What is the Origin of the Term 'Prism'?
  • Thread starter NumFront
  • Tags
    Prism
In summary, the word "prism" comes from the Latin word "prisma" which means "something sawed". The word is used to refer to the triangular shape of a particular type of glass.
NumFront
Hello respected physics experts,
I want to ask why prism is called prism. Can you explain please?
Thanks.
Science news on Phys.org
Google for "prism etymology".
Likes pinball1970 and davenn
The word "prism" refers to the shape of a particular set of polyhedra and is not associated with glass, particularly.
Likes pinball1970
https://www.etymonline.com/word/prism
I have checked the etymology form this dictionary. The words "prism" comes from a Latin word "prisma" which means "something sawed".
I don't understand how this meaning ("something sawed") relates to a prism. Could you please expand on this meaning and explain what the dictionary refers to when it says "something sawed"? Which thing is sawed and how/why it is sawed?
Likes pinball1970
Freehanding a smooth plane with a mallet and a chisel, or just a hammer stone, is difficult on large surfaces.
A flattened copper strip with sand as an abrasive would saw stone surfaces, bronze strips with jagged teeth would saw wood. These surfaces would not necessarily be triangular, merely flat planes.
These perfect shapes were given their own description due to being obviously distinct from a chipped surface.
Common usage beginning in the 1500's gave the term its present day meaning of a sawn and polished glass triangle.
A shiny rainbow overwhelmed any previous meaning.
Note also that early texts on optics, natural science and mathematics were written and published in contemporary Latin. Many scholarly terms entered the vernacular from Latin and Greek. For example consider the origin of 'calculus', literally 'pebbles'. Small stones probably have the same relation to counting as the shape of an axe head or arrangement of teeth on a saw blade have to 'prism'.
Likes dextercioby and pinball1970
I think the relationship between "small stones" and "calculus" is a somewhat stronger relation. I believe the precursors to an abacus were a collection of pebbles, possibly followed by a flat piece of wood with the pebbles in grooves.
Likes Klystron and sophiecentaur
It is one of the partition pieces of the lost proof of the volume of a pyramid by Democritus.
And while we are it, why is a pyramid called pyramid?
Mi thinking is, lot at figures 9.4.3 and 9.5.1 of this book: https://books.google.es/books?id=ruRoDQAAQBAJ&pg=PA206&lpg=PA206&dq=yang+ma+volume+pyramid&source=bl&ots=CpXNwHQeKP&sig=ACfU3U0LsnS3D88pElOClvp7SDIjqmBSoQ&hl=es&sa=X&ved=2ahUKEwijxMndmsbjAhX86OAKHXfdAKsQ6AEwDXoECDcQAQ#v=onepage&q=yang ma volume pyramid&f=false
Or here: https://www.maa.org/book/export/html/842718
Clearly the prism is sawed from the pyramid, and also from wedge, in order to obtain recursive formulas for the volume. But on the other hand the chinese name for the prism is "moat wall", unrelated to this cut.
Likes Klystron and pinball1970
The projection of a one-dimensional object (a line) through a three-dimensional object (a solid), creates a two-dimensional object (a plane).
So "A saw cut is a flat surface".
The rest is linguistics history : good luck with that : it's pretty convolute.
calculus
Chalk is pretty easy to break into smaller pieces, then even smaller pieces, etc. ?
You can get various kinds of prisms by sawing rectangular cuboids. Maybe that's related to the origin of the term?
1. Why is a prism called a prism?
A prism is called a prism because of its geometric shape. It is a solid figure with two parallel and congruent polygonal bases that are connected by rectangular faces. This shape resembles the shape of a prism, which is a three-dimensional object with flat, rectangular sides.
2. What is the origin of the word "prism"?
The word "prism" comes from the Greek word "prisma," meaning "something sawed off" or "something with a sharp edge." This was a reference to the triangular shape of the ancient Greek prisms that were used for light refraction experiments.
3. How does a prism work?
A prism works by refracting, or bending, light as it passes through the different materials of the prism. This creates an effect called dispersion, where the different wavelengths of light are separated, creating a rainbow of colors.
4. What are the different types of prisms?
There are several types of prisms, including triangular prisms, rectangular prisms, and hexagonal prisms. Triangular prisms are the most common and have three rectangular sides and two triangular bases. Rectangular prisms have six rectangular sides and two rectangular bases. Hexagonal prisms have six rectangular sides and two hexagonal bases.
5. How are prisms used in science and everyday life?
Prisms are used in science to study light and its properties, such as refraction and dispersion. They are also used in devices such as binoculars, cameras, and spectrophotometers. In everyday life, prisms are used in eyeglasses, kaleidoscopes, and even decorative items like chandeliers.
