collinsmark
Homework Helper
- 3,445
- 3,568
Here's an image I captured last Tuesday night [Edit: actually, Monday night/Tuesday morning], a little less than a week before opposition.
Rhea, one of Saturn's moons, can be seen on the left. Saturn's north is "up" in the image.
If the rings' shadow and inner rings look a little blue to you, it's less to with them actually being blue and more to do with the fact that I did not break out my atmospheric dispersion corrector (ADC) during acquisition, mostly out of laziness. Earth's atmosphere affects blue wavelengths more than other colors.
Equipment:
Celestron C14 EdgeHD telescope
Skywatcher EQ8-R Pro mount
TeleVue 2x Powermate (a fancy Barlow lens)
Astronimik RGB filter set
ZWO ASI290 (monochrome camera)
Software:
FireCapture (for acquisition)
AutoStakkert! (for lucky imaging processing)
WinJUPOS (for derotation, RGB combination)
PixInsight with RC Astro plugins (sharpening and misc. processing)
Acquisition (using FireCapture):
Date/Time: 2025-09-16, from 08:33.9 to 08:54.6 UT
(Midpoint time: 2025-09-07 08:47.4 UT)
Atmospheric seeing: somewhat on the better side of "meh"
Sub-frame exposure time: 25 ms.
Acquisition video length: 60 sec per color, alternating R-G-B-R-G-B...
21 minutes of total acquisition time.
Lucky Imaging with AutoStakkert!:
Best 50% frames kept.
Drizzle/Resampling: 3x Drizzle
Sharpening (after lucky imaginging processing) by PixInsight:
MultiscaleLinearTransform
DynamicCrop (to remove stacking artifacts at frame edges)
Derotation:
For each color channel (R, G, or B) 7 sharpened images were derotated and stacked using WinJUPOS.
Final adjustment processes with PixInsight:
ChannelCombination to combine the R, G, and B into a single color image.
HistogramTransformation did the heavy lifting for color balance
CurvesTransformation for color balance fine adjustments
NoiseXTerminator
DynamicCrop for final crop
Equipment:
Software:
Derotation:
NoiseXTerminator
