mcastillo356
- 365
- Homework Statement
- The frequency of a car horn is ##400\,\text{Hz}##. If the horn is honked as the car moves with speed ##u_s=34\,\text{m/s}## through still air toward a stationary receiver, find ##(a)## the wavelenth of the sound passing the receiver, and ##(b)## the frequency recieved. Take the speed of sound in air as ##343\,\text{m/s}##. ##(c)##Find the wavelength of the sound passing the receiver and find the frequency received if the car is stationary as the horn is honked and a receiver moves with a speed ##u_r=34\,\text{m/s}## toward the car.
- Relevant Equations
- ##\lambda=\cfrac{v-u_s}{f_s}##
##f_r=\cfrac{v\pm{u_r}}{v\pm{u_s}}\,f_s##
##\lambda=\cfrac{v\pm{u_s}}{f_s}##
PICTURE ##(a)## The waves in front of the source are compressed, so we use the minus sign in ##\lambda=(v\pm{u_s})/f_s##. ##(b)## We calculate the received frequency using ##f_r=[(v\pm{u_r})/(v\pm{u_s})]f_s##. ##(c)## For a moving receiver, we use the same equations as in Parts ##(a)## and ##(b)##.
SOLVE
Calculate the wavelength in front of the car. In front of the source the wavelength is shorter, so choose the sign accordingly:
$$\lambda=\cfrac{v-u_s}{f_s}=\cfrac{343\,\text{m/s}-34\,\text{m/s}}{400\,\text{Hz}}=0.758\,\text{m}=\boxed{0.76\,\text{m}}$$
Solve for the received frequency with ##u_r=0##
$$f_r=\cfrac{v\pm{u_r}}{v\pm{u_s}}\,f_s=\cfrac{v}{v-u_s}\,f_s=\Bigg (\cfrac{343}{343-34}\Bigg )(400\,\text{Hz})=453\,\text{Hz}=450\,\text{Hz}$$
Why the sign minus in the second equation?
##(c)## 1. Calculate the wavelength in front of the source with ##u_s=0##
$$\lambda=\cfrac{v\pm{u_s}}{f_s}=\cfrac{343\,\text{m/s}}{400\,\text{Hz}}=0858\,\text{m}=\boxed{0.86\,\text{m}}$$
2. The received frequency is given with ##u_s##. The source is approaching the receiver, so the frequency is shifted upward. Choose the sign accordingly:
$$f_r=\cfrac{v\pm{u_r}}{v\pm{u_s}}\,f_s=\cfrac{v+u_r}{v}\,f_s=\Bigg (1+\cfrac{u_r}{v}\Bigg )\,f_s=\Bigg (1+\cfrac{34}{343}\Bigg )(400\,\text{Hz})=\boxed{440\,\text{Hz}}$$
In front of the source the wavelength is shorter. Why then is bigger than the wavelength in front of the car?
SOLVE
