dacad
- 1
- 0
- TL;DR
- Wanting to determine the change in insulation value in open airways vs sealed airways
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas.
I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply.
Typically, both ends of the corrugated sheet are open to atmosphere. This allows air flow and I do remember that moving air is far less insulating than static or contained air. So my question is, by how much for this particular example. Attached pdf file has approximate dimensions of a typical corrugated plastic board. Figure polyethylene or similar plastic for the board itself for any values needed for that material but again, just looking for the delta between free flowing air versus contained air. The exact geometry may be a bit different but I'm strictly trying to determine a delta value for the insulation properties.
Not even sure what units the result should be in but if I can get something, I can probably research enough to translate into units that I can compare with other solid materials in the bee hive.
Pretty basic stuff I'm sure but again, it's been 40 some years and energy transfer is outside of my field.
Thanks !!!!
Thanks !!!!
