How do I stretch a laser from a beam into a sheet?
  • Context: Undergrad
  • Thread starter Thread starter LightningInAJar
    Optic lens
The discussion revolves around methods to transform a laser beam into a sheet of light, focusing on the use of lenses and other optical devices. Participants explore various optical configurations, including cylindrical lenses and telescopes, as well as practical applications for creating a plane of laser light for artistic purposes.
  • Experimental/applied
  • Some participants suggest using a cylindrical lens to stretch the laser beam along one axis, while others propose that a simple diffuser could also work, albeit at the cost of brightness.
  • A Galilean telescope arrangement is proposed by one participant, involving a concave lens followed by a cylindrical lens to expand the beam diameter.
  • Concerns are raised about the initial beam diameter of the laser and the need for a finite diameter for effective spreading.
  • Some participants mention the potential use of a rotating polygonal mirror or a simple reciprocating reflector as alternatives for creating a plane of light.
  • There is a suggestion to scan a 1D beam in a plane faster than the shutter speed of a camera to capture falling rain or snow, with various mechanical solutions discussed.
  • One participant emphasizes the importance of understanding the divergence characteristics of the laser, especially in the context of diode lasers.
  • Participants discuss the practicality and cost-effectiveness of different solutions, including the use of second-hand equipment.
Participants express a range of opinions on the best approach to achieve the desired effect, with no clear consensus on a single solution. Various methods are proposed, and some participants challenge or refine earlier suggestions without reaching a definitive agreement.
Participants note the limitations of certain optical configurations, such as the need for specific beam characteristics and the potential for reduced brightness when spreading the laser light. The discussion also highlights the variability in laser types and their divergence properties, which may affect the proposed solutions.
This discussion may be useful for hobbyists, artists, or engineers interested in optical setups for creating visual effects, as well as those exploring practical applications of laser technology in experimental projects.
  • #61
The "Y" in "DIY" stands for yourself. We can't tell you the best way for you to solve the mechanical mounting problem with your tools, desires, and experience.
Science news on Phys.org
  • #62
A totally personal choice, of course. For anyone to help you get to your goal you need to describe the problem exactly. The easiest solution would almost certainly to have been to buy a cheapo laserlevel. Now you have spent $40 on your posh lens, you are pretty well forced to use it. Also, a level is a level and useful in its own right.
  • #63
I'm almost loathe to suggest it but you could formulate a detailed question for ChatGPT and ask the educated and intelligent people on here (which excludes me) bout the details that eludes you....
EDIT: I've had success with that MO before....
  • #64
I'd bet that ChatGPT uses PF as a source for 'good ideas'. It has to get them somewhere as it has nothing of its own to give.
  • Agree
  • #65
Yeah, in reality I'd be like searching PF and ask for elaboration on a particular subject.
EDIT: You *could* probably cut out ChatGPT but as I said when I formulated my questions in detail I was actually quite pleased with the answers. Except the parts I needed explained in more detail.
Here's an example (I knew I needed to profile the laser but I wanted ChatGPT to offer solutions, also with the lenses):
Please explain the demands, details and/or specifications of a 532 nanometer laser for use in a home build Raman spectrometer with a 2 lens setup. Specifically what, if anything, needs to be checked or done with regards to the laser for optimal focusing back and forth through the lens focusing the beam onto the sample in order to pick up the Raman backscattering.
EDIT: Or rather, I wanted it to point out to me which values were important to profile.
EDIT2: It "liked" my question("Nice project — fun and doable."? I wonder where these opinions come from? And what constitutes a stupid or inane question?) and I got a surprising amount of math back at me! :woot:
  • #66
Here's the follow-up:
Please provide detailed instructions and specifications for building laser beam profilers for a 532 nanometer laser based on all techniques within DIY range. Specifically I want you to include the knife edge and camera techniques as well as any alternatives.
Also a lot of math. Obviously.
  • #67
You might want to give this thread a look if you haven't already:
  • #68
Chatgpt is the first place I went when asking about lenses. YouTube helped more.
  • #69
Yeah well, I'm not much for videos. I like to read.
  • #70
You have the necessary info about the lens and the laser. What you need is practical advice for the 'under-tooled'. If you had some modest machine tools then you'd do this easily. But, as I have already pointed out, you haven't shown us the actual problem. I wonder why.
  • #71
Undertooled?
EDIT: And this is a month-old picture.
  • #72
Nah, my basic problem is that I'm not made of money and I need to buy the things I need step by step. And then I'm also not exactly great at math. I'll make it work but it'll take some time. Also I have other, way more serious, stuff going on in my life.
  • #73
I mean I know how to solve an ODE but, but luckily I'm teamed up with a civil engineer. I recently conspired with his wife to get him off the booze so we're getting there. :woot:
  • #74
sbrothy said:
Undertooled?
Ah you meant perhaps in the qualification-department? Fair enough. Don't worry. I'll the there.
  • #75
Just a cheap green laser pen about 2cm diameter. Less the 5mm laser beam. Roughly 8mm diameter Powell lens.
  • #76
I have several of the 532nm green ones. Disassembled they're the size of my thumb nail. Also red ones.
Well, I found out that a near IR laser might be better better suited for the job. You can follow my antics here:
  • #77
sbrothy said:
Undertooled?
Sorry, no offence intended. I was referring to a drill, a lathe, a milling machine machine, a band saw and even a bench with a vise. Those 'tools' make a job like yours a doddle. It's the border between ee and metal bashing that determines how easy some jobs can be - that is if you can't buy ready made parts.
A vise and a small pillar drill (always second hand for me!!) make drilling holes in the right place possible and getting the right diameter too.
  • #78
TIL: Pillar Drill = Drill Press (I think). Y'all talk funny over there.
Anyway lathes and milling machines aren't required. I could do this with a hack saw, a cordless drill, a file, and an assortment of tape, screws, and glue. Also great deal of patience, creativity, and forgiveness for a kludgy looking result. However, I consider myself and expert on doing things badly with the wrong tools to get a good enough result. Yes, I think I can make a slot in a block of aluminum with a hand drill and a file.
What's really needed is desire, initiative, and a few failed attempts. It doesn't sound like that's in the cards this time.
PS: Also a vise, I'll need that or some clamps.
  • #79
Well, as you know from our previous "altercation" I own a Devil (tm) Forge, a plasma burner / TIG welder and a comprressoe
  • #80
I started trying to set up a forge amassing equipment like the Devil's Forge and a plasma burner, hydraulic presses and so on. I then had to set up a proper comapany because the number of private persons wanting to have an smithy in thir backyard was "surprisingly" small. My company is now called (Odense is the 3rd largest city in Denmark after Copehagen and Århus):
My one-man firm is called "Odense Metallurgy, Electronics, Chemistry & Computing", which kind of covers it all. I'll admit it's mostly for renting a commercial workshop, and perhaps obtaining ISO-certifications not available to private individuals, for instance LASERS too powerful to be accessably to private individuals.
I plan on using wood to prototype my first attempt.
  • #81
Gor blimey guv'nor. Strike me pink! (Apologies to Dick Van Dyke.)
I always fancied something like that myself but my requirements are smaller and finer than blacksmithing will produce. Too much investment for a brief bit of fun for me.
  • #82
Why not cast something in alloy? Use your existing skill to support your present interest. :smile:
  • · Replies 19 ·
