Why is the Lorentz Force always perpendicular to velocity?
  • Context: Undergrad
  • Thread starter Thread starter JiuBeixin
    Lorentz force
JiuBeixin
TL;DR
Exploring the relativistic origin of Lorentz force. I'm deriving how a transverse force (from length contraction) and a longitudinal force (from relativistic momentum compensation) combine to stay perpendicular to velocity.
I represent the conductor as two parallel lines: stationary protons and electrons moving at velocity ##v##. A test object with a positive charge also moves at velocity ##v## parallel to the electrons.
In frame ##S'## (the rest frame of the object), the object experiences a repulsive force (the origin of the Lorentz force) due to the length contraction of the moving proton line.
If I introduce an additional vertical velocity ##u## to the object in the frame ##S## the rest frame of the conductor), the entire conductor appears to move upward in frame ##S'##. Since length contraction only occurs in the direction of relative motion, this vertical shift seemingly shouldn't create any additional charge density imbalance, so there isn't any extra force.
Yet, someone told me that because of a kind of Transformation of Forces, the force in frame ##S## would be vertical, but WHT and HOW it transform?
PS: I am a high school student and not a native English speaker, so please excuse any grammar issuee and awkward phrase :)​
JiuBeixin said:
If I introduce an additional vertical velocity u to the object in the frame S the rest frame of the conductor), the entire conductor appears to move upward in frame S′.
Not just upward, but to the right (like it was moving before) and upward. So you have to apply the Lorentz transformation along that diagonal direction.
The Lorentz transformation is non-linear, so you cannot decompose it into independent dimensions like with Galilean transformations.
Consdider the case where the test charge moves perpendicularly away from the conductor ("wire") in the lab frame ##S## and suppose the charge has no motion parallel to the wire. Let ##S'## be the frame moving with the test charge. In both ##S## and ##S'##, there is no imbalance of charge density in the wire. In frame ##S## there is no electric field produced by the conductor, only a magnetic field.
In frame ##S'## there are both an electric field and a magnetic field :wideeyed:. See this thread for a discussion of how the electric field arises in ##S'## even though there is no charge imbalance. The electric field in ##S'## is parallel to the wire. Thus, in this frame there is an electric force on the test charge parallel to the conductor and no magnetic force (because the test charge is not moving in this frame).
Frame ##S## also finds a force on the test charge parallel to the wire. But, in this frame the force is interpreted as a magnetic force.
In general this is not the case. The Lorentz force is ##F = q \left( \vec{E} + \vec{v} \times \vec{B} \right)## (modulo some constant factors that depend on your choice of units). The ##\vec{v} \times \vec{B}## component will always be perpendicular to ##\vec{v}##, but the ##\vec{E}## component does not have to be. For a simple example, consider an electron that starts out at rest between two oppositely charged plates, as in a capacitor: in the rest frame of the plates, the EM field is pure ##\vec{E}## and the force on the electron will be parallel to its velocity once it starts moving towards the positively charged plate.
The OP might be using a different naming convention:
https://en.wikipedia.org/wiki/Lorentz_force said:
Some sources refer to the Lorentz force as the sum of both components, while others use the term to refer to the magnetic part alone.
Notably, Zangwill uses the "Lorentz force = magnetic force" convention.
This is also how I learned it in school, while the other component was called "Coulomb force"
It seems to me that if you define the Lorentz force as being only due to the magnetic field, the Lorentz force is perpendicular to the magnetic field because you defined it that way. Perhaps there's some way to rephrase the question in a more covariant way that doesn't treat the electric and magnetic fields differently - that would likely be more illuminating.
There's no way to define "Lorentz force" as being solely due to the magnetic field and have the definition be covariant. And if we define it the way I defined it, which is the only covariant way to define a force on a charged object due to the EM field, then the answer to the question is what I said in post #4--in general, the force is not always perpendicular to the velocity.
One could start from the equation for the Lorentz 4-force and from that it is rest mass-preserving.
Source
Which is equivalent to what I wrote in post #4, i.e., it is not just the magnetic force. So what I said in post #4 would apply if one takes this approach.
Indeed, yes. At this point I'm not sure how familiar the OP is with the concept of covariance and what we call the covariant fomulation of electromagnetism. In case they either were familiar with it or were potentially interested in learning about it, I thought I'd give them a nudge in that general direction.
Source
Your source got trimmed - but I do find the argument that the idea that the electromagnetic force should preserve the rest mass of a particle does imply that if we formulate the 4-force as a tensor, said tensor should be anitsymmetric. In terms of 4-forces and 4-vectors, it implies that the idea of preservation of rest mass requires that the 4-force should be orthogonal to the 4-velocity. This formulation of limitations on the form of the force law that make it preserve rest mass may be slightly more approachable as it requires 4-vectors rather than tensors. However, the original post was not written in a covariant framework, and I'm not sure how to translate this observation into a non-covariant form or how helpful it will be to the OP. We can hope it will be useful to them though.
Thanks yoru reply. But I still have question. As I know, Lorentz Transformation is a frame tranformation. How could it affect the direction of force? And, I only know a little about Lorentz Transformation, so do you know where can I learn more about Lorentz Transformation?
You are right. Now I do not treat the electric and magnetic fields differently. I veiw lorentz force as a special electric force but caused only when related moving occurs. And I didn't say that Lorentz force is perpendicular to the magnetic field.
Source
LOL, this is to difficult for me XD
In my model, the conductor is electrically neutral in the lab frame (##S##), so there is no net electric field (##\vec{E} = 0##). Therefore, the ##q\vec{E}## term vanishes, leaving only the magnetic component
In the lab frame, yes, this is the case. But it is not the case in the rest frame ##S'## of the object. In that frame there is a nonzero electric field.
As an interesting(?) aside, we can "pick out" the magnetic force for a particular observer in a manifestly covariant way (I know this isn't what you meant).
With the field tensor ##F^{\mu \nu}## and the "projection tensor" ##P^{\mu}_{\nu} = \delta^{\mu}_{\nu} - u^{\mu} u_{\nu} ## for observer four-velocity ##u^{\mu}## (where ##u^{\mu} u_{\mu} = 1##), the tensor ##B^{\rho \omega} = F^{\mu \nu} P_{\mu}^{\rho} P_{\nu}^{\omega}## for the ##u^{\mu}## observer is ##F^{\rho \omega}## but with ##F^{0 \omega} = F^{\rho 0} = 0## (i.e., with the electric-field components "zeroed out"). Then for a particle with charge ##q## and four-velocity ##v^{\nu}##, the four-vector ##q B^{\rho \omega} v_{\omega}/(v^{\nu} u_{\nu})## for the ##u^{\mu}## observer has components ##(0, q \vec v \times \vec B)## (where ##\vec v## is the particle's 3-velocity).
Yes, because you can express both the observer's 4-velocity and the overall EM field as covariant objects (a 4-vector and an antisymmetric 2nd rank tensor).
But of course if you switch to a different 4-velocity by changing which "observer" you use (or changing the state of motion of an "observer"), what looked like a pure "magnetic force" for the original observer will no longer look like one for the new observer.
Whether you call it the Lorentz force or the magnetic force is just a naming convention. But the fact that it's perpendicular to the magnetic field is an observed behavior of Nature, it doesn't seem like a convention to me.
But "perpendicular to the magnetic field" is not a covariant concept, because "the magnetic field" is not a covariant concept. Only the full EM field tensor is covariant.
You can covariantly define a notion of "perpendicular to an object's velocity", as @SiennaTheGr8 posted, but that's not the same as "perpendicular to the magnetic field".
Thanks everyone here!:coffee:
Now, I’d like to clarify that in my mental model, I don’t treat "electric" and "magnetic" forces as separate entities.
Then, I've realized that my previous confusion came from assuming the force vector's direction is "fixed" during frame shift. That means a downward force in frame ##S'## can become vertical to the velocity. But how this occur? I think the direction it change depends on the direction of velocity.
I’d love to know if there's a more intuitive way to see this "vector tranformation"
Whether two 3D vectors are perpendicular depends on the frame of reference. Imagine a particle is moving along the x-axis and the force on the particle is in the y-direction.
Now change to a frame of reference moving in the y-direction. The force vector still points along the new y'-axis, but the particle is not moving in the new x' direction.
This implies that a pure magnetic force in one frame may not be a pure magnetic force in another frame, and will generally have an electric component.
However, the physical phenomena are equivalent whatever reference frame is employed.
Terme and conditions may apply.
As I understand your scenario, the object is moving in frame ##S## not parallel and not perpendicular to the conductor. But the force must be perpenducular to the object's velocity, because in this frame there is only a magnetic field. It may look like this:
If you make a horizontal boost transformation to the rest frame of the object, then the force will be also vertically, accourding to the following force transformation formulas
(the indices ##1, 2, 3## correspondent to ##x, y, z##):
Source (page 124, equation 6.46):
https://www.amazon.com/Relativity-S...fgang-Rindler/dp/0198567324?tag=pfamazon01-20
shortened online version (equation 78)
What does this mean exactly?
In the frame where the conductor is neutral (conductor rest frame), the EM-force is perpendicular to the test change velocity.
In the frame where the test charge is at rest, the EM-force is perpendicular to the (now charged) conductor.
Note that the orientation of the conductor is different between the frames, that are related by a boost oblique to the conductor.
In the labframe ##S## in my drawing in posting #26, the ##x## axis points in the same horizontal direction as ##u_1##, the ##y## axis in the same vertical direction as ##f_2## and the ##z## axis, according to the right-hand rule, in out of the paper plane.
In frame ##S'##, which is the rest-frame of the object, the force ##f'_2## points in the vertical ##y'## direction.
I don't think so, because in frame ##S'## the conductor is not oriented horizontally. The ##\Delta y'## between distant atoms of the conductor is the same as the ##\Delta y## in frame ##S##.
Yes. The ##\Delta x'## between distant atoms of the conductor is lenght contracted, but the ##\Delta y'## is not.
The fields of the moving positive atom-ions (and electrons) of the conductor in frame ##S'## are also length-contracted.
JiuBeixin said:
TL;DR: Exploring the relativistic origin of Lorentz force. I'm deriving how a transverse force (from length contraction) and a longitudinal force (from relativistic momentum compensation) combine to stay perpendicular to velocity.
After thinking about this some, I think you have gotten some good advice when you suggested you wanted to learn more about transformation laws.
Maxwell's equations are fully relativistic. If you know how to properly transform charges and currents (usually expressed as charge density and current density), you can use Maxwell's equations to answer your questions. Judging by your questions, you don't currently even know the name of the Lorentz transform - apologies if I got this wrong).
You give the impression of not having any questions about Maxwell's equations (in the most basic form, two Gauss' laws, Faraday's law, and Ampere's law), but rather about the relativistic aspects.
There's a standardized way of describing the source terms. This is in terms of charge density, which would be coulomb/meter^3, and current density, which would be ampere's per meter^2.
The tool you need to know how these quantities transform when switching from a rest frame to a moving frame is called the Lorentz transform, and that's what you need to research.
It'd also be helpful to know the terms "Lorentz boost", which is the way we describe going from a "stationary" frame of reference to a moving frame of reference, and the term "invariant". Invariants are quantites that don't change when you perform a Lorentz boost, I.e. switch from a stationary frame to a moving frame.
The notable invariant of charge and current doesn't have a catchy name, but is given by the quantity
$$c^2 \rho^2 - |J|^2$$
where c is the speed of light, ##\rho## is the charge density in coulomb's/meter^3, and J is the current density in amperes / m^2.
Note that one point of this is that when we boost a neutral current carrying wire in the direction of current flow, it becomes charged. Which you seem to be aware of.
As far as sources go, the results of a "swarm of particles" are well known, but I don't know of many texts that go through the actual work of analyzing a swarm of particles. Usually they just present the results for the continuum limit.
I think that would be the "proper charge density" (for the right kind of charge distribution, anyway).
  • · Replies 101 ·
  • · Replies 17 ·
  • · Replies 30 ·
