hbar). Indeed to establish statistical mechanics, you have to define a phase-space distribution function for a single particle f(t,\vec{x},\vec{p}) which must have the dimension of inverse action cubed, because that's the dimension of phase-space volume \mathrm{d}
241
Greg Bernhardt submitted a new PF Insights post
Continue reading the Original PF Insights Post.
Likes Nguyen Son, thierrykauf, Doc Al and 5 others
Another example of an Insight that made me a real fan of this PF feature. Is it the practice here or the special mentality, that makes them readable in a way, that all crucial keywords are mentioned and the explanation is still somewhere above the boring of a textbook and the out-of-context of a Wiki article, i.e. close to what an actual lecture would be. Absolute an appetizer for non specialists like me!
I wonder if it were possible to make an index of all of them.
Likes NFuller and Greg Bernhardt
Great article!
I haven’t read much about Stat Mech in over forty years. I think we used only one ensemble in our undergrad coursework.
Your article was very insightful. Thanks!
Likes NFuller
I think it should be mentioned that here tacitly the Bose distribution was used to count the states without giving the argument for why to use Planck's constant ##h=2\pi \hbar##, which is of course a measure of phase space not spatial volume.
That's definitely not the way Boltzmann did it. Of course, it's correct, but the classical result comes from doing a rather tough approximation using Stirlings formula, which is in fact a bit tricky anyway. Another problem is that in the given expression of the entropy there are dimensionful quantities as arguments in logarithms. This should be corrected. Otherwise it's a very nice derivation in the microcanonical ensemble.
For a treatment (however in the context of kinetic theory), see section 1.8 of
https://th.physik.uni-frankfurt.de/~hees/publ/kolkata.pdf
Likes Nguyen Son and NFuller
Greg Bernhardt said:
Great work! Will there be a part 3?
Yes, I intend to do a few more parts as time permits.
Likes jedishrfu, fresh_42 and Greg Bernhardt
vanhees71 said:
I think it should be mentioned that here tacitly the Bose distribution was used to count the states without giving the argument for why to use Planck's constant h=2πℏh=2πℏh=2\pi \hbar, which is of course a measure of phase space not spatial volume.
You're right that I never proved that using Planck's constant yields the correct discritization of the space space. Rather, I assumed it a priori as a reasonable guess which yields the right answer. It's also true that dividing the volume by Planck's constant doesn't really mean anything physical on its own. The point is to discritize the phase space and tacking on the ##h^{3}## term accomplishes this in an intuitive, although not exactly correct, way.
Are you referring to the logarithms after applying Stirling's approximation?
It's not "space space" (I guess you mean "configuration space") but "phase space" that's to be divided into cells of the size ##(2 \pi \hbar)^{3f}##!
For the case of an ideal gas, it's easily derived by solving the problem for the single-particle phase space. See my kinetic-theory manuscript for that:
And yes, there are logarithms with dimensionful quantities in their arguments. As far as I can see you can very easily repair it by taking the logarithms together since I think the formulae are in principle right!
Yes, that was a typo.
These should be fixed now. I was originally doing the derivation with dimensionless variables but then later switched to dimensionful variables, but forgot to change this in the article.
Likes vanhees71 and Greg Bernhardt
Now it's better. Only in the third-last formula you should again combine the two ln terms :-).
Likes NFuller
NFuller said:
The point is to discritize the phase space and tacking on the h3h^{3} term accomplishes this in an intuitive, although not exactly correct, way.
Why is it intuitive? Is the assertion that h-bar is a reasonable lower bound based on uncertainty, and because there are three dimensions in the volume it needs to be cubed?
First of all, phase space is not descritized in quantum theory. Second, the choice of the natural phase-space volume to be able to define phase-space distribution functions has been the greatest enigma for Maxwell and Boltzmann when formulating classical statistical theory.
Quantum theory resolves this problem without further thought since it implies that the single-particle phase-space-cell measure indeed is ##h^3=(2 \pi \hbar)^3##. Indeed to establish statistical mechanics, you have to define a phase-space distribution function for a single particle ##f(t,\vec{x},\vec{p})## which must have the dimension of inverse action cubed, because that's the dimension of phase-space volume ##\mathrm{d}^3 x \mathrm{d}^3 p##.
Now suppose you have a particle in a spatial volume ##\mathrm{d}^3 x##. Then imposing periodic boundary conditions you find that there are ##\mathrm{d}^3 x \mathrm{d}^3 p/(2 \pi \hbar)^3## quantum states. This implies that the phase-space distribution function has to be normalized such that
$$\int_{\mathbb{R}^3} \mathrm{d}^3 x \int_{\mathbb{R}^3} \mathrm{d}^3 p \frac{1}{(2 \pi \hbar)^3} f(t,\vec{x},\vec{p})=1,$$
i.e., QT uniquely defines the appropriate single-particle phase-space measure as ##(2 \pi \hbar)^3##. For details see
Related to Statistical Mechanics Part II: The Ideal Gas - Comments
1. What is the ideal gas law and how does it relate to statistical mechanics?
The ideal gas law is a fundamental equation in thermodynamics that describes the relationship between the pressure, volume, and temperature of a gas. It can be derived from statistical mechanics by considering a large number of gas molecules in a container and assuming that they behave as point particles with no interactions between them. This allows for the prediction of the macroscopic properties of a gas, such as pressure and volume, from the microscopic behavior of its individual molecules.
2. How is the ideal gas law different from real gases?
Real gases do not perfectly follow the ideal gas law because they have interactions between molecules and take up space. These factors can affect the behavior of the gas and lead to deviations from the ideal gas law. However, under certain conditions, real gases can approximate the behavior of an ideal gas.
3. What is the Maxwell-Boltzmann distribution and how is it used in statistical mechanics?
The Maxwell-Boltzmann distribution is a probability distribution that describes the speeds of particles in a gas. In statistical mechanics, it is used to calculate the average kinetic energy of a gas and to determine the most probable speed of the gas molecules.
4. How does statistical mechanics explain the properties of an ideal gas?
Statistical mechanics uses the principles of thermodynamics and the behavior of individual gas molecules to explain the macroscopic properties of an ideal gas, such as pressure, volume, and temperature. By considering a large number of particles and their interactions, statistical mechanics can predict the behavior of an ideal gas and explain its properties.
5. What are some real-world applications of statistical mechanics in understanding ideal gases?
Statistical mechanics has many practical applications, such as in the study of gas mixtures, diffusion, and phase transitions. It is also used in the design of industrial processes, such as the production of gases for various applications. Additionally, statistical mechanics plays a crucial role in understanding the behavior of gases in various environments, such as in combustion engines and the Earth's atmosphere.
12K
21K
