Complex Numbers (Laurent Series)
  • Thread starter Thread starter jojosg
The discussion centers on the validity of a problem involving the Laurent series for the function \( f(z) = \frac{z+1}{z^3(z^2-2)} \). Participants express skepticism about the specified domains for the series expansions, particularly questioning the convergence for \( 1 < |z| < +\infty \) due to the presence of a pole at \( z = \sqrt{2} \). The correct domains for convergence are identified as \( 0 < |z| < \sqrt{2} \) and \( \sqrt{2} < |z| < +\infty \). The discussion emphasizes the importance of partial fraction decomposition and the correct application of series expansions.
  • Understanding of Laurent series and their convergence properties
  • Familiarity with partial fraction decomposition techniques
  • Knowledge of complex analysis, particularly regarding analytic functions
  • Proficiency in using LaTeX for mathematical expressions
  • Study the properties of Laurent series and their convergence criteria
  • Learn about partial fraction decomposition in complex functions
  • Explore the implications of poles and singularities in complex analysis
  • Practice writing mathematical expressions in LaTeX for clarity in communication
Students and professionals in mathematics, particularly those focusing on complex analysis, as well as educators seeking to clarify concepts related to Laurent series and their applications.
jojosg
Am attempting a Laurent Series question but I'm not confident in my answers. would appreciate any corrections.
f(z) = sigma (cnz^n)
see attached.
Are you sure this problem is valid? The domains of the two expansions would make more sense to me if the function was
##\frac {z+1}{z^3(z^2-1)}##
or if the domains were ##0\lt z \lt \sqrt 2## and ##\sqrt 2 \lt z \lt \infty##
PS. I can not read your work.
It was given by my teacher so I assume the problem is valid. Hope these are clearer.
I don't believe there is a Laurent series for that function that converges for ##1 \lt |z| \lt \infty##
##\boxed{
\textbf{Problem 3: Find the Laurent series of } f(z) = \frac{z+1}{z^3(z^2-2)} \text{ for:}
\quad \text{(1) } 0 < |z| < 1 \quad \text{(2) } 1 < |z| < +\infty
**Partial Fraction Decomposition**
We begin with the partial fraction decomposition:
$$f(z) = \frac{z+1}{z^3(z^2-2)} = \frac{A}{z} + \frac{B}{z^2} + \frac{C}{z^3} + \frac{Dz+E}{z^2-2}$$
Multiply both sides by ##z^3(z^2-2)##:
$$z+1 = Az^2(z^2-2) + Bz(z^2-2) + C(z^2-2) + (Dz+E)z^3$$
$$z+1 = A(z^4-2z^2) + B(z^3-2z) + C(z^2-2) + Dz^4 + Ez^3$$
$$z+1 = (A+D)z^4 + (B+E)z^3 + (-2A+C)z^2 - 2Bz - 2C$$
Comparing coefficients:
$$\begin{cases}
z^4: & A + D = 0 \\
z^3: & B + E = 0 \\
z^2: & -2A + C = 0 \\
z^1: & -2B = 1 \\
\text{Constant}: & -2C = 1
\end{cases}$$
Solving:
$$B = -\frac{1}{2}, \quad C = -\frac{1}{2}, \quad -2A - \frac{1}{2} = 0 \Rightarrow A = -\frac{1}{4}$$
$$D = -A = \frac{1}{4}, \quad E = -B = \frac{1}{2}$$
Thus:
$$f(z) = -\frac{1}{4z} - \frac{1}{2z^2} - \frac{1}{2z^3} + \frac{\frac{1}{4}z + \frac{1}{2}}{z^2-2}$$
**1. Laurent Series for ##0 < |z| < 1##**
For ##|z| < 1##, we expand ##\frac{1}{z^2-2}##:
$$\frac{1}{z^2-2} = -\frac{1}{2} \cdot \frac{1}{1 - \frac{z^2}{2}} = -\frac{1}{2} \sum_{n=0}^{\infty} \left(\frac{z^2}{2}\right)^n = -\sum_{n=0}^{\infty} \frac{z^{2n}}{2^{n+1}}$$
Then:
$$\frac{\frac{1}{4}z + \frac{1}{2}}{z^2-2} = \left(\frac{1}{4}z + \frac{1}{2}\right) \left(-\sum_{n=0}^{\infty} \frac{z^{2n}}{2^{n+1}}\right) = -\frac{1}{4} \sum_{n=0}^{\infty} \frac{z^{2n+1}}{2^{n+1}} - \frac{1}{2} \sum_{n=0}^{\infty} \frac{z^{2n}}{2^{n+1}}$$
So the Laurent series for ##0 < |z| < 1## is:
$$f(z) = -\frac{1}{4z} - \frac{1}{2z^2} - \frac{1}{2z^3} - \frac{1}{4} \sum_{n=0}^{\infty} \frac{z^{2n+1}}{2^{n+1}} - \frac{1}{2} \sum_{n=0}^{\infty} \frac{z^{2n}}{2^{n+1}}$$
**2. Laurent Series for ##1 < |z| < +\infty##**
For ##|z| > 1##, we expand ##\frac{1}{z^2-2}## differently:
$$\frac{1}{z^2-2} = \frac{1}{z^2} \cdot \frac{1}{1 - \frac{2}{z^2}} = \frac{1}{z^2} \sum_{n=0}^{\infty} \left(\frac{2}{z^2}\right)^n = \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+2}}$$
Then:
$$\frac{\frac{1}{4}z + \frac{1}{2}}{z^2-2} = \left(\frac{1}{4}z + \frac{1}{2}\right) \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+2}} = \frac{1}{4} \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+1}} + \frac{1}{2} \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+2}}$$
So the Laurent series for ##1 < |z| < +\infty## is:
$$f(z) = -\frac{1}{4z} - \frac{1}{2z^2} - \frac{1}{2z^3} + \frac{1}{4} \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+1}} + \frac{1}{2} \sum_{n=0}^{\infty} \frac{2^n}{z^{2n+2}}$$
**Final Answer:**
**(1) For ##0 < |z| < 1##:**
**(2) For ##1 < |z| < +\infty##:**
Series (2) can not converge at ##z=\sqrt 2## because the function is not defined there. The region of convergence (##1 \lt |z| \lt +\infty##) of a Laurent series can not include a pole (## z=\sqrt 2##) of the original function, .
I repeat that the problem statement is wrong.
Yes. Expanding ##(z - a)^{-k}## in binomial series can be done in two ways; one converges for ##|z| < |a|## and the other for ##|z| > |a|##.
I agree
Your teacher is not infallible, so I'd reach out for clarification about the intended function and intended domain.
Note that your first series converges when ##\left\lvert \frac{z^2}2 \right\rvert < 1## or, equivalently, ##\lvert z \rvert < \sqrt 2##.
I haven't looked at your work, but if it is correct, then it will be valid for the modified problem with domains specified as ##|z|\lt \sqrt 2## and ##\sqrt 2 \lt |z| \lt +\infty##.
can I use this theorem to prove that its not analytic in that range for part 2?
WA delivers a series for all values, just not the same. However, it does not provide the convergence radii.
jojosg said:
##\boxed{
$$\begin{cases}
z^4: & A + D = 0 \\
z^3: & B + E = 0 \\
z^1: & -2B = 1 \\
\end{cases}$$
Solving:
Thus:
It is simpler to add the series expansions of ##\frac{z}{z^3(z^2-2)}## and ##\frac{1}{z^3(z^2-2)}##. Both series are simple to derive and valid for ##|z^2/2| \lt 1##. Your restriction of ##|z| \lt 1## is wrong.
I don't think we should use the words wrong or false. The answer is simply not as simple as expected, since the crucial point is different from the one given by the problem statement.
Maybe I should have said, unnecessary or misleading or arbitrary.
In any case, IMO, it is important to know and use the radius of convergence of the geometric series.
  • · Replies 30 ·
