Why can't logs have a negative base?
In summary: There's no real answer. There are an infinite number of complex answers.The main problem with having a negative base in a logarithm is that it leads to complex numbers, which cannot be handled by a real function.
Rumplestiltskin
97
I understand that taking logs of a negative number isn't possible because no number to any power produces a negative number. But why not a negative base?
Say, log-10(100) = 2. Rewritten, -102 = 100, which is accurate.
You could suggest that you may as well just ignore the negative because -x2 = x2, but it's still weird that this shows up as a syntax error on a calculator.
Mathematics news on Phys.org
Try to calculate log-10(50)=x.
Or, alternatively, solve log-10(x)=1.7. What is x=(-10)1.7?
For integers (with the right sign) as logarithm values, it would work, but only for those.
No, it isn't. ##-10^2 = - 100## because the exponent has a higher precedence than the negation sign. What you probably meant was ##(-10)^2##, which is 100.
For the reason given above, ##-x^2 \ne x^2##, unless x happens to be 0. If you want to square a negative number on a calculator, put parentheses around the number, with the exponent outside the parentheses.
Moved from Homework sections, as this is more of a general question than a homework question. @Rumplestiltskin, be advised that if you post in the HW sections, youi need to use the homework template, not delete it as you apparently did.
You should be more careful regarding order of operations.
-102 = -100
and
-x2 = - (x2)
I assume you meant to write
(-10)2 = 100
and
(-x)2 = x2The main problem with having a negative base in a logarithm, is that there is a problem defining a real valued exponential function having a negative base.
Syntax error on calculator. When typed into google, (-10)1.7 = 29.4590465 - 40.5468989 i. Woah. Still at a loss.
Could you elaborate?
Syntax error on calculator. When typed into google, (-10)1.7 = 29.4590465 - 40.5468989 i. Woah. Still at a loss.Could you elaborate?
That's a complex number. Isn't that a problem for a real function?
Try (-10)π .
Related to Why can't logs have a negative base?
1. Why can't logs have a negative base?
Logs cannot have a negative base because the logarithmic function is defined as the inverse of the exponential function, and exponential functions can only have positive bases. Therefore, the base of a logarithmic function must also be positive.
2. What happens if a log has a negative base?
If a log has a negative base, it violates the definition of a logarithmic function and does not have a valid solution. This is because the domain of a logarithmic function is restricted to positive numbers only.
3. Can logarithms with negative bases exist in some cases?
No, logarithms with negative bases cannot exist in any case. The concept of a logarithm with a negative base goes against the fundamental properties and rules of logarithmic functions.
4. Why is it important to have a positive base in logarithmic functions?
A positive base is important in logarithmic functions because it ensures that the function has a unique and meaningful solution. It also allows us to use logarithmic functions in a variety of applications, such as calculating the rate of change or solving exponential equations.
5. Is there any other way to represent a logarithm with a negative base?
No, there is no other way to represent a logarithm with a negative base. If the base is negative, the logarithm is undefined and cannot be represented in any form. It is important to always use a positive base when working with logarithmic functions to avoid any mathematical errors.
  • General Math
  • General Math
  • Computing and Technology
