Pointwise convergence for all real x
  • Thread starter Thread starter lys04
    Convergence
lys04
pointwise convergence of a series
$$ \sum_{n=1}^\infty sin(\frac{n\pi}{2})sin(nx) $$
How do I know whether or not the series
$$ \sum_{n=1}^\infty sin(\frac{n\pi}{2})sin(nx)$$
converges pointwise for all real x or not?
By the way am I right in thinking that converging pointwise for all real x means whatever x i plug into the series it converges to some finite value?
I was thinking if i plug in x=pi/2 then I'd get
$$ \sum_{n=1}^\infty sin^2(\frac{n\pi}{2}) $$
Which diverges, does that prove that the series doesn't converge pointwise for all x?
You either show that it does or find a way to show that it does not.
Yes.
Yes.
lys04 said:
Homework Statement: pointwise convergence of a series
Relevant Equations: $$ \sum_{n=1}^\infty sin(\frac{n\pi}{2})sin(nx) $$
Note that ##\sin(\frac{n\pi}{2}) = 0## if ##n## is even and alternates between ##\pm1## if ##n## is odd. Using the alternating series test, ##\sum_{n=1}^\infty sin(\frac{n\pi}{2})a_n## converges iff ##a_n \to 0## for odd ##n##.
In this case, the series converges iff ##\sin((2n+1)x) \to 0## as ##n \to \infty##. That's only the case when ##x = k\pi## for some integer ##k##. Although, it's not that easy from first principles to prove that it does not converge for any other ##x##. You found a good example,
The series expansion of the sine function can help. Not really first principles but at least in the realm of the question.
Another idea is to substitute ##y=x-(\pi/2)## which turns the series members into ##\sin^2(n \pi /2)\cos(ny)## which reduces the question to: Under what circumstances does ##\sum \sin^2(n \pi /2)\cos(ny)## converge, if ##\sum \sin^2(n \pi /2)## diverges?
One should also keep the Weierstraß- or half-angle substitution in mind whenever it comes to trig functions and integrals or sums.
One small point, we don't actually know the ##a_n## are positive in this question so the alternating test doesn't work.
Yes, well spotted.
  • · Replies 18 ·
