Quantum interpretations and indistinguishable elementary particles
Ben vdP
TL;DR
Elementary particles are indistinguishable and this has consequences.
How do different interpretations take this into account or deal with situations where one cannot identify a particular quantum?
Does the way forces work (the exchange of virtual particles) provide a mechanism for being indistinguishable?
On one hand, a minimal view of quantum mechanics is to see the Schrödinger equation and wavefunction as part of a description for a "generic" quantum system or ensemble of identical prepared systems ala Ballentine ( The Statistical Interpretation of Quantum Mechanics ).
In the act of measurement one moves from a "generic cat" to a "more specific cat" or subensemble.
On the other hand there are interpretations that view the wavefunction as representing a complete state description or representing an individual physical system.
With Copenhagen you then get the collapse of the wave function or the many world interpretation with the splitting up into many worlds.
It looks there is nothing in the middle.
A simple example:
Consider light going through a window.
On macro level it makes sense to say that a photon arrives at the window, travels through the glass and leaves the window.
On micro level the story could be very different. There could be all kinds of interactions taking place, the photon could get absorbed, there could be a re-emit.
And also, elementary particles are indistinguishable, if a quantum is detected at a certain position then at a later time or later detection you cannot say that it is the same or a different one at the same position.
As a consequence, it is impossible to tell if the photon leaving the window is still the same one that entered the window.
So at a glance, it is prohibited to use a wavefunction for a single photon in the large i.e. across the window.
Or more generally across a measurement or interaction at macro level.
What could be a justification to still try to do so or do you just pretend it as an approximation?
How do different interpretations deal with such issues?
A photon that is "absorbed and reemitted" will likely leave behind energy and end up with a higher wavelength. Or, in the case of a laser, stimulate the emission of light at a lower wavelength.
At a QM entity, exactly what happens when a photon is travelling is not simple.
The landing spot of a photon is a function of what it would have encountered in all of its potential trajectories, not just the one that it appeared to follow.
Certainly. If I form a negative ion by adding an electron to a molecule and then take that electron back, it is meaningless to ask if I got the same one back that I put in.
Even the meaningful of the question is unclear. Think of the detection of a particle that just landed on the screen in a double slit experiment. Would you be asking if that photon was the same one that existed before it entered the slits? Which slit?
I think that you are holding onto an model that says that photons follow a specific trajectory. Any "interpretation" that relies on that would be the approximation. The wave function is the precise answer.
A more direct answer is to realise that ordinary non-relativistic QM (QM) is incorrect - our best current theory is Quantum Field Theory (QFT). In QFT, there are no particles, only excitations in the quantum field. Suppose you have two identical excitations and reverse them. There is no difference. QFT explains why all particles are literally identical.
It turns out that several quantum mysteries are trivial in QFT, and a literal interpretation of QFT is, IMHO, an excellent interpretation of quantum physics in general. If you would like to explore this in more detail, get:
https://www.amazon.com.au/Fields-Their-Quanta-Quantum-Foundations-ebook/dp/B0DLNLLG7Y
It's not a common interpretation, and the book is a bit pricey, but it's accurate (for the knowledgeable, there are minor defects). The only actual assumption is, and the majority of physicists agree with this, that the quantum fields are real (it seems almost trivial - if particles are real, then excitations in the field are real, and the field is real). But a careful analysis shows that they, too, may be just calculational tools. Ah, well, the foundations of physics have always been a bit murky; we just often don't realise it (nor does it generally matter a hoot, if we are honest). However, now and then, someone like Bell comes along, and it turns out to actually be important. Thats when breakthroughs are made.
Thanks
Bill
What is the wave the answer to?
Does it represent an individual physical system or an ensemble or something only mathematically or something else?
Any choice here is already a particular interpretation.
Also if you wanted to say that photons do not follow a particular path but multiple paths with probabilities then that is also a particular interpretation of quantum mechanics and not universal.
(I did not wanted to say that the particle followed a path in the classical sense or literal).
Do I understand it correctly that you reject the idea that the wave function stands for an individual physical system?
On hindsight there might be two aspects that interpretations have to deal with:
- In how far are relevant phenomena the result of fundamentally collective processes
- In how far can you label a quantum particle
Thanks
Bill
I agree that QFT should bring better answers.
The implications on what you might still be able to tell on macroscopic level could be very complicated.
Not "wave", "wave function". It provides the weighted distribution of all the places where you might find a particle. When used that way, it directly reflects exactly what is found in particle experiments. So, it is not an "interpretation". Any description of what is going that is consistent with the wave function (and, more importantly, actual experiments) would be either a "theory" or an "interpretation". If that model or description only makes predictions that are described by the wave function, then that description would e an "interpretation". Otherwise (if it predicts something new), it would be a theory - with, perhaps, it's own family of interpretations.
Even the same person in the same paragraph might describe the travel of a photon as both a particle trajectory and a waveform pattern. It's hard not to. We like to think in terms of "what is actually happening" - in hopes of seeing something familiar. QM doesn't cooperate. It reminds me of that Mermin phrase "Shut up and calculate".
So when you asked about whether it was the same photon that entered the glass as left the glass, my concern was that you were taking the "trajectory" model a little too seriously. In other words, if you're down to a level of detail where you want to label every photon, then you need to back up because that kind of labelling can only be done after the fact. If I set up a dim flashlight, point it through a window at a screen, and detect a photon on that screen, then I may be able to deduce that specific photon originated from the flashlight, must have travelled through the window, and was detected on the screen.
I don't know. What does it mean for something to "stand for an individual physical system"?
In terms of predicting what a system will do, the wave function is limited. It only predicts everything that might happen, not specifically which of those things will happen.
Indeed wave function, just being sloppy.
From the reference given earlier (Ballentine):
(II) Interpretations which assert that a pure state
provides a complete and exhaustive description of an
individual system (e.g., an electron).
This class contains a great variety of members, from
Schrodinger’s original attempt to identify the electron
with a wave packet solution of his equation to the
several versions of the Copenhagen Interpretation.2
Indeed many physicists implicitly make assumption II
without apparently being aware that it is an additional
assumption with peculiar consequences. It is a major
aim of this paper to point out that the hypothesis II is
unnecessary for quantum theory, and moreover that it
leads to serious difficulties.
In short, the original question in narrower context:
How can you combine "exhaustive description of an individual system"
with "indistinguishable elementary particles" when that says that you cannot label them.
Every interpretation has to take that into account, so how do you deal with it?
I hadn't had a particular interpretation in mind.
"Cannot label them" is too strong a statement.
If I have a single electron captured in a Penning trap, I can label it as "the electron that's captured in that Penning trap", and describe it with a wave function, and, if I want to adopt an interpretation of QM that asserts that the wave function gives a complete and exhaustive description of that electron, I can do so. The fact that that electron is "indistinguishable" from all other electrons doesn't change that.
More generally, if I have any quantum system that's composed of one, single electron, I can do the same as I did above.
Now say I have a quantum system composed of two electrons. For example, say they're both trapped in some kind of Penning trap-like device that can trap two particles with like charges at once. Now the fact that the two electrons are "indistinguishable"--more precisely, that they are indistinguishable fermions--means that the wave function I use to describe the two-electron system has to change sign under particle exchange. But now I do not even have a wave function for either of the electrons individually. I only have a wave function for the two-electron system. And the fact that the two electrons are "indistinguishable" does not prevent me from saying that that two-electron wave function is a complete and exhaustive description of the two-electron quantum system that I am using it to describe. The fact that those two electrons are also "indistinguishable" from all the other electrons in the universe doesn't prevent me from doing that, because I can label those two electrons as "the two electrons trapped in this trap" and describe them as a two-electron quantum system on that basis.
In short, the "issue" that you claim exists, that every interpretation has to take into account, actually is not an issue at all. It's just a misunderstanding on your part of what "indistinguishable" means. It does not mean that I have to somehow describe every electron with a one-electron wave function and then somehow account for the fact that it's indistinguishable from other electrons. That isn't even a matter of QM interpretation--it's not how QM, just the basic "shut up and calculate" math without any interpretation at all, deals with things.
Yes, I understand that. You cannot label them if the different electrons have a probability to be in the same position in such a quantum system.
By the way "shut up and calculate" is actually interpretation dependant.
According to Ballentine that statement is superfluous. So is the idea that there needs to be a complete and exhaustive description.
:smile:
Usually it's taken to refer to the viewpoint that you can do QM without having to adopt any interpretation: you just do the math and compare the predictions with the data, and don't make any claims at all about "what's really happening" beyond that.
Ballentine's viewpoint is indeed similar to that--he says he's adopting an "interpretation" where the wave function/quantum state vector describes an abstract ensemble of identically prepared systems--or, equivalently, the preparation process itself. But one could also take this to be disavowing any interpretation, and adopting the viewpoint I described above, where all you're doing is computing predictions and comparing them with the data. That usually requires doing statistics on large numbers of experimental runs, which is how Ballentine describes it.
But of course there are those who disagree with Ballentine about this, and such disagreements, at least as far as this forum is concerned, do basically boil down to different interpretations of QM--including not just "what QM says about reality" but "how we're supposed to do QM in practice".
OK, during the weekend I had some time to think it over.
The electrons cannot be labeled if they each have a probability for presence at a certain position in such a system.
That can be illustrated as follows. If it would have been possible to make a measurement at the location and finding an
electron and label it as "electron A". Then in a subsequent measurement a positive identification cannot be made, since
multiple electrons have a probability for that location and you cannot tell "electron A" apart from the others.
This can be called the essence of being indistinguishable for identical particles.
As a consequence you then revert to a procedure as out-lined in post 8.
In other situations electrons are distinguishable.
This is fundamental for elementary particles and it sets limitations on what you are able to tell or describe.
I'm getting the impression now, that this was never in focus with quantum interpretations.
For example in a number of interpretations the term "superposition of states" pops-up, but there
may never have been a check for any implications on what would then still be distinguishable
within the context of a particular interpretation.
It might go to far to start discussing such things.
Also I don't want to start an argument for the sake of having an argument like in an old Monty Python episode.
I could not exactly put my finger on it, but in general I am very skeptical about far reaching statements
or conclusions being made or at an overblown skope. If it is said that "everything is entangled with everything", then that could
have some validity in a certain context within a certain interpretation. But It can also be a sign that it is based on flawed assumptions.
Yes I'm biased, since my background qua qm-training was based on Ballentine.
The best possible answer may have been given by bhobba in post 3 but it leaves a large void.
Usage of that term, unfortunately, is very vague and hand-wavy in much of the literature. There is one such usage that kinda sorta has to do with distinguishability or indistinguishability of particles--but there are plenty of other usages that don't.
The wave function, and its Born interpretation, in ordinary non-relativistic QM, is simply the consequence of modelling observations as Hermitian operators via Gleason's Theorem. It can be used for individual or composite systems.
The real issue is why observations are modelled as hermitian operators with their eigenvalues as the possible outcomes.
Assuming an intuitive understanding of QFT (i.e., all we have are interacting fields and the results of observations are simply the results of those field interactions), a quite reasonable answer to that can be given, as I have written in other posts.
But we know QM is wrong since it is not the non-relativistic limit of QFT. It's simply an approximation valuable in many, many applications.
That's the facts. I am happy with any view of it as long as it is compatible with the facts. The best view (or interpretation if you like) is of QFT, not QM - in fact, strictly speaking, any view of QM except as an approximation of QFT is wrong. I use a simple, realistic view, as detailed in the book I referenced, Fields and Their Quanta by Art Hobson (that I recommend to anyone interested in more than just a passing acquaintance with QM). But I have been told that other interpretations, such as many-worlds and decoherent histories, can also be applied to QFT. I personally have not investigated them in that context (except Arnold Neumeier's, who often posts here and is very well respected - in fact, he recommended Art Hobson's book to me):
https://arxiv.org/abs/2110.05294
I also have to mention that Ed Witten thinks QFT is just math, like calculus is just math:
Are we interested in just math? We are at rock bottom, facing the same issue Wigner wrote about in his famous 'Unreasonable Effectiveness of Mathematics', which is easily found using Google. So did Witten, except that what he said is less well known:
It's not really 'shut up and calculate', it's understanding QM as an approximation to QFT that makes many issues redundant. Indeed, Ed Witten may be correct, QFT is like calculus - books on real analysis detail it (much to the dislike of many math students), but what is it really? We also detail the laws of logic, but what are they really? Answering that is philosophy, which we don't discuss here.
Thanks
Bill
bhobba said:
The real issue is why observations are modeled as hermitian operators with their eigenvalues as the possible outcomes.
IMO the use of real numbers to describe lengths and such in classical physics is any less miraculous than using hermitian operators acting on Hilbert space in QM. Mathematics works extremely well. I think what people really find emotionally difficult with QM is the lack of a reliable preprogrammed intuition humans seem to have with much of classical physics. Well, then there’s gyroscopes…
You have corrected me and rightfully so for not taking sufficient time for it.
It is very difficult to express these things.
Elementary particles simply don't have any individuality.
You can distinguish them if they are spatial apart etc..
If in an interpretation it is posed that you are describing an individual physical system then
you might already have overestimated what you are able to tell about elementary particles.
Indistinguishable particles in two different states, here and there for example, are still indistinguishable.
I assumed that a vacuum approaches the 2nd dimension and that therefore a atom approaches the 4th dimension (I know insane) but I asked google gemini to use area equations to describe atomic bonds and time equations to describe the differences between subatomic particles and I got 4 time equations and 3 area equations my name is Thomas weissflog btw
Welcome to PF, Tom. Please keep in mind that we do not allow AI to be used as a reference in the technical forums. You can read our policies on AI in the PF Rules (see INFO at the top of the page).
Not at all. You just need to be clear about what "individual physical system" your wave function is describing. As in the example I gave earlier in the thread, two electrons can be perfectly well treated as one "individual physical system" with one wave function. And there are plenty of cases where much larger systems can be perfectly well treated as one "individual physical system" with one wave function. There is no requirement whatever that each "individual physical system" must be a single elementary particle.
No, there is no such requirement indeed.
Thus you are trying to describe with a wave function a system and interpretate it as an "individual physical system" (and not an ensemble) based upon underlying elementary particles that in principle don't have such individuality.
I got the impression everything has been said though.
That depends on the specific scenario. In some cases you can describe a single elementary particle with a specific wave function and treat it as an individual quantum system. In other cases you can't.
It is not about describing a single elementary particle, but about an individual physical system.
Let me guess, you never had a real look at the link provided at the beginning.
There can be different views and opinions about it, but included is a discussion about what
an individual physical system means and issues around it.
Then why do you keep bringing up elementary particles?
Ballentine? I've read it completely, multiple times.
Sure, Ballentine advocates an ensemble interpretation, and contrasts it with an interpretation that claims the quantum state describes an individual physical system. This is a perfectly valid contrast of different choices of interpretation. Nobody has disagreed with any of that.
And that choice of interpretation has nothing to do with indistinguishability of like particles. Everything I said in post #8, and in my later posts--all of which you've basically agreed with--is true on either type of interpretation.
So what are we discussing here, exactly?
  • Love
I thought I was the only one nutty enough to do that o0)o0)o0)o0)o0)
Thanks
Bill
I've read Misner, Thorne, & Wheeler in full, more than once, as well. Which took, um, quite a bit longer than it took to read Ballentine. :wink:
  • Love
Because elementary particles are identical. The indistinguishability is a consequence of that.
A photon may have a different energy, but still a photon is like any other photon.
It starts to look now that by interpreting a physical system as an ensemble the concept of identical particles
got incorporated into Ballentine.
This concept may be missing in other interpretations. Or how do other interpretations reckon with the concept of identical particles?
The original question could even be rephrased that way.
It is not just a choice.
By describing it as an individual physical system, it is being overlooked that every such physical system is like any other such physical system.
It's trivial in QFT.
Ordinary QM is only an approximation to the relativistic limit of QFT. There are no antiparticles in ordinary QM as required by the relativistic limit; there is just one Schrodinger equation - not two - but since antiparticles are rare in our world for the vast majority of purposes, it makes no difference - but interpretation-wise it is crucial. Interpretations of QM are only of intellectual interest. They would just take it as a fact requiring no explanation.
Thanks
Bill
I can agree with that.
p.s. Post 8 was not really relevant at all, but lets leave that
As far as the term “identical particles” is concerned, there is probably no need for any interpretation-related issues in physics:
From: “Notes on Quantum Mechanics” by Daniel V. Schroeder, Weber State University, January 2022
Identical particles
Quantum mechanics allows two (or more) particles to be identical in a sense that isn't really possible in classical mechanics. Consider what happens when two particles have all the same intrinsic properties (mass, electric charge, spin orientation, etc.), and in addition, their probability density is unchanged under the operation of interchanging its two arguments:
$$|\psi (x_2; x_1)|^2 = |\psi (x_1; x_2)|^2$$
If this relation holds, then the two particles can't even be distinguished by their locations – or rather, by the probabilities of their being found at various locations – because the probability of finding particle ##1## near ##x = a## and particle ##2## near ##x = b## is the same as that of finding particle ##2## near ##x = a## and particle ##1## near ##x = b##, for any ##a## and ##b## (see Figure 4.17). This situation is fundamentally different from classical mechanics, in which you can always distinguish particles by their locations (if nothing else).
  • · Replies 84 ·
  • · Replies 309 ·
18K
  • · Replies 91 ·
9K
  • · Replies 49 ·
