Which has the most intense sunlight hitting it?
In summary: Recall that the summer solstice is when the Sun is at the highest point in the sky for the Northern hemisphere. So which location would have a higher angle/height of the Sun in the sky?In summary, the North Pole at Noon on the Summer Solstice would have the most intense sunlight hitting it, as the angle of incident rays would be higher compared to Montreal at Noon on the Spring Equinox.
shmijda
23
Which has the most intense sunlight hitting it?Question 2 options:
A point on the Equator at sunset
The North Pole at Noon on the Summer Solstace
The South Pole on the (Northern hemisphere) Summer Solstace
none
Ruled out first choice as it is at sunset.
Ruled out last choice as the South Pole does not receive much sunlight on the Summer Solstice
Stuck between choice 2 and 3.[/B]
What do you know about choices 2 & 3?
shmijda said:
none
That's where you went wrong. Intensity can be described numerically, and then applying what you know about the Sun position in each case is a key to the correct answer.
We were supposed to do this without looking at the intensity numerically, so how do I choose between 2 and 3?
How far above the ecliptic plane are the two locations at the times of the year stated in the question?
You can't answer the question without comparing angles. Angles are numbers.
You don't need to calculate the intensities, but you can reason mathematically which situation results in more intense sunlight. What determines how intense the sunlight is at noon?
The angle of incident rays? In this case I would say the north pole at noon
:headbang::headbang::headbang:
Are you just guessing? What's the angle between the incident rays and the normal at the North Pole on the summer solstice? You should be able to figure this out knowing the tilt of the Earth and the fact that the North Pole is at 90 degrees latitude.
What about for Montreal on the vernal equinox? If your answer is right, the Sun should be lower in the sky than it was for the North Pole on the summer solstice. Can you justify that?
for north pole on summer solstice - I got angle 66.6
for montreal on equinox - angle 45.5
Those look reasonable, so the Sun is lower in the sky in...
Montreal, thus North pole at noon on summer solstice is right?
Those angles are between the incident ray and the normal. Zero degrees would correspond to the Sun being directly overhead, and 90 degrees would be if the Sun were on the horizon.
1. Which location on Earth experiences the most intense sunlight?
The equator experiences the most intense sunlight on Earth, as it receives direct sunlight throughout the year due to its position in relation to the sun.
2. How is intensity of sunlight measured?
The intensity of sunlight is measured in watts per square meter (W/m²), which is the amount of solar energy that falls on a given area in a given time.
3. Does altitude affect the intensity of sunlight?
Yes, altitude can affect the intensity of sunlight. As altitude increases, the atmosphere becomes thinner and less sunlight is scattered or absorbed, resulting in higher intensity of sunlight.
4. Is the intensity of sunlight the same all over the world?
No, the intensity of sunlight can vary depending on factors such as latitude, altitude, and weather conditions. Locations closer to the equator generally experience higher intensity of sunlight compared to those closer to the poles.
5. How does the Earth's tilt affect the intensity of sunlight?
The Earth's tilt on its axis affects the intensity of sunlight by changing the angle at which sunlight hits different parts of the Earth. This results in varying levels of intensity throughout the year at different locations on Earth.
  • Astronomy and Astrophysics
