With gravitational lensing, which way is down?
  • Context: Undergrad
  • Thread starter Thread starter .Scott
The discussion revolves around the effects of gravitational lensing on the trajectory of a spacecraft in the presence of a black hole and a distant star. Participants explore the implications of gravitational lensing on the perceived direction of gravitational pull and the complexities of spacetime geometry in general relativity.
  • One participant proposes a scenario where a spacecraft hovers near a gravitational lens and questions the direction of its fall when a distant star is introduced.
  • Another participant challenges the validity of introducing new objects into the scenario, emphasizing that all objects must be accounted for in the model from the beginning.
  • Clarifications are made regarding the term "almost directly behind," indicating that it refers to a situation where the star does not create an Einstein ring but is still noticeably deflected due to lensing.
  • Some participants argue that the gravitational contribution of the star will not align with its apparent position due to the effects of the lens, suggesting that the spacecraft will not fall directly towards the star.
  • There is a discussion about the nonlinear nature of general relativity, with one participant noting that gravitational contributions cannot be separated out from multiple sources.
  • Another participant introduces the idea of an "option 3," suggesting that the gravitational effects near a black hole could lead to unexpected trajectories as the spacecraft approaches critical regions like the photon sphere.
Participants express differing views on the validity of the proposed scenario and the implications of gravitational lensing. There is no consensus on the direction in which the spacecraft would fall, and multiple competing interpretations of the effects of gravitational lensing and spacetime geometry are present.
Participants note the complexities of modeling gravitational interactions in general relativity, including the dependence on the relative positions of the objects involved and the nonlinear nature of gravitational effects.
.Scott
Homework Helper
TL;DR
I would think that gravity has no choice than to propagate through the same space that light uses.
Let me construct a scenario.
My space craft is due south of a black hole - or other gravitational lens. But I have arranged my thrusters to precisely counter the effects of its gravity. So, I am hovering light years away.
Now I add a third item to my universe. A powerful star almost directly behind the lens. Because of the gravitational lensing, that star appears further to the side of the lens than is "really" is.
Because I have added a new object to my universe, this new gravitational source will cause me to drift away from my original hover location.
Question: In which direction will I fall? Directly towards the star - as if the lens was not there? Or directly towards the image of the star? Or something else?
My answer is that I fall directly towards the image. After all, space is really bent and gravity cannot propagate through anything other than space.
If that is right, I have some follow-on questions.
I don't know what to do with the "almost" here. If it is almost directly behind then why would you expect that directly towards the star is even a possibility? Is the "almost" a mistake or is that meaningful to the question?
You can't. Objects can't just magically appear out of nowhere.
Remember that GR is a theory of spacetime. Whatever objects are going to be there for all time need to already appear in your model. You can't start with a model that doesn't contain some object and then just add it.
You need to rethink your entire scenario in the light of the above.
@Dale regarding "almost":
If it was directly behind the lens, I would get an Einstein ring. But for this scenario, I don't want an Einstein ring. I just want the apparent direction of the star displaced - as is expected of gravitational lensing. So, "almost" means not so perfectly aligned that it forms a ring, but enough to show a noticeable deflection.
OK. It was there all along - but I am only applying enough thrust to balance out the direct gravitational effects of the lens (ie, the galaxy, black hole, whatever).
OK, but then we can immediately discard any possibility that it falls directly towards the star.
If "L" is the lens, "S" is the star, and "C" is my spacecraft, then without "S", C hovers stationary (by thrusters) at some distance from "L". But because of "S" it moves - it is pulled in some direction.
I proposed two answers: 1) in the same direction it would had "L" and the thrusters not been included in the scenario (which could be described as "directly"). Or 2) in the direction where "S" visibly appears to be.
Are you saying that we can immediately discard option 1?
In other words, the thrusters are there to null out the direct gravitational effects of the lens. I am only looking for the gravitational contribution of the star.
You can't, at least not the way you appear to be thinking.
You can calculate what magnitude and direction of thrust would be sufficient to hover above the lens object at a given altitude, if the lens object were the only gravitating object present, and apply that thrust. But that doesn't mean your ship now behaves as if the lens object wasn't there. The lens object is still affecting the spacetime geometry, and therefore it's still affecting the worldline of your ship.
So my short answer to your OP question is "something else".
OK, glad to hear option 1 is out.
I didn't expect my ship to act exactly the same. For one thing, as soon as "C" is displaced by the gravitational contribution of the star ("S"), the pull from the lens on "C" will begin changing.
But you are saying that the gravitational contribution of "S" on "C" will not be precisely in the apparent (ie visible) direction of "C" - even in the moment when "C" is in a stationary hover ??
If not, how far off will it be? Will it be close?
OK, I misunderstood. The "almost directly" refers to the path from C to L, and the "directly" refers to the path from C to S. I thought both referred to the path from C to L.
I don't know the answer to your question directly for gravity, but I do know the answer for electromagnetism. The equations are the same for weak gravity, so they may be applicable, but maybe not.
For electromagnetism if you have a charged L, S, and C, and in addition L and S are emitting light, the force from S acting on C may come from a different direction than the light from S to C. The light will come from the retarded position, but the force will come from the retarded position plus the retarded velocity times the difference between the current and the retarded time. In your specific scenario that is the same, but not in all scenarios.
I am not surprised that there is an "option 3" which is the accepted answer.
If option 3 is anything similar to option 2, then you would get interesting effects as you approached the photon sphere of a Schwarzschild black hole. The gravitational effect of everything outside the photon sphere would be pulling you up or to the side - even if it was on the opposite side of the black hole.
Then, after dropping below the photon sphere, it might be valid to model the mass of the black hole as existing only on its event horizon. If you do that, and follow the "light line" paths of that mass to your space craft, I believe you get something very different than an ever-increasing gravitational field.
In other words, I was hoping to make things as simple for me to understand as possible - and to try to avoid the worse of the messy black-hole arithmetic.
Strictly speaking, there isn't one; GR is nonlinear. You can't separate out the contribution of one particular source.
Note also that the system is not stationary; "S" and "L" will be moving relative to each other. And for "S" to make a difference to the worldline of "C", it has to be pretty close to "L"--if it's far away, its contribution is negligible. And "C", by your scenario, is pretty far away from both "L" and "S"; light years, you said. So from "C"'s viewpoint, it's going to be very difficult to even tell, gravitationally, that there isn't just one source of gravity, "L" and "S" combined.
As for any actual calculation of this scenario, it would have to be numerical. I'm not aware of any such calculation in the literature, but perhaps there is one. In the absence of such a calculation, I don't think we can say much more about the answer than has already been said.
It had to be non-linear. For option 2, I was trying to work with first order estimates.
I haven't been able to grasp how gravity "propagates" or "communicates" as the photon sphere of a Schwarzschild black hole is approached and passed.
What about the gravitational pull of "everything else in the universe"? Certainly the combination of that and the black hole gravity combine non-linearly. How could the net of all the "everything else" be anything other than to pull up?
That's the exact storyline I was trying to avoid.
For that sort of thing I think that the electromagnetic analogy in the weak field limit is instructive. In EM the direction of the force does not always coincide with the direction of the light. That must also be true in the weak field limit of gravity.
Although I cannot answer for black holes, I would very surprised to learn that strong gravitational fields act to make the direction of the “force” always coincide with the direction of the light when that is not true of weak fields.
That only works in the regime where the higher order terms are negligible. That can be true in the local region around your "C", but it can't be true for the region containing your sources, "L" and "S".
This is a different question from the one we've been discussing, and should be discussed in a new thread.
If the everything else is distributed around the region you're interested in in a spherically symmetric manner (which is not a bad approximation in many cases), then its net effect on the spacetime geometry inside the region you're interested in is zero. This is the GR version of the shell theorem (or at least one part of it).
If the everything else is not distributed spherically symmetrically around the region you're interested in, then there can be some "pull" from it--but it's not at all clear that the obvious direction for that "pull" will be "up". (Indeed, a Newtonian "pull" might not even be the best way to picture the effects.)
Unfortunately I don't think you can. There is no exact solution for your scenario, so we have no analytical equations we can use.
  • Agree
To avoid ambiguous wording, confusion, let me set up a scenario.
Say we are being lowered to the north pole of a black hole and we have reached the photon sphere. And say that there is a significant mass (SM) on the opposite side (ie, south pole) of that black hole. A direct path from that SM to us would go through the "interior" of the black hole - which is not a real path. If the gravity reaches us through the same mechanism as light - ie, through curved space - then we would see light from the SM coming to us mostly from the sides. If gravity followed the same path as the light, it might just as well pull us up (away from the event horizon) as down. I'm not saying that this would happen, but if you had subscribed to option 2, I would have been asking for clarification. In contrast anything mass behind us would tend to simply pull us up.
Attempting to follow option 2 once you've passed into the photon sphere is even more interesting - because now you need to communicate the black hole mass from within the event horizon through even curvier space to us. If you parse up the event horizon into pieces, and try to determine which direction each piece is pulling on us through curved space (integration), it is very hard for me to see how the gravitation forces could combine in any way similar to the way it does with a Euclidean model.
Light is radiation. "Gravity" in the sense you are using it here is not radiation. You can't treat the two as though they're the same kind of thing.
GR is a theory of spacetime, not space. Thinking of gravity as "propagating through curved space" is not going to work well.
Unfortunately, I think you are trying to work with a conceptual scheme that is not suited to the scenarios you are posing.
I'll save further comments on your "slowly lowering to the photon sphere" scenario for a separate post.
First, as I said before, this scenario will not be stationary. If the SM and the hole are at rest relative to each other at some instant of time, they will fall towards each other and merge. If the SM and the hole have some sideways motion relative to each other, they'll either be in mutual orbits about each other or they'll be in some kind of flyby scenario where each escapes to infinity relative to the other. None of these scenarios can be treated the way you appear to be thinking, as if the SM is at rest on the opposite side of the hole from the object being slowly lowered.
Second, as far as any slow lowering process is concerned, the photon sphere makes no difference whatever. All that happens during the slow lowering process is that the force that has to be exerted on the object being lowered gradually increases. There is no discontinuity or change in behavior at the photon sphere. The force (at the object) increases without bound as the hole's horizon is approached (if we only consider the hole and not the SM).
I don’t think this reasoning is correct. In weak fields the force and the light can come from different directions even though both come through the same spacetime.
I am not surprised.
If the force can come from a different direction than its effect, it suggests that the field has orientation(s). But that orientation still has to survive spans of curved space. I wonder how well it does.
What does that mean?
Responding to "What does that mean?"
I was interpreting this as meaning that the field was coming from the same direction as the light - but that its force was directed along that orientation.
I don’t know how you can define the direction that the force comes from independent of the direction of the force.
AI video removed
Dale said:
For electromagnetism ... The light will come from the retarded position, but the force will come from the retarded position plus the retarded velocity times the difference between the current and the retarded time.
To the question I posed in the OP. Yes, information about gravity will follow the same path as the light. And gravity will be affected by the gravitational lensing. But, with or without the lensing, only when the I am moving directly towards or away from the gravitational source (or hovering in place with it) will the direction that the gravity directs me be aligned precisely with where the gravitational source appears to me optically.
As far as how this affects the mechanics of a black hole. I'm still reading.
.Scott said:
a Feynman video
First, just the title of the video screams "not a good source".
Second, it's not clear that the video actually is Feynman.
Third, gravity is not a force in GR. In the weak field approximation, there is a way to sorta kinda think of it as a force, but not a Newtonian force pointed at the source, and not as something that propagates at the speed of light. See this classic paper by Carlip (which has been discussed in quite a few previous PF threads):
https://arxiv.org/abs/gr-qc/9909087
No, this is not correct, because there is no "information about gravity" in the sense you are using the term that has to propagate.
Gravitational waves will propagate similarly to light waves, at least if the scenario is one where we can usefully split the spacetime geometry into a "background" part and a "gravitational wave" part (a good example of a case like this is a binary pulsar and the change in its orbital parameters over time due to gravitational wave emission). But "gravity" in general is not propagated by gravitational waves (any more than a static EM force is propagated by light waves--the Carlip paper I referenced above discusses the comparison between those two cases in some detail).
You really, really, really need to stop waving your hands and look at what the actual theories in question say. Your intuitions are steering you wrong, and you need to unlearn them.
If you are moving only radially or hovering at a spherically symmetrical mass, how could the direction of the net gravity by the mass on you be any different from the visual center of the mass, since the entire scenario is symmetrical?
If you include the lensing of it's own light by its mass, this might affect the visual size of the massive object.
I wouldn't be. I was only stating that in all other cases, there would not be perfect alignment.
An observation - this is answerable with Newtonian gravity. If the lensed object is distant from you and you are near the lens, then to an excellent approximation both you and the lens will fall towards the distant object with the same acceleration. So you would require no additional thrust to hold position with respect to the lens.
To a slightly better approximation, you and the lens would fall on radial lines towards the distant object. Since you are almost colinear and you are further from the object than the lens is the lens will accelerate more rapidly than you, so you would actually have to accelerate towards the distant object (or reduce your station-keeping thrust) to maintain your position wrt the lens. Conversely, if you were between the lens and the distant object you would need to accelerate away from the distant object (or, again, reduce your station-keeping thrust) to maintain position.
So, considering that we've managed to obtain answers between "yes" and "no, actually the exact opposite" in Newtonian gravity, then we can probably conclude that we would find similar in a full GR treatment.
  • · Replies 43 ·
  • · Replies 51 ·
  • · Replies 22 ·
  • · Replies 22 ·
  • · Replies 35 ·
