Design of Boost Converter
  • Context: Engineering
  • Thread starter Thread starter PhysicsTest
The discussion revolves around the design of a boost converter, focusing on component selection such as inductors, capacitors, resistors, and MOSFETs, as well as calculations related to inductor current, output voltages, and load currents. The original poster considers a configuration of 10V, 4.8A input to 24V, 2A output and seeks feedback on the validity of these specifications.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the assumptions of efficiency in the design, with some noting that the original specifications assume 100% efficiency, which is unrealistic. Questions arise regarding the duty cycle needed for the specified input and output voltages, as well as the impact of real efficiency on the duty cycle. There are inquiries about the values of inductance and capacitance, switching frequency, and the equations necessary for determining these values.
The discussion is ongoing, with various participants providing insights into the design process and equations involved. Some guidance has been offered regarding the importance of understanding continuous versus discontinuous conduction modes, the role of the MOSFET in determining switching frequency, and the significance of component selection. There is no explicit consensus, but multiple interpretations and approaches are being explored.
Participants note the original poster's inexperience in hardware design and the potential for misunderstanding in the application of equations. There is a mention of the need to consider the efficiency of the converter and the implications of component choices on performance. Constraints such as the requirement for hands-on design and the complexity of the equations involved are acknowledged.
PhysicsTest
Designing a Boost Converter
V = L di/dt
I want to do hands on designing a buck converter mainly understanding the selection of component values Inductor, Capacitor, Resistor, Mosfet, performing the calculations of Inductor current, Output voltages and Load currents. My first question is, i want to consider the below configuration of 10V, 4.8A -> 24V, 2A. Is the selection Ok? or i am failing in the first step itself, there is no particular reason for considering the above specifications, or please suggest better specifications which would help. Thank you in advance.
Brief circuit of Boost Converter
You mean boost converter there, right? That's what you've shown and you mention boosting the input voltage to make the higher output voltage.
Your specs assume 100% efficiency, which will not be possible. The best you can do will be about 95%.
Sorry yes it is Boost converter can I go with above specifications assuming 95% efficiency.
What are your L and C values and what is the switching frequency? What duty cycle would an ideal boost converter need to run at for your input-->output voltages? How does the lower real efficiency affect the duty cycle?
First, ignore the input current.
Design for a specified output current.
You know the input and output voltages.
Write equations that can be solved for D, the duty cycle.
Only then will the values of C and L be determined.
I am really new to hardware design so please excuse me for any mistakes or i am going in an entirely different direction. I have attempted this, i have no idea if it is correct
R = V/I = 24/2 = 12 Ohm
$$ V_{out} * I_{out} = 0.95 *V_{in}*I_{l} - eq 1 $$
When switch closed let the ON time be T_on
$$I_l = \frac{V_{in} * T_{on}}{L} - eq3$$ substitute in eq-1
$$\frac{V_{out}*I_{out}}{R} = \frac{0.95 *V_{in}^2 * T_{on}}{L} eq-4$$
$$V_{out} = V_c$$
Using the capacitor equation
$$i = C*\frac{dv}{dt} eq- 5$$ For linear ramp
$$V_c = \frac{I_{out}*T_{off}}{C} - eq6 $$
$$\frac{I_{out}^2 *T_{off}}{C} = \frac{0.95 *V_{in}^2 * T_{on}}{L} $$
$$V_{in} = 10 V; I_{out} = 2 A; $$
$$\frac{T_{on}}{T_{off}} = \frac{4*L}{C*100*0.95} $$
$$1 + \frac{T_{off}}{T_{on}} = 1 + \frac{23.5*C}{L}$$
$$\frac{1}{D} = 1 + \frac{23.5C}{L} $$
In case it is wrong please guide me with the rules / laws i have to apply to derive the values.
Il=Vin∗TonL−eq3
This is the change in the inductor current; how much it increases.
Read up a bit about continuous vs. discontinuous conduction mode. There's a ton of information on the web. Plus everyone here will assume your switching frequency is fast compared to the circuit dynamics, which I assume you will too. The inductor value is usually chosen initially by how much current ripple you want.
https://en.wikipedia.org/wiki/Boost_converter
https://www.ti.com/lit/an/slva372d/slva372d.pdf?ts=1769844593676
Sorry, I don't have time to go through the rest of your equations now, but you'll find the equivalent in the links I gave.
You can know the duty cycle, but you cannot know the switch on/off times, until after you select the MOSFET switch, and design the gate drive.
The thing that decides the frequency of operation, is the speed of the MOSFET switch, and that depends on the gate charge, miller capacitance, and your gate drive circuit.
The energy dissipation of one switch cycle, will tell you how many times you can switch per second, and not exceed the package dissipation. Then you can specify output voltage ripple, which will size the reservoir capacitor, and then the inductor.
There are many other factors involved in selecting the switching frequency. I guess this would be a good description of the maximum speed. However, much also depends on the commentating diode (or Mosfet for synchronous rectification). At turn on the FET must support the current ramp up to the load current plus the diode recovery time at full output voltage. You'll want a very stiff (high current) gate drive to keep the Miller effect from also adding extra time to this turn on stress.
Honestly my advice would be to skip the switching frequency optimization for now and just use 100KHZ. If your inductor is too big, use 200KHz. You're still learning the basic stuff, you can optimize this on your next attempts. Faster than this will just make things harder.
Also 95% efficiency is definitely doable with optimization, but plan on 90% at first, that's probably what you'll get.
If you're actually going to build this, PCB layout, snubbers, and bypass caps, are super important. You can read about that or ask us.
  • · Replies 36 ·
