High School Compton’s experiment vs ordinary mirror
  • Thread starter Thread starter exmarine
    Experiment Mirror
Compton's experiment demonstrated that X-rays can impart energy and momentum to electrons, resulting in measurable changes in photon wavelengths based on their deflection angles. In contrast, ordinary mirrors reflect lower-energy photons without causing significant energy transfer to the electrons, as the energy is insufficient to alter atomic energy levels. This results in negligible momentum change for the mirror as a whole, although theoretically, it could lead to a tiny kinetic energy increase. The discussion also touches on the Crookes radiometer, questioning whether the rotation is influenced by light reflection or other factors, highlighting the complexity of photon interactions. Overall, the differences in energy levels between X-rays and visible light are crucial in understanding these phenomena.
exmarine
Compton hit the electrons in a carbon target with x-rays and measured the changes in the wavelengths of the scattered photons versus their deflected angle. He correlated that with the energy and momentum the incident photon gave to the electron.
My question is why does this not happen in mirrors? AFAIK there is no red-shift in the much lower energy photons reflected from an ordinary mirror. Is no energy and momentum given to the electrons in the mirror? What is the difference in these cases?
As you've already said, the waves in light have much lower energy than X-rays, which also gives them a larger wavelength, so the scale of their interaction is much larger, involving arrays of atoms, and for materials suitable for a mirror the energy is not enough to cause energy level changes in individual atoms which would absorb energy.
So the light bounces off the mirror as a whole, which does cause a very tiny change in momentum and could in theory give the mirror as a whole some kinetic energy eventually. The effect is far too small to be significant in normal cases, but is the basis of "solar sails" which may be used in future as a means of propelling space probes.
Do you think this effect is responsible for the rotation of a Crookes radiometer, or is that view controversial?
What direction would this turn a radiometer?
In what direction does a radiometer actually turn?
Likes vanhees71
I suppose you would expect the white sides to retreat, because the radiation is reflected, not absorbed, imparting more momentum to the vane. I think this is opposite to what is observed, which at least proves that I don't know what is going on.
BTW, that was an innocent question. Which guideline did I violate?
Likes vanhees71
If you're referring to the guidelines link in Vanadium 50's signature line, that's just for information.
You did somewhat change the subject of the thread, which could be considered to be against the "hijacking" guideline, but it wasn't far off topic.
In addition to the above "light mill" article, the Wikipedia article on Crookes radiometer contains some useful information.
Thanks for the references.
