Undergrad How do I stretch a laser from a beam into a sheet?
  • Thread starter Thread starter LightningInAJar
    Optic lens
To stretch a laser beam into a sheet of light, a cylindrical lens is likely the appropriate tool, potentially requiring two for effective collimation. A simple diffuser could also work, but it may significantly reduce brightness. For a more dynamic solution, scanning a 1D beam quickly across a plane could create the desired effect, using a rotating mirror or a vibrating mirror setup. The discussion highlights the importance of lens choice, with suggestions for using concave lenses or even repurposing components from laser printers for optimal results. Ultimately, achieving the desired laser sheet for artistic projects like capturing rain or snow will depend on careful selection and arrangement of optical components.
  • #31
There are standard optical components used for generating lines from laser beams, known as Powell lenses. These lenses are manufactured with various divergence angles.
A typical laser beam has a Gaussian intensity profile. The principle behind a Powell lens is that it splits the laser beam into two parts and recombines them in such a way that the Gaussian profiles cancel each other, resulting in a uniformly distributed line. Powell lens assemblies allow the laser line to be focused at a desired distance, ensuring a sharp line with even intensity along its length.
Likes LightningInAJar, Ibix, berkeman and 2 others
Science news on Phys.org
  • #32
sophiecentaur said:
you need a concave lens to spread the beam
Either will spread the beam in the far field.
  • #33
How far, though? You would want it to be compact, I assume. OP didn’t say the focal length. I didn’t understand it ‘not working at all’.
Maybe the fan out dispersed the energy too much.
  • #34
That's my guess too. It's too simple not to work at all.
Scanning has an advantage in brightness over divergent optics.
PS: Google says laser levels don't scan though.
  • #35
In many ways that would be true; you can be much more 'adventurous' than you can with static optics and get an almost parallel sided output. But moving parts?? I wouldn't go there'
The context of this thread is still unknown. It strikes me that the OP got himself a laser and waved it about on a rainy night. Reasonably enough he came to the 'fan' idea but with no specific application (except for nice photos perhaps. This is just where I could be, too.
I wonder if it might be worth while playing with some shiny cutlery (spoons and fork handkes) to see hoe they affect the laser beam.
My guess would be a second hand laser level from Facebook Marketplace would do the job for a fiver.
  • #36
LightningInAJar said:
No smoky medium. I would like to create a plain of laser light to take video of rain water or snow falling through it as a little art project.
So all you need is the standard beam spreader used in a laser level that produces a line on a wall. So quick and dirty, try shining a laser through the round stem of a wine glass and point that at a stream of water drops :). Anything that falls between the laser and the wall will reflect the laser. In other words, there is a "sheet of laser light" created by the typical laser level. You can't normally see it since there is nothing interrupting the sheet (until it hits the wall). But if there are water drops falling through the sheet, they will light up in the beam.
If you use a couple lasers and spreaders with their planes parallel to the ground but at different heights the raindrops should look like falling blinking lights.
Likes sophiecentaur
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 24 ·
