Story behind imaginary numbers
In summary, Eric thinks that the acceptance of imaginary numbers was gradual, starting with the solution to cubic equations. The term "imaginary" was originally used to avoid the negative connotation of "complex number".
thejinx0r
27
Hey Guys,
I am looking for a book that talks about the history of imaginary numbers and how people came to need it.
I'm just having trouble imagining how people could have accepted imaginary numbers before negative numbers (at least in the western world).
Thank you,
Eric
P.S.
If there's a book that reads like a novel, it would be better :)
Imaginary numbers first appeared on the stage in the 16th century, as quantities that could formally be manipulated when solving cubic equations.
I have looked a bit about, the following book be Paul Nahin: "An imaginary tale" seems to be something you might trry out 8haven't read it myself).
A warning, however:
Quite a few of the negative reviews at amazon.com says it is "too heavy" on the maths, I hope that won't scare you away.
https://www.amazon.com/dp/0691127980/?tag=pfamazon01-20
I thought that both began to 'widespread' acceptance at the same time -- with the method solution to cubic equations.
A warning, however:
Cool, will check it out.
I just hate how they called it imaginary and how people truly believe that you cannot "imaginary" numbers in forced damped oscillators
:S
True, but from what I recall, for the quadratic, they always rewrote the equations such that there were only positive terms in there. So there were 4 different equations for solving the quadratic.
Then when they realized that imaginary numbers had a negative inside, they found it easier to accept that a negative because there were no way of having the sqrt of a positive number equal to i.
But anyways, I'm just studying for my Algebra class now and was thinking about it when I was doing quotient rings.
So there must have been another period in time where imaginary numbers were developed independently of solving the cubic equation, although I am in the part that says "every polynomial has a root in a bigger field". So maybe that was the only time where imaginary first came up.
We have Gauss to think for pushing the term "complex number", in his efforts to avoid this connotation. Alas, he was unsuccessful with his attempt to push the term "lateral part" as a replacement for "imaginary part". :frown:
I know negative numbers have been around since antiquity. I'm pretty sure the beginnings of the idea of complex number had been around a long time too; I have vague recollections of people playing with ways to represent solutions of quadratic equations that didn't have real roots; something with circles, I think. (The center worked out to being the real part, and radius to the imaginary part, I think)
Related to Story behind imaginary numbers
1. What are imaginary numbers?
Imaginary numbers are numbers that, when squared, give a negative result. They are represented by the letter "i" and are used to solve equations that have no real solutions.
2. Why are they called "imaginary"?
They are called imaginary because they were originally thought to be "imaginary" or non-existent. However, they have since been proven to be useful in solving mathematical equations and are now an accepted part of mathematics.
3. What is the story behind the discovery of imaginary numbers?
The concept of imaginary numbers was first introduced by Italian mathematician Girolamo Cardano in the 16th century. However, it was not until the 18th century that Swiss mathematician Leonhard Euler fully developed the concept and coined the term "imaginary".
4. How are imaginary numbers used in real life?
Imaginary numbers are used in many fields, including engineering, physics, and economics. They are used to solve equations that have no real solutions, such as in alternating current circuits, signal processing, and financial modeling.
5. Can imaginary numbers be graphed on a number line?
No, imaginary numbers cannot be graphed on a traditional number line because they represent a different type of number. However, they can be graphed on a complex plane, where the real numbers are represented on the x-axis and the imaginary numbers are represented on the y-axis.
  • Topology and Analysis
  • Quantum Physics
Writing: Input Wanted Number of Androids on Spaceships
  • General Math
  • Linear and Abstract Algebra
  • Art, Music, History, and Linguistics
  • Quantum Interpretations and Foundations
