- 29,617
- 21,428
Here is a valid derivation of the electric field for an infinite plane, based on the result for an infinite wire of uniform linear charge density.
The electric field for an infinite wire of uniform charge density ##\lambda## at a distance ##h## from the wire is:
$$E_l = \frac 1 {2\pi \epsilon_0} \big (\frac \lambda h \big )$$Consider the plane as a infinite sequence of parallel uniformly charged wires, separated by a distance ##d## from each other. The component of the electric field in the direction away from the plate is given by:
$$E_n = \frac 1 {2\pi \epsilon_0} \big (\frac {\lambda h}{h^2 + n^2d^2} \big )$$Where the nth wire is a distance ##nd## from some reference point on the plane. And the field is measured a height ##h## above this point. The total electric field at this point is:
$$E = E_0 + 2\sum_{n = 1}^{\infty} E_n$$To approximate a uniformaly charge plane of charge density ##\sigma##, we need to take ##d \to 0##. And, for a give ##d##, we need to set ##\lambda = \sigma d##. This gives the required component of the electric field as:
$$E = \frac 1 {2\pi \epsilon_0}\big [ \frac {\sigma d}{h} + 2\sum_{n = 1}^{\infty} \frac{\sigma d h}{h^2 + n^2d^2} \big ]$$$$= \frac 1 {2\pi \epsilon_0}\big (\frac {\sigma d}{h} \big ) \big [1 + 2\sum_{n = 1}^{\infty} \frac{1}{1 + n^2(d/h)^2} \big ]$$Now we need to take the limit as ##d \to 0## (which is equivalent to taking ##a = \frac d h \to 0##
$$E = \frac{\sigma}{\pi \epsilon_0} \lim_{a \to 0}\bigg (\sum_{n = 1}^{\infty} \frac{a}{1 + n^2a^2} \bigg )$$Finally, all we have to do is show that:
$$\lim_{a \to 0}\bigg (\sum_{n = 1}^{\infty} \frac{a}{1 + n^2a^2} \bigg ) = \frac \pi 2$$And we have, as required:
$$E = \frac {\sigma}{2\epsilon_0}$$
