Phase relation between two waves
  • Thread starter Thread starter songoku
The discussion centers on the phase relationship between two waves, specifically addressing confusion over why the correct answer to a question is B instead of A. It clarifies that the x-axis in the graph represents position, indicating that wave Q is ahead of wave P, which is why Q leads P. If the x-axis were time, P would lead Q as it reaches maximum displacement earlier. The distinction between displacement-position and displacement-time graphs is emphasized, with the former showing a snapshot of wave positions at a moment in time. Understanding these graph types is crucial for accurately interpreting wave behavior.
songoku
Please see below
##\phi=\frac{2\pi x}{\lambda}##
I answered A but the answer key is B.
I thought since the wave is moving to the right, P started first compared to Q (the crest of P is closer to y-axis compared to Q). Why is the correct answer B?
Thanks
Edit:
Wait, is it because the x-axis is position so the position of Q is in front of P (more to the right)?
If the x-axis is time, then P will lead Q since P starts earlier?
Imagine that you are measuring the wave height at some arbitrary position on the x-axis. As the waves move towards you, which wave peak arrives first?
Also note that the x=0 location is arbitrary. That wave has no beginning, it comes from x → -∞ and goes to x → +∞
Likes songoku and AlexB23
songoku said:
Edit:
Yes.
Thanks
Edit:
Say we have a transverse wave, moving in the +x direction, along a string.
There are 2 very different types of graph and it’s easy to get them confused.
I) A displacement-position (d-x) graph. This shows the shape of the wave. It’s basically a 'snapshot', showing the shape of the wave taken at some moment in time.
ii) A displacement-time (d-t) graph. This shows you how the displacement of single particle on the wave, at a fixed x-position, changes over time.
The graph in the Post #1 question is type i) – it’s a snapshot of 2 waves taken at the same moment. The waves are moving right; the wave labelled Q is clearly ahead (further to the right) of wave P. So we can say wave Q leads wave P (by a distance which is 1/8th of a wavelength).
If the graph were type ii), this would show that particle P reaches its (for example) maximum displacement at an earlier time than particle Q reaches its maximum displacement. We would describe this by saying ‘particle P leads particle Q’ (by 1/8th of a period).
Minor edits.
  • Agree
Likes hutchphd, songoku and SammyS
I understand.
Thank you very much for the help and explanation DaveE, nasu, Steve4Physics
Likes Steve4Physics and DaveE
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
