phy_magic
- 7
- 0
- Homework Statement
- 3 equal weights are attached to the ends and in the middle of the rope. We raise the middle weight so that the rope is horizontal and in the middle between the pulleys, and let it go, after which the middle weight is lowered and the weights at the ends are raised.
How far will the middle weight travel before it starts to rise?
- Relevant Equations
- 3 weights -m
2 pulleys
I don't understand if we let go of the middle mass it will move down the y-axis and the two edge masses up. So the tensions will have to be greater than mg for the edge masses to start moving but then when (if) the system stops then the tension will have to be equal to mg. Is that possible? Will the middle weight move up after some time? So, i came to this thoughts.
Is tension force in rope same all the time , does acceleration of middle weight change during time and why would middle weight go up (rise)?
I saw questions like this , but I am little confused about this questions?
