System of linear inequalities
In summary: We can see that the solution set is contained within the interval [0,41). In summary, if you work a total of 41 hours each week at your two jobs, you'll be able to pay your bills.
rebo1984
You can work a total of no more than 41 hours each week at your two
jobs. Housecleaning pays \$6 per hour and your sales job pays \$9 per hour. You
need to earn at least \$252 each week to pay your bills.
Are the answers:
x+y\le 41
6x+9y\ge252
How would you solve this?
Thanks
Mathematics news on Phys.org
To solve a system of linear inequalities, such as the system we have here:
\(\displaystyle x+y\le41\)
\(\displaystyle 2x+3y\ge84\) (I divided through by 3 to make the numbers smaller)
We observe that the variables represent the number of hours worked, and so we are only interested in non-negative values, so our solution set will be in quadrant I, or along the positive axes.
We begin with the first inequality and consider the equation:
\(\displaystyle x+y=41\)
This line will be the boundary of the solution set of the inequality. To plot the graphs of a line, I like to arrange it in slope-intercept form $y=mx+b$:
\(\displaystyle y=-x+41\)
We immediately see the point $(0,41)$ is on the line. Plot that point. Now, since the slope is -1, we may go one unit to the right and one unit down to the point $(1,40)$. Plot that point, and since the inequality is a weak one, we plot the solid line passing through the two points we plotted.
Now, to see which side of the line the solution set exists, we check a point not on the line to see if it satisfies the inequality or not. It if satisfies the inequality, then we know the solution set is on the same side of the line as our test point. Let's use the origin $(0,0)$...
\(\displaystyle 0+0\le41\)
\(\displaystyle 0\le41\quad\checkmark\)
This point satisfies the inequality, so we shade underneath the line in the first quadrant up to and including the positive axes:
[DESMOS=-3.332076962397118,46.32304769391533,-4.665236823966467,44.98988783234599]x+y\le41\left\{0\le x\right\}\left\{0\le y\right\}[/DESMOS]
Okay for the second inequality, we write the equation:
\(\displaystyle 2x+3y=84\)
Write in slope-intercept form:
\(\displaystyle y=-\frac{2}{3}x+28\)
Plot the $y$-intercept $(0,28)$, then move three units to the right and two units down to the point $(2,25)$ and plot that point, then connect those points with a solid line (weak inequality) and extend them to the positive axes. We'll use the origin again as our test point:
\(\displaystyle 2(0)+3(0)\ge84\)
\(\displaystyle 0\ge84\quad\xcancel{\checkmark}\)
This point does not satisfy the inequality, so we shade above the line:
[DESMOS=-2.1314516419265574,44.60278332872047,-9.23991795329183,37.49431701735519]2x+3y\ge84\left\{0\le x\right\}\left\{0\le y\right\}[/DESMOS]
We are interested in the set of points that satisfy both inequalities simultaneously, so our plot becomes:
[DESMOS=-1,40,-1,42]0\le x\left\{2x+3y\ge84\right\}\left\{x+y\le41\right\}[/DESMOS]
What is a system of linear inequalities?
A system of linear inequalities is a set of two or more linear inequalities involving the same set of variables. These inequalities can be graphed to form a shaded region on a coordinate plane.
How do you solve a system of linear inequalities?
To solve a system of linear inequalities, you can use the substitution method or the elimination method. Both methods involve manipulating the equations to eliminate one variable and solve for the other.
What does a solution to a system of linear inequalities represent?
A solution to a system of linear inequalities represents the values of the variables that make all of the inequalities in the system true. This solution is usually a shaded region on a coordinate plane.
Can a system of linear inequalities have more than one solution?
Yes, a system of linear inequalities can have infinite solutions. This means that there are many different combinations of values for the variables that satisfy all of the inequalities in the system.
How is a system of linear inequalities used in real life?
Systems of linear inequalities are used in real life to model and solve various problems, such as determining the minimum and maximum values of a product to maximize profit or finding the best combination of ingredients to create a recipe within a certain budget. They are also commonly used in economics, engineering, and other fields to make predictions and analyze data.
  • General Math
  • General Math
  • General Math
  • General Math
