jbriggs444
Homework Helper
- 13,433
- 8,100
EDIT: The quoted passage above has been removed from the post in which it appeared. The next few paragraphs are now unmotivated. So I've spoiler tagged them.gen x said:Car travel in constant radius circle track, is this rigid motion?
If we are treating the car as a point-like object then it is not rigid motion. If all one has have is a moving point then notions of rigidity or rigid motion are irrelevant.
If we are treating the car as an extended object maybe 2 meters wide by 4 meters long by 1 meter high then we do have rigid motion.
It would be convenient to adopt a frame of reference anchored to the center of the track and view the car as rigidly rotating about that non-translating center.
For this scenario, it is challenging to find other sensible descriptions. But not impossible. We might imagine that this circular track is actually a turntable. We might further imagine that this turntable is placed on the deck of an aircraft carrier with the car parked somewhere on the turntable's rim. We might stipulate that the aircraft carrier is moving forward at a speed which is equal to the tangential velocity of the turntable which is rotating clockwise.
If we adopt a frame of reference where the ocean water is at rest and look for an "instantaneous center of rotation", what center will we find?
We look for a point on the turntable that is at rest in our chosen frame. This will turn out to be a point at the rim of the turntable on the starboard side. That is the "instantaneous center of rotation" of the turntable plus car.
With a wave of paper and pencil. The throwing of the wheel/stick has nothing to do with it.gen x said:How can you throw wheel/stick in the air and force to not rotate around CoM?
Rotation about the CoM is not a physical fact of the matter. It is a convenient way of describing the physical motion.
