Finding the minimum distance between two curves
  • Context: Undergrad
  • Thread starter Thread starter Charles Link
Charles Link
Homework Helper
Insights Author
2025 Award
TL;DR
The problem is to compute the minimum distance between the two curves y=4-x^2 and y=(x-3)^2 in two dimensions.
The other day a friend of mine gave me the above problem which I found rather interesting. I was able to get a numerical solution. I'll post how I solved it later in the thread. Others may want to try it and see what they come up with.
Square of the distance is
$$L^2=(y_1-y_2)^2+(x_1-x_2)^2=(4-x_1^2-(x_2-3)^2)^2+(x_1-x_2)^2$$
The condition of minimum is
$$\frac{\partial L^2}{\partial x_1}=\frac{\partial L^2}{\partial x_2}=0$$
Intersection of these two curves would give an answer.
@anuttarasammyak That's one part of what I did to solve it. Those two partial derivative expressions are really too clumsy to solve exactly. I used them though by getting an approximate ## x ## for where the two ## x ## values occur by first solving for the ## x ## where the vertical distance is a minimum. That turns out to be at ## x=3/2 ##.
I then let ## x_1=3/2+ \Delta_1 ## and ## x_2=3/2+ \Delta_2 ## and solved for ## \Delta_ 1## and ## \Delta_2 ## to first order using the two partial derivative expressions.
Others may want to try the calculation and/or have alternative ways of solving it, so I'm leaving just a summary of the solution rather than showing all of the details.
continued from #2:
With the help of Wolfram I get one real solution. https://www.wolframalpha.com/input?i=Solve+(4-x^2-(y-3)^2)(-2x)+(x-y)=0+and++(4-x^2-(y-3)^2)2(y-3))+(x-y)=0.+
where ##x=x_1,y=x_2## Let us confirm it.
It is easily observed that the two curve formula coincide when ##-x=y-3=-a## thus a should satisfy
$$4a^3-6a-3=0$$
which derives all the solutions. Using real ##a=2^{-1/3}+2^{-2/3}=1.42366...##.
The minimum distance is
$$L=\sqrt{4a^4-12a^2-12a+25}=\sqrt{-6a^2-9a+25}=\sqrt{19-12*2^{-1/3}-15*2^{-2/3}}=0.16182....$$
when ##x_1=a, x_2=3-a##
I hope I commit no more careless mistakes.
  • Love
@anuttarasammyak We are going to need to look over your two partial derivative expressions carefully, because your solution is incorrect and not even in the right ballpark. I got, doing it all by hand with no computer that ## (x_1,y_1)=(1.43,1.96)##, and ##(x_2,y_2)=(1.57,2.04) ## for a minimum distance of ## L=0.16 ##. These are approximate coordinates, and only accurate to the two decimals.
Edit: and I looked over your partial derivative expressions=they look like they may be correct. The values for the real solution might also be correct, but I don't have a computer that can compute them. It looks like you did get ## x_1=1.42366 ## and ## x_2=1.57634 ## which is close enough to what I got that they are most likely correct and even exact in the form Wolfram has them. I think your error may be when you finished up.
Try computing ## L ## again, but use ## (x_1,y_1) ## and ## (x_2,y_2) ##. I don't know where your expression for ## L ## using ## a ## came from. Note: ## L=\sqrt{(x_2-x_1)^2+(y_2-y_1)^2} ##.
With that one correction, I think everything else you did may be correct. :)
and I see you have now edited your post and made the correction. Very good=excellent. :)
I am sorry for my careless mistakes on L. I corrected #4. It seems in good accord with your result.
@anuttarasammyak Thank you very much for your solution above. It is excellent. <3 <3
@anuttarasammyak Perhaps you also noticed this already, but I find it interesting that with your exact solution, the slopes of the curves are precisely parallel, as they should be, at ## x_1= a ## and ## x_2=3-a ##, with slopes of ## -2 x_1 =-2a ## and ## 2(x_2-3)=-2a ##.
Edit: I also believe that ## (x_1,y_1),(x_2,y_2) ## and ## (3/2,2) ## are co-linear with a slope of ## 1/(2a) ## of the line connecting them, making the line perpendicular to the two curves at the two points. I'll need to check this but I'm almost certain that it is the case. =and yes, I checked it, and it indeed is the case, as it needed to be. :)
( Note: ##x=3/2 ## is where the vertical distance is minimized, and ## y=2 ## is where the horizontal distance is minimized between the two curves. The point ##(3/2,2) ## didn't need to be perfectly co-linear with the other two points, but I thought it might be, and yes, it is.)
Charles Link said:
@anuttarasammyak Perhaps you also noticed this already, but I find it interesting that with your exact solution, the slopes of the curves are precisely parallel, as they should be, at x1=a and x2=3−a, with slopes of −2x1=−2a and 2(x2−3)=−2a.
After transformation of ##X_2=3-x_2## the two partial differential equations are
$$-2(4-x_1^2 -X_2^2)x_1+(x_1+X_2-3)=0$$
$$-2(4-x_1^2 -X_2^2)X_2+(x_1+X_2-3)=0$$
This pair of eqution is obviously symmetric between ##x_1## and ##X_2##. This may help you to prove the features you find that have been not confirmed yet.
For the calculation with the slopes mentioned in post 8, we have ## m=\frac{2-(4-a^2)}{3/2-a}=\frac{(3-a-3)^2-2}{3-a-3/2}## and these are both ## \frac{a^2-2}{3/2-a}=\frac{1}{2a} ## because of what @anuttarasammyak had previously mentioned in post 4 that comes from the first partial derivative expression that ## 4a^3-6a-3=0 ##.
Meanwhile the midpoint of the two points is readily computed to be ## (x_m,y_m)=((a+3-a)/2, (4-a^2+(3-a-3)^2)/2)=(3/2,2) ##.
If $$L = (y_1(x_1) - y_2(x_2))^2 + (x_1 - x_2)^2$$ then the partial derivatives are $$\begin{split}
\frac{\partial L}{\partial x_1} &= 2(y_1 - y_2)y_1'(x_1) + 2 (x_1 - x_2) = 0 \\
\frac{\partial L}{\partial x_2} &= -2(y_1 - y_2)y_2'(x_2) - 2 (x_1 - x_2) = 0.\end{split}$$ Adding these gives $$
(y_1 - y_2) \left( y_1'(x_1) - y_2'(x_2)\right) = 0$$ whilst adding ##y_2'(x_2)## times the first and ##y_1'(x_1)## times the second gives $$
(x_1 - x_2) \left( y_1'(x_1) - y_2'(x_2)\right) = 0.$$ In each equation, one of other factor must vanish. For ##y_1 = 4 - x^2## and ##y_2 = (x + 3)^2## we know that ##x_1 - x_2## and ##y_1 - y_2## don't vanish simultaneously, so we must have $$y_1'(x_1) - y_2'(x_2) = -2(x_1 + x_2 + 3) = 0.$$ Eliminating one or other of ##x_1## and ##x_2## in either of the partial derivatives for ##L## then gives a cubic for the other, which can be solved analytically by standard methods.
pasmith said:
Eliminating one or other of x1 and x2 in either of the partial derivatives for L then gives a cubic for the other, which can be solved analytically by standard methods.
Yes, sometime I'm going to need to try Vieta's substitution on this cubic and see if I can get the same answers that Wolfram got. :)
and perhaps @anuttarasammyak already identified the cubic in post 4 that needs to be solved. It may be simply solving ## 4a^3-6a-3=0 ## to get the ## x_1 ##.
and yes, I got Vieta's substitution to work on ## a^3-\frac{3a}{2}-\frac{3}{4}=0 ##, so that ## a=w+\frac{1}{2w} ##. The solution is routine indeed to solve for ## w^3 ## and then ## a ##. :)
and I suggest the reader try this themselves. They will find they are able to solve this cubic for ## a ## and get the same answer that Wolfram got in @anuttarasammyak post 4 above.
If we go to @anuttarasammyak post 9 and assume we have a solution where ## x_1=X_2 ##, that solves it completely with what we did just above. and @pasmith showed in post 11 that ## x_1+x_2-3=0 ## where I think he got the sign wrong on the 3 but otherwise completely correct. :)
@pasmith I think it should read ##-2(x_1+x_2-3)=0 ##. Otherwise, yes, very good=excellent. :)
and I think I see where he got the wrong sign: Right before that he has ## y_2=(x+3)^2 ## where it should be a minus sign on the 3.
Just a couple additional comments: I thought I did pretty well by getting a numerical solution by writing out the partial derivative expressions and solving for ##x_1 ## and ## x_2 ## to first order about ## x=3/2 ##. The exact solutions given by @anuttarasammyak and @pasmith are really a hundred times better though, thank you. <3 <3
Charles Link said:
TL;DR: The problem is to compute the minimum distance between the two curves y=4-x^2 and y=(x-3)^2 in two dimensions.
Let ## (x_1,y_1) ## be a point on the curve ## f(x)=4-x^2 ##, which is the closest point on the curve ## f(x) ## to the curve ## g(x)=(x-3)^2 ##, and let ## (x_1+a,y_1+b) ## be a point on the curve ## g(x)=(x-3)^2 ##, which is the closest point on the curve ## g(x) ## to the curve ## f(x) ##. That means that curves ## y-b=4-(x-a)^2 ## and ## y=(x-3)^2 ## intersect at only one point. The equation ## b+4-(x-a)^2=(x-3)^2 ## has only one solution, and its discriminant must be equal to zero. There is ## 2b+6a-a^2-1=0 ##.
The slope of ## y=4-x^2 ## in point ## (x_1,y_1) ## is ## -2x_1 ## and it is equal to ## -a/b ##. Also, it is equal to the slope of ## y=(x-3)^2 ## in point ## (x_1+a,y_1+b) ##, and we have ## -2x_1=2(x_1+a-3) ##. From ## -2x_1=-a/b ## and ## -2x_1=2(x_1+a-3) ## we have ## b=a/(3-a) ##.
After substituting ## b ## with ## a/(3-a) ##, the equation ## 2b+6a-a^2-1=0 ## will be ## a^3-9a^2+21a-3=0 ##. I can solve the equation ## a^3-9a^2+21a-3=0 ## without using a computer, only numerically. The computer gives me the result of ## a=0,15267789 ##. ## b=a/(3-a) ## implies that ## b=0,05362157 ##.
The minimum distance is ## \sqrt{a^2+b^2}=0,16182031 ##.
  • · Replies 18 ·
