Help with derivation of electric field of a moving charge
The discussion focuses on the derivation of the electric field from a moving charge, starting with the expression for the magnetic field. The user derives the electric field using the vector potential and applies the chain rule, leading to a complex expression involving derivatives of variables with respect to time. They identify a discrepancy in the first term of their derived electric field equation, which has a dimension of T^-1, while it should be dimensionless. The user seeks assistance in locating the source of this error and understanding its implications. The conversation emphasizes the importance of dimensional consistency in physical equations.
GilSE
Derive electric field of moving charge formulas from Lienard-Wiechert potentials.
Formulas of electromagnetic field of moving charge to be derived:
$$\vec E=\frac q {\mu^3}\left((1-\beta^2)\vec R-R(1-\beta^2)\vec\beta\right)+\frac q{c\mu^3}\left(\vec R\times\left((\vec R-R\vec\beta)\times\vec\beta\right)\right)$$
$$\vec B =\frac{\vec R}{R}\times\vec E$$
$$\mu=R-\vec\beta\cdot\vec R$$
##\vec R## is a difference between point, where the fields are calculated, and the point, where moving charge are.
Here and further, all values are considered taken in ##t'## moment (except those in general formulas for calculating EMF from potentials)
Values in the right side of these equations should be calculated at the moment ##t'## given by equation: ##R(t')=c(t-t')##.
One can derive field equations from Lienard-Wiechert potentials:
$$\varphi = \frac q {\mu}$$
$$\vec A=\frac{q\vec\beta}{\mu}$$
By general formulas:
$$\vec E = -\nabla\varphi-\frac 1 c \frac{\partial\vec A}{\partial t}$$
$$\vec B=\nabla\times\vec A$$
Also I have these relations from my textbook:
$$\frac{\partial R}{\partial t'}=-c\frac{\vec\beta\cdot\vec R}R$$
$$\frac {\partial t'}{\partial t}=\frac R{\mu}$$
At first, I derived that:
$$\nabla \frac 1{\mu}=-\frac 1{{\mu}^3}\left((1-\beta^2)+\frac{\dot{\vec\beta}\cdot\vec R}c\right)\vec R$$
(dot means differentiation with respect to ##t'##).
I assume this result is true because it gives valid result for magnetic field.
To find electric field one should also derive partial derivative of ##\vec A## with respect to ##t##. I've used chain rule, substituted ##\vec A## and used derivative of product formula.
$$\frac {\partial \vec A}{\partial t}=\frac {\partial \vec A}{\partial t'}\frac {\partial t'}{\partial t}=q\frac {\partial t'}{\partial t}\left(\frac1\mu\frac{\partial\vec\beta}{\partial t'}-\frac 1{\mu^2}\frac{\partial\mu}{\partial t'}\vec\beta\right)=q\frac {\partial t'}{\partial t}\left(\frac1\mu\dot{\vec\beta}-\frac 1{\mu^2}\frac{\partial\mu}{\partial t'}\vec\beta\right)$$
Then calculated separately:
$$\frac{\partial\mu}{\partial t'}=\frac{\partial R}{\partial t'}-\frac{\partial(\vec\beta\cdot\vec R)}{\partial t'}=\frac{\partial R}{\partial t'}-\vec\beta\cdot\frac{\partial\vec R}{\partial t'}-\vec R\cdot\frac{\partial\vec\beta}{\partial t'}$$
Now use the fact that:
Also, obviously:
$$\frac{\partial \vec R}{\partial t'}=-c\vec\beta$$
Substituting these two formulas in the above one:
$$\frac{\partial\mu}{\partial t'}=-c\frac{\vec\beta\cdot\vec R}R+c\beta^2-\vec R\cdot\dot{\vec\beta}$$
And finally:
$$\frac {\partial \vec A}{\partial t}=q\frac {\partial t'}{\partial t}\left(\frac1\mu\dot{\vec\beta}-\frac 1{\mu^2}\frac{\partial\mu}{\partial t'}\vec\beta\right)=$$
$$=q\frac R\mu\left(\frac 1 \mu\dot{\vec\beta}+\frac 1 {\mu^2}\left(c\frac{\vec\beta\cdot\vec R}R-c\beta^2+\vec R\cdot\dot{\vec\beta}\right)\vec\beta\right)=$$
$$=q\frac R{\mu^3}\left(\mu\dot{\vec\beta}+\left(c\frac{\vec\beta\cdot\vec R}R-c\beta^2+\vec R\cdot\dot{\vec\beta}\right)\vec\beta\right)$$
Using expression for ##\nabla\frac 1{\mu}##, electric field is:
$$\vec E=\frac q{{\mu}^3}\left((1-\beta^2)+\frac{\dot{\vec\beta}\cdot\vec R}c\right)\vec R-q\frac R{\mu^3}\left(\frac{\mu\dot{\vec\beta}}c+\left(\frac{\vec\beta\cdot\vec R}R-\beta^2+\frac{\vec R\cdot\dot{\vec\beta}}c\right)\vec\beta\right)=$$
$$=\frac q {\mu^3}\left((1-\beta^2)\vec R-R\left(\frac{\vec R\cdot\dot{\vec\beta}}R-\beta^2\right)\vec\beta\right)+\frac q {c\mu^3}\left((\dot{\vec\beta}\cdot R)\vec R-\mu R\dot{\vec\beta}-R(\dot{\vec\beta}\cdot R)\vec\beta\right)$$
The second part after simplification matches the second part of Lienard-Wiechert E-field equation, but the first slightly differs, and I can't find an error causing it. I'll appreciate any help with finding it.
The first term has dimension of T^-1 though it should be non dimensional. You should investigate its derivation.
Besides the error pointed out by @anuttarasammyak, check your work for the following:
I get an additional term proportional to ##\vec{\beta}##. $$\nabla \frac 1{\mu}=-\frac 1{{\mu}^3}\left((1-\beta^2)+\frac{\dot{\vec\beta}\cdot\vec R}c\right)\vec R + \frac 1 {\mu^2} \vec{\beta}$$
Verify that the additional term does not alter the result for the magnetic field.
Unfortunately, must be a typo. In my handwritten notes there is no dot above beta in this term. But still thank you for your answer!
Thank you very much, with that additional term the result looks correct at last! I will be searching why I haven't obtained it when was calculating gradient.
Good. If you wish, you can post your work for ##\nabla \mu## and we can review it.
I want to find the solution to the integral ##\theta = \int_0^{\theta}\frac{du}{\sqrt{(c-u^2 +2u^3)}}## I can see that ##\frac{d^2u}{d\theta^2} = A +Bu+Cu^2## is a Weierstrass elliptic function, which can be generated from ##\Large(\normalsize\frac{du}{d\theta}\Large)\normalsize^2 = c-u^2 +2u^3## (A = 0, B=-1, C=3) So does this make my integral an elliptic integral? I haven't been able to find a table of integrals anywhere which contains an integral of this form so I'm a bit stuck. TerryW
  • · Replies 32 ·
