What is the derivative of velocity with respect to position?
In summary, the conversation discusses the use of the Euler-Lagrange equation in Classical Mechanics and the misunderstanding of taking the derivative of velocity with respect to position. It is clarified that the Lagrangian is initially analyzed as an abstract function of dynamic variables and the Euler-Lagrange equation describes how these quantities are related for a specific trajectory. The example of a free particle is used to illustrate this concept.
polytheneman
I'm reading a book on Classical Mechanics (No Nonsense Classical Mechanics) and one particular section has me a bit puzzled. The author is using the Euler-Lagrange equation to calculate the equation of motion for a system which has the Lagrangian shown in figure 1. The process can be seen in figure 2. What I don't understand is this:
He seems to consider that the partial derivative of (dx/dt)2 with respect to x is zero. Same thing for the partial derivative of x2 with respect to dx/dt. This doesn't seem obvious to me and I haven't found any explanations elsewhere. Why is it so?
Looks like derivatives are assumed to commute: d(dx/dt)/dx=d(dx/dx)/dt.
However, if position is a function of time, it does seem meaningful to ask how the velocity is changing from one position to the next. To take it as saying velocity is not changing with position is problematic, since velocity usually does change with position. For any position-dependent force, d^2(x)/dt^2 is a function of x:
d^2(x)/dt^2=f(x) -> dx/dt = ∫f(x)dt = ∫f(x)(dt/dx)dx = v(x)
so to make sense of this you need t(x) to evaluate (dt/dx), which is not always a function
But it is odd that d(dx/dt)/dx=0 implies that velocity is constant with position. Can anybody correct/explain?
edit: differential operators do not, in general, commute, so if it is not a mistake in the text, then there is some special condition that makes it so.
Likes polytheneman
In Lagrangian mechanics, position and velocity are independent variables.
Likes polytheneman
vela said:
In the Lagrangian mechanics, position and velocity are independent variables.
Thanks for clearing that up. However, you can have a particle modeled by a Lagrangian which differs in velocity along the positions of the motion, correct?
Likes polytheneman
polytheneman said:
Summary:: What can I expect to get if I take the derivative of velocity with respect to position? Is it zero?
This is a common misunderstanding. The Lagrangian is initially analysed as an abstract function of the dynamic variables. In which case, ##x## and ##\dot x## are taken to be two abstract independent variables and the functional format of the Lagrangian is analysed.
The Euler-Lagrange equation then specifies how these abstract quantities are related for the specific trajectory of a particle in this system.
This is done by assuming that the action is stationary for an actual trajectory. This is known as the Lagrangian principle and can be shown to be equivalent to Newton's laws. The principle is, however, much more generally and widely applicable than Newton.
Either your textbook failed to say any of this or you just skimmed past it!
Likes polytheneman
To see what is being done here, let's take the simple example of a free particle. We have a formula for the kinetic energy:
##T = \frac 1 2 m \dot{x}^2##
Now, if you do a normal time differentiation of that equation you get:
##\frac{dT}{dt} = m \dot x \ddot x = 0##
Which follows from Newton's second law.
But, the Lagrangian approach takes ##T = \frac 1 2 m \dot{x}^2## as an equation relating the KE to the variable ##\dot x##. You could draw a graph of this function. You could also ask what is the gradient of this function? To calculate this you would treat ##\dot x## simply as a variable upon which ##T## depends:
##\frac{dT}{d\dot x} = m\dot x##
And, we recognise the RHS as the momentum of a particle. This formal derivative of ##T## with respect to the variable ##\dot x## has thrown up the form of a recognisable quantity.
The Euler-Lagrange equation then describes how the quantities obtained by this process of formal differentiation are related for a particle on a real trajectory - i.e. one that could have been obtained from the Newtonian equations of motion, say. In this simple case, Euler -Lagrange implies that:
##\frac{d}{dt}(\frac{dT}{d\dot x}) = \frac{d}{dt}(m\dot x) = 0##
(This is back to normal time differentiation now.)
And so Euler-Lagrange simply recovers Newton's second law for a free particle: ##m \ddot x = 0##. But, in this case, Newton's second law arose from looking at the way the kinetic energy, ##T##, functionally depended on the dynamic variable ##\dot x##.
Likes jk_er_gamma
If I understand this correctly, you're saying that for a free particle, there is no change in T (and thus no change in dx/dt).
But what about the problem indicates that it was a free particle? Was it that the Lagrangian included (dx/dt)^2?
I'm not sure what you're asking here.
I'm imagining that you start with the assumption that there is an equation of motion (1-dimensional) x(t). Then,
at every point on the graph of that function should be a derivative, the velocity, which you can graph as well. Since x(t) and v(t) have a common parameter of t, you can graph v against x. This graph is not always a horizontal line, so it could have tangents along the curve. The slope of those tangents would indicate nonzero derivative.
Yes, of course the velocity can change as the particle moves. If you start with the assumption of a specific trajectory ##x(t)##, then clearly ##x## and ##v## aren't independent. They're related through Newton's second law.
In Lagrangian mechanics, however, you do not start with the particle having a trajectory ##x(t)##. You're actually considering all possible combinations of position and velocity and then from that, finding the specific combination that minimizes the action. That specific combination turns out to be the one that satisfies Newton's second law.
Likes jk_er_gamma
vela said:
In Lagrangian mechanics, however, you do not start with the particle having a trajectory x(t)
Interesting. So that's what is meant by taking position and velocity as independent variables for this process.
So if it is zero then acceleration is 0?
What is the relevance of this to the rest of the thread?
Likes Vanadium 50
I had similar question in this thread. I got good answer that
Periwinkle said:
The $$ \frac {d} {dt} \frac {\partial L} {\partial \dot x } - \frac {\partial L} {\partial x} = 0$$ Lagrange equation is written using the following substitution (use the left-hand element to replace the right) $$ t \to t $$ $$ x(t) \to u $$ $$ \dot x(t) \to v. $$ Of course, the partial derivative of the Lagrange function cannot be taken by ## x(t) ## or ## \dot{x} (t) ##, because they are not independent variables. But the partial derivatives of ##u## and ##v## can be calculated for the function ##L (u, v, t)## and then replace it with ## x(t) ## and ## \dot{x} (t) ## as above.
Likes vanhees71 and PeroK
It's basically the same as one of the questions I was asking, and I think the main source of confusion.
I think PeroK was saying that it should be zero for a free particle, since there is no gain or loss of kinetic energy.
At certain steps in the process of examining functions of x and v, they are treated as separate variables and their co-dependence is ignored, since it is a property of functions used to find minimum action, not an analytical moving frame. That is why substituting in dx/dt for v can give confusing answers at certain points in the process.
Likes fisher garry
Related to What is the derivative of velocity with respect to position?
1. What is the meaning of "derivative of velocity with respect to position"?
The derivative of velocity with respect to position is a mathematical concept that represents the rate of change of velocity with respect to a change in position. It measures how much the velocity of an object changes as its position changes.
2. How is the derivative of velocity with respect to position calculated?
The derivative of velocity with respect to position is calculated by taking the derivative of the position function. This involves finding the slope of the tangent line to the position function at a specific point, which represents the instantaneous velocity at that point.
3. What is the physical interpretation of the derivative of velocity with respect to position?
The physical interpretation of the derivative of velocity with respect to position is acceleration. This is because the derivative measures the change in velocity over a change in position, which is the definition of acceleration.
4. How does the derivative of velocity with respect to position relate to motion?
The derivative of velocity with respect to position is a fundamental concept in the study of motion. It helps us understand how an object's velocity changes as it moves, and can be used to predict future motion based on current velocity and position.
5. Can the derivative of velocity with respect to position be negative?
Yes, the derivative of velocity with respect to position can be negative. This indicates that the object is slowing down, as the velocity is decreasing with respect to an increase in position. It can also be positive, indicating that the object is speeding up.
  • Mechanics
  • Mechanics
  • Mechanics
