Torque and rotational kinetic energy
The discussion revolves around the calculation of torque and rotational kinetic energy for a rock attached to a string. The torque required was calculated using τ=Iα, yielding 2.8 Nm, while the rotational kinetic energy formula E_k=1/2 Iω^2 gave a result of 177 Nm. The discrepancy arises because torque and kinetic energy, despite sharing units, represent different physical concepts; torque is not a measure of energy. It was clarified that while the rotational kinetic energy formula can be used to determine the energy of the system, it does not equate to the torque applied during acceleration. The relationship between kinetic energy and angular momentum was also discussed, confirming that the energy used to bring the rock to its current rotation can be calculated accurately.
BERNIE649
This is problem from a textbook whose solution I don't understand.
A small rock of mass 0.5kg is attached to a 1.5m string, then it is whirled for 5 seconds until it achieves a near horizontal orbit at 120 rpm. What is the torque required?
I used the equation : τ=Iα (moment of inertia x angular acceleration) giving an answer of 2.8 Nm or Joules. This is the book's answer.
My question is, why I don't get the same answer with the formula for rotational kinetic energy
E_k=1/2 Iω^2 which gives 177 Nm.
Both formulas have the same units of Nm or energy. Why the energy used to impart the motion is not the same as the kinetic energy stored in the moving mass?
From the point of view of units, both torque and kinetic energic carry the Nm tag. However, their meanings are vastly different; that´s why an energy is given in Joules and a torque in Nm. You've just compared apples to oranges
Torque isn't exactly a measure of energy. While the two quantities have the same dimensions, they aren't obtained in the same way: radians are treated as dimensionless, so ω2 has dimensions [T]-2, which happens to coincide with the dimensions of dω/dt = α
To illustrate the difference, consider a wheel spinning at a constant rate. The rotational kinetic energy is non-zero, but there is no torque on the wheel (so the torque is zero).
Thank you Cauchyam and Gordianus for your help.
I still have some questions. In the problem in question supposing the mass continues swinging around with no friction. If I want to calculate its energy, is it correct to apply the rotational kinetic energy formula, and would also be valid to say that that was the same amount of energy used to bring it from rest to its current rotation?
Yes
Correct.
And here you can see the relation between kinetic energy and angular momentum: The 2.8Nm were applied while the rock made 5 rotations* with a total angle of 10pi. And 2.8Nm*10pi=88J. I get the same value for the kinetic energy.
* 0/s at t=0, 2/s at t=5s, with constant acceleration, gives 5 rotations
Thank you mfb.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
